03-17-2024, 07:27 AM | #1 |
Rep 13
MP3 files on USB-C stick
In all previous BMWs I’ve owned that had USB ports, I have put my mp3 collection on a stick and had access via the iDrive system.
I’ve had my iX1 for a couple of months and it will just not read either of the Type C sticks that I bought. One was 500GB and one was 1TB. Previously I haven’t had any trouble reading USB1 sticks. A 256GB one works perfectly in my wife’s i3. Any ideas? Thanks. |
03-17-2024, 07:54 AM | #2 |
Rep 541
Did you format the stick as xfat. I haven’t come across anything that says there is a max size GB compatible but maybe worth trying the 256gb.
andybarton3.00 |
03-17-2024, 07:56 AM | #3 | |
Rep 13
Yes. They’ve been reformatted a couple of times as ExFat and all Mac OS hidden files and folders have been removed. Sometimes the car will load a single folder (album) on the stick, other times it can’t find anything. |
03-17-2024, 08:12 AM | #4 |
Rep 541
There is a thread re this problem, have a read through see if this helps.
https://u11.bimmerpost.com/forums/sh...ght=Usb&page=2 |
andybarton3.00 |
03-17-2024, 08:56 AM | #6 |
Rep 541
Hope it sorts it out for you.
andybarton3.00 |
03-18-2024, 03:29 PM | #8 |
Rep 27
I’m using this and it works perfectly : https://www.samsung.com/us/computing...-muf-256da-am/ , so size isn't an issue. Thousands of files, two levels of folders. Using only the exploration by folders and file names.
Xdrive 30e on 11/2023.30. |
andybarton3.00 |
03-22-2024, 11:53 AM | #9 | |
Rep 13
It’s just a FAT32 drive, not an ExFat one, so that may be the difference. I’ve partitioned the SanDisk 500GB one and reformatted one half to FAT32. I’m hoping that will work too, so that I can have two drives in the car. |
03-23-2024, 10:47 AM | #10 |
Rep 11
if it helps, I bought a Lexar USB C/A drive on Amazon (128GB) and it's formatted exFat and it works flawlessly in the left USB C port (I did not try the right one). I'm guessing it's highly dependant on the make of the drive....
andybarton3.00 timesone187.50 |
03-23-2024, 10:56 AM | #11 | |
Rep 13
All very flakey… |
guppy4.50 |
04-01-2024, 06:13 AM | #12 |
Rep 13
I’ve given up with this. Three different USB sticks and still not working reliably or even at all.
With the interface disaster that is iDrive 8, and the dangerous navigation of albums when the drive did work, I’m safer without my music collection. Too late for me, but for goodness sake BMW, bring back the physical rotating knob interface and some physical buttons. Keep the lovely big screen, but think about how your customers use the interface. |
04-01-2024, 08:35 AM | #13 |
John27
23
Rep 87
I recently purchased this one. Works perfectly. https://www.amazon.co.uk/dp/B01EZ0X3...roduct_details
Good luck |
andybarton3.00 |
04-01-2024, 08:43 AM | #14 |
Rep 13
Thanks.
I can’t keep buying USB sticks though. I’ve already tried three different ones including the Samsung recommended previously. The car sometimes recognises the drive for about five minutes and then unmounts it. In all previous BMWs, they’ve been totally reliable. |
04-01-2024, 03:29 PM | #15 |
Lurker
103
Rep 186
The old system wasn't great either, it would basically memorize the stick so it didn't have to analyze contents every time. Which was great...but then if you added more stuff to it, it wouldn't update the contents until you did the 5 stick swap trick to force it to analyze again. There has to be a better way than the current or the old...
andybarton3.00 |
04-02-2024, 12:34 AM | #16 |
Rep 13
At least the old system had a hard drive that you could fill with music.
The new iDrive system is a definite backward step |
rocketman99102.50 |
