03-02-2024, 07:08 PM | #1 |
Rep 136
Drives: 2023 M2 & 2018 M2
Swapping track tires: Contis Extremecontact Force!
Wow these are noticeably lighter than my Falken Azenis.
I have decided to ditch the Falken's. Why? So first off I put 275 / 295 18s RE-71RSs on our OG M2 and was immediately amazed by how well it rode. Second I was happy with the wear. Third I was happy with their predictability. Also they are asymmetric so it would be easy to rotate them left to right. Compare this to my 305 / 315 19 RT660s on my G87. They rode extremely rough. Tire wear didn't look great after a couple track days. Then there was the screw in my front pass tire. I can do a plug/patch kit and it will probably be fine, but my front left is pretty shot. I have some pretty odd wear and is probably a combo of Roebling Road being brutal on that tire and driving a bit on the street. So I was at a crossroads needing 2 new fronts. I almost went with RE71s but I would have needed to go 275 / 285 combo. My wheels are 10.5 and 11. I think it would have worked and I would have got some added rear tire height which would prevent hitting my speed limiter at the track. But then I did some more looking and was able to get a decent discount through a NASA partner for the Contis. I ended up going 295/30 up front and 315/30 in the back. The tread width is a bit narrower than the Azenis in the back but it is slightly taller. The car may have a bit more rake but we will see how that pans out once I finish up my Ohlins. But man they are light. It's a bit eerie. Looking at the charts it's like 16lbs (5 per front, 3 per rear) lighter for the set over my Falkens. Personally I like the look. I wish they were asymmetric and not rotational, but that also means I will get to use up more of the tire when i do a remount and balance. I should have them on the car sometime next week and will be on the track at Roebling Road on the 11th. Won't be a direct comparison cuz I will also have my Ohlins R&T on the car.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, Pagid RSL29, BM3 Stg1, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro next mods: Ohlins R&T, Vorshlag Camber Plates, SPL parts IG: Follow ME: genXg87 |
03-03-2024, 09:16 AM | #2 |
Rep 268
Interesting, report back on how they are on the track. Could be a great tire.
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
GenXG87190.50 |
