03-01-2024, 11:32 AM | #1 |
Rep 20
M240i brakes
Is there anyone that has upgrades their brakes on the M240i?
I dont like them at all, braking from lets say 200 km/h feels like I have to pray sometimes to stop in time. I live in Holland and I am near the Autobahn in Germany so I go there sometime. Just saying in case of people thinking I am some kind of speed criminal. I am looking at the M performance brakes, I had them before and they are quite good, not too expensive either. Anyone any experience with changing brakes? |
03-01-2024, 02:23 PM | #2 |
Rep 2,095
I changed from stock to M perfomance dimpled and slotted brakes on my F36 and it was night and day.
However, I have the ZKT pack on the G42 and find stock are fine. I’m sure if you got the full M performance set you be more than happy but it’s not a cheap upgrade. |
03-01-2024, 04:05 PM | #3 | |
Rep 127
nype139.50 |
03-02-2024, 08:52 AM | #4 | |
Rep 86
You are refering to the stopping distance when you do heavy braking. That has more to do with the quality and contact patch of the tires, and the quality of the suspension. Last edited by vTuga; 03-02-2024 at 08:58 AM.. |
03-03-2024, 11:29 AM | #5 |
Rep 20
Hi Tuga,
Very interesting videos and surprising aswell. Although I now believe that bigger discs do not decrease braking distance I still have to investigate why I think my cars brakes are not good enough. 1 month ago I have put on new Michelin PS4s and a complete Bilstein coilover suspension on the car so that should not be the problem. Maybe I should just have the braking system checked, oil, pads etc... Do the M performance brakes also have different calipers and pistons? They should have because the M performance discs dont fit on the Msport calipers? |
03-03-2024, 11:43 AM | #6 | |
Rep 86
What size tires do you have on the front? Wider front wheels and tires should improve braking distance a lot more than better brakes. If you improve the breaks without increasing the contact patch of the tires with the ground, you will remain traction limited. Probably will just trigger the ABS sooner. |
