03-12-2024, 02:48 PM | #1 |
Rep 205
Make it stop!
I keep getting this emergency call system malfunction alert. And there is no way to cancel it. It bings like every 10 seconds. What’s going on and what can I do!?
Thanks in advance! |
03-12-2024, 02:55 PM | #2 |
Rep 20,403
Could be water leakage through the fin and the TCU is bad or maybe just a dead battery. You will want to take it in to get checked.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
Tek-dad168.00 |
03-12-2024, 03:17 PM | #5 |
Rep 3,607
i had this happen to me recently, it software just needed to be reloaded. bring it to the dealer regardless. i believe it happened after an app update on the car.
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
Tek-dad168.00 |
03-12-2024, 05:39 PM | #7 |
Rep 20,403
That was good thinking, I don't recall anyone trying to submit that to their insurance.
03-12-2024, 06:33 PM | #9 |
Rep 20,403
I have seen some folks post that they ran a bead of silicone caulk around it. A few have removed the fin, cleaned everything, laid a bed of caulk and reattached the fin. I'm hesitant to do anything as I don't want to do anything that may help the problem along.
03-12-2024, 07:32 PM | #10 | |
Rep 78
03-12-2024, 08:45 PM | #11 |
Rep 3,607
https://static.nhtsa.gov/odi/tsbs/20...27571-9999.pdf
basically from start of production till jan 2022, the seal can fail. looks like they're using windshield adhesive (urethane) for the repair. i recall reading somewhere the test for the leak was to run the HVAC on max with recirc off and spray soapy water around the sharkfin. if you get bubbles, you have a leak OP, if yours is a 2024, possibly its just a software issue. this is what the fix was when mine went out (it stopped working in the middle of a rainstorm so i thought it was a leak, but it wasnt)
03-12-2024, 09:24 PM | #12 |
Rep 142
03-12-2024, 09:28 PM | #13 |
Rep 20,403
Okay, that makes sense that it wasn't insurance. It is surprising though that they covered it under CPO. They must have not considered it to be ruined by a water leak as the CPO excludes those. We have had others not have it covered.
03-12-2024, 10:07 PM | #14 | |
Rep 35
So for anyone directed here by google in the future, some insurance companies will cover the cost to fix your leaking shark fin that causes the Emergency Call System failure on your 2019-2022 BMW. |
03-12-2024, 10:41 PM | #15 | |
Rep 142
Given the other poster, looks like my insurance (USAA) would have covered it too. |
