03-03-2024, 08:34 PM | #1 |
Rep 133
Drives: 2023 M2 & 2018 M2
Wow!
First the weight difference. Gotta be 20-25lbs. Second sounds great. Third I think this is what the car needed. I have a JB4 and this mid pipe really woke it up. Seat of the pants meter is like 30-40hp. Responsive and torquey too. https://www.youtube.com/watch?v=HnArbN1Q4ag Fitment was spot on. Pretty easy to install. Only gripe and it seems to be pretty common with some of the more cost effective solutions is no instructions, parts list or links to pdfs or videos. I heard about cutting at the dimples. Well there is one spot with one dimple and one with two. Cut first at the one since it was less pipe removed. Then mocked it up and realized it needed to be cut at the two dimples, about 2 inches. That was perfect.
2023 G87 ///M2 6MT - Ohlins R&T, Vorshlag Camber Plates, Fall-Line Rear Toe Arms, APEX VS-5RS, Conti Extreme Contact Force, Pagid RSL29, BM3 Stg1, IRL single mid-pipe
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro next mods: Ohlins R&T, Vorshlag Camber Plates, SPL parts IG: Follow ME: genXg87 Last edited by GenXG87; 03-03-2024 at 08:48 PM.. |
03-04-2024, 02:42 PM | #2 |
Joint Chiefs of Staff
24348
Rep 191,145
GenXG87184.50 |
03-05-2024, 08:53 PM | #3 | |
Rep 170
GenXG87184.50 |
03-05-2024, 09:34 PM | #4 |
Rep 133
Correct. Still pretty quiet. Valves closed windows up it isn’t much difference. In the throttle you notice it.
Open valves a bit more noise at cruise. No drone. More burble on lift. WOT roars a bit now.
2018 F87 ///M2 DCT - MPE, BM3 stg1, MAD Intake, xHP stg2, M4GTS Diff/Steering, Euro MDM, Ferodo 3.12, APEX VS-5RS, Potenza RE-71RS, Cobra Nogaro next mods: Ohlins R&T, Vorshlag Camber Plates, SPL parts IG: Follow ME: genXg87 |
03-05-2024, 10:44 PM | #5 |
Rep 268
Did you take this pic halfway through your Ohlins install?
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
GenXG87184.50 |
03-06-2024, 06:37 AM | #6 |
Rep 133
lol. Good eye.
03-07-2024, 05:09 PM | #8 |
Rep 31
I installed one of these last week and used a sawzall. Cut the oem exhaust and dropped the middle section. Left the muffler box on the car.
03-07-2024, 07:36 PM | #9 | |
Rep 133
You probably can't use a chain cutter with stainless pipe. I dropped the whole exhaust. It takes like 10-15 min to drop. You need two people though cuz it's pretty heavy.
mtenhoven124.00 |
04-08-2024, 06:19 PM | #11 |
Rep 170
EngineerTheVoid & GenXG87 - How low does the main pipe hang coming off the downpipes prior to the bracket on your install?
Seems lower than I expected on my install. |
04-09-2024, 05:49 AM | #12 |
Rep 618
How's the JB4 been on the G87? What settings have you been running? Lowkey interested in getting one for my car sometime in the future
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
04-09-2024, 07:44 AM | #13 | |
Rep 133
However, on a road course it's not ideal. The main issue is that it will kick-in at a certain throttle %. This can cause some issues since throttle modulation needs to be consistent. So I set it to map 0 (stock) on a road course. On the street I run map 2 on 93 and the car is a blast.
04-09-2024, 06:30 PM | #14 |
24348
Rep 191,145
It's a solid option for more power safely
GenXG87184.50 |
05-09-2024, 07:37 AM | #18 |
Rep 133
I believe 2nd. I cut at the front dimple first and I had to cut again.
xps303.00 |
05-09-2024, 09:08 AM | #20 |
Rep 133
Is it all the way in the clamps? Does not stick out and my hangars are vertical.
May need to be cut more. Or another thing is the y could be upside. Not sure if that is possible but when I was assembling I did have to double check because it looked like it could.
Chi5828.50 |
05-09-2024, 10:52 AM | #21 |
Rep 192
Drives: '23 M3
Would this effect emissions at all? Non California state.
05-09-2024, 12:53 PM | #22 |
24348
Rep 191,145
Midpipes do not trigger the check engine light, so if your state only does an OBD check, it won't set any flags.
Chi5828.50 |
