04-01-2024, 03:43 PM | #1 |
Rep 12
Catless smell
Guys who are running catless, how heavy is the smell and is it tolerable? I have ran catless on various platforms and feel like every car has been different. Curious to hear peoples takes on the G87.
04-01-2024, 07:46 PM | #4 |
Rep 3,029
04-01-2024, 09:41 PM | #6 |
Car Geek
3708
Rep 3,621
The smell depends on how accurate the tune that is applied is in handling closed-loop operation. My Caterham was delivered as a factory car in 2012 with no cat, as the specific regulations it was sold in Canada under didn’t require one.
The idle and half throttle and below operation to 5,000RPM are all closed loop and accurately hit Lambda 1.00 +/- 0.02, giving no noticeable smell. Full throttle to 8,200RPM tapers to 0.86 Lambda under open loop Alpha-N conditions (high compression naturally aspirated engine), but combustion is complete and the car is moving at speed under those conditions, so also no detectable smell. |
04-02-2024, 02:08 PM | #7 |
Joint Chiefs of Staff
24350
Rep 191,156
The smell is certainly noticeable. you will almost always get a question about it every time someone rides in the car with you or stands nearby the car when it's on idle.
04-02-2024, 05:30 PM | #8 | |
Rep 12
aerobod3707.50 |
04-02-2024, 05:32 PM | #9 |
Rep 12
Yeah, this is my concern. Not sure if it is worth it. Seems like performance isn't too impacted but I'm really adamant on a deep throaty sound. I've been looking to couple catless downpipes with either AA stainless steel single midpipe or Akropovic titanium catback. 1st world problems...
04-02-2024, 06:30 PM | #10 | |
24350
Rep 191,156
04-02-2024, 06:40 PM | #11 |
Rep 12
04-03-2024, 09:22 AM | #12 |
Rep 5,019
Are you keeping the secondary cats on the midpipe? If so you can run catless with very little smell but we also have a 200 cell option that will greatly reduce it however it will pull a little sound volume out of the equation as well..
omidpoornasir1.50 |
04-03-2024, 10:31 AM | #13 | |
24350
Rep 191,156
let us know what you end up getting
04-04-2024, 03:18 PM | #14 |
Rep 12
I have been planning for no secondary cats although ideally would like to run catless DP with full catback. Is there any way to minimize the smell of catless DP without secondaries? Would the right flash tune make this possible?
04-04-2024, 04:35 PM | #15 | |
Rep 5,019
The s58 is not the smelliest engine out there so the smell won't be unbearable by any means however there will be a smell when idling with the windows down and on. When cruising I really don't smell it much. Adding a tune would only help if the car was running slightly on the rich side to begin with. If smell is a concern keep the stock downpipes or our catted 200 cell downpipe. Alternatively you can run catless downpipes and keep your secondary cats.
omidpoornasir1.50 |
04-05-2024, 11:03 AM | #16 |
24350
Rep 191,156
the tune will not reduce the smell
omidpoornasir1.50 |
