03-09-2024, 05:56 AM | #1 |
Rep 328
Notchy steering on highway
Never seems to be an issue on back roads, but on the highway when trying to make tiny steering wheel corrections is feels very notchy and not smooth, this makes it harder to make very small adjustments to keep the vehicle going straight.
(This is a 2020 with 39k miles) Basically it seems like it just wants to wander alot at highway speeds. Anyone else run into this? Steering rack? Bushings? |
03-09-2024, 07:28 AM | #2 |
Rep 321
Drives: 2014 STI - 2020 X3MC
Do you have the steering in comfort, sport, or sport+? Does it do it through all of the different steering modes?
These cars have a lot of toe in from the factory, so it could be that too. Maybe need an alignment? Last edited by joebie3; 03-09-2024 at 08:30 AM.. |
03-09-2024, 10:46 AM | #5 |
Rep 328
Pilot Sport All Season 4's. (21 inch)
I noticed the pressures were 38psi front 44psi rear. So I brought them all down to match the door sticker at 33/38. Doesn't seem quite as bad, I'm guessing its how this thing is with its fairly twitchy steering... |
03-09-2024, 01:01 PM | #7 |
Rep 75
Drives: 2023 X3MC
Totally normal but unfortunate for these cars. Also have the pilot sports and mss and does not help. I’ve read some have been able to improve it by adjusting the front toe on realignment.
03-11-2024, 10:57 AM | #10 |
Rep 208
Drives: 2024 X3M Comp
I have the same issue on my new 2024 X3MC. I feel that the suspension has something to do with it as I notice it feels it likes to rock from left to right, in doing so, it requires steering correction. I've used the Sports setting for steering which has help a bit but I still feel the side to side rocking has a lot to do with it.
03-11-2024, 07:45 PM | #11 |
Rep 502
Idk - my 2024 x3mc is a nimble sob.
I put my rear tire 265's on the front and it did exactly what you mention. Went back to the star 255's in the front and it is nimble again. I've got Eibach springs on four corners too. Happy w/ it.. |
03-12-2024, 04:59 PM | #12 |
Rep 1,932
my 2019 was quite bad on the OEM Conti6 but a lot better on Goodyear Eagle5.
as said above, these cars prone to it. It is better in sport. |
03-13-2024, 10:20 AM | #13 |
Rep 185
The alignment is very aggressive from the factory. Get it realigned and reduce the toe settings and it will be much more stable (and enjoyable IMO). I zeroed out the front toe and reduced the rear toe to the low end of the factory range. I'll see if I can find my exact settings and I'll post them here.
EDIT: Here we go. Ignore the before numbers, they installed KWs at the same time so it wasn't aligned yet. |
joebie3337.00 |
