04-09-2024, 05:46 AM | #1 |
Rep 900
Who’s installed the Rogue Engineering Short Shifter in their G87?
- How much did it increase effort?
I don’t want a stiffer shifter, but would like a shorter / more precise one. - Did any of you use the adjustability function or just take the stock setting? - Did you install the new Rogue rear mount too? Looking for some feedback on how much more shifting effort is required on this shifter. I did the SS install on my old 135i and it was not fun - I assume this is similar? Is it worse?
///M
04-11-2024, 10:24 PM | #4 |
Forced Induction Connoisseur
967
Rep 748
Drives: 23 X5MC / 23 720s
Garage List 2024 G87 M2 [0.00]
2023 Mclaren 720s [0.00] 2005 Honda S2000 [0.00] 2008 BMW M3 [0.00] 2023 BMW X5MC [0.00] 1964 Ford Mustang [0.00] 1968 Pontiac GTO [0.00] |
Mine comes on Saturday, will try and get it on before next weekend.
Oy vey, look at all these shekels
04-13-2024, 12:33 PM | #6 |
Rep 1,688
I drove one with it, it’s very short. Like half the throw of my GT4, if that. Personally I will be going for autosolutions SSK which can be configured with the same rifle bolt action but longer throw. I had 20pc on my F87, I would go for 15pc on this which I think would put the throw similar to a GT4.
04-15-2024, 11:37 PM | #7 | |
967
Rep 748
Install is on Wednesday, I should take some before/after throw videos for y'all. Have to find my protractor to measure angle too
04-16-2024, 08:51 AM | #8 | |
Rep 1,688
04-16-2024, 09:58 PM | #9 |
Rep 900
This is helpful - I don’t like super short-throw either. Nor do I like a lot of increased effort. It makes daily heavy-traffic commutes even more of a chore.
///M
04-17-2024, 08:14 PM | #10 | |
967
Rep 748
The good news: The throw is half the distance of the factory one
The bad news: The one I got either needs to be adjusted or sent back, as we can't get the ball to move and adjust the pivot point and it binds going into 5th and 6th. See video here; https://drive.google.com/file/d/1mGc...PAi6qeO9JjnEh/ Edit: Ok I looked at it a bit more, compare the length between the pivot point and the top of the rod, see attached pictures. It sits approx half an inch higher than the factory knob how it's currently configured and I can verify it binds on 3rd 5th and 6th; https://drive.google.com/file/d/14-_...W3hO3DLMNBfaH/ It seems the only remedy is to lower the ball, or go with Rouge Engineering's suggestion which as follows; Quote:
Initial quality impressions: 6/10, booger welds, doesn't fit out of the box for a $600 product shifts feel nicer when they don't bind (1 to 2) Will follow up with another post once I get it shifting correctly.
RandomBro97.50 |
04-18-2024, 07:54 AM | #11 | |
Rep 82
Would love to know what tips and tricks you might have in trying to solve the binding issue. LMK if you figured out a solution to the problems! |
04-18-2024, 02:13 PM | #12 |
967
Rep 748
I'm just gonna lower the ball. It looks like whoever was responsible for QC did not place it in quite the correct spot
04-18-2024, 02:32 PM | #13 |
Rep 69
Not trying to hijack here, but is there anything simple that can be replaced like a bushing on the shift bracket or something that will significantly stiffen the throw? I don't mind the length of it, but it just feels vague and mooshy. Would like to firm it up - similar to a Tremec T56.
Thanks! |
04-18-2024, 04:17 PM | #14 | |
967
Rep 748
04-18-2024, 05:15 PM | #15 |
Rep 69
Thanks. If anyone has installed just the rear bushing, could you please give your input as to how it changed the shift feel, if at all.
04-20-2024, 03:04 PM | #16 |
Rep 82
Rogue SS kit and bracket installed, also did CDV delete.
Night and day difference in terms of shifting feel, engagement and clutch modulation. Car drives MUCH better than stock. No binding or issues whatsoever during install. Highly recommend the kit and CDV removal combo |
BroDoze257.50 |
04-20-2024, 03:16 PM | #17 | |
967
Rep 748
04-20-2024, 03:24 PM | #18 | |
Rep 82
In hinde sight I would have preferred it to be a bit lower tbh. But it's good enough for now. I already can shift 2x as fast as before, without worrying of being locked out or grabbing the wrong gear due to vagueness of OEM shifter bracket. It ALMOST shifts as well as my old integra type S. Not as mechanical feeling as the ITS BUT 90% of the way there. |
04-20-2024, 06:09 PM | #19 |
Rep 18,747
Here is my IG reel on the kit that I’ve installed to my local customer’s M2.
https://www.instagram.com/reel/CyPaj...RlODBiNWFlZA== He changed to CAE a few months later. https://www.instagram.com/reel/C4OJq...RlODBiNWFlZA==
04-20-2024, 06:46 PM | #20 |
Rep 63
Is it accurate that we need to drop the transmission in order to do the install? I've read a few reviews of the different shifter options, and it's keeping me from jumping in with both feet.
Thanks in advance! |
r33_RGSport13033.50 |
04-20-2024, 07:08 PM | #21 | |
Rep 18,747
Just need to lower it a bit.
04-20-2024, 10:12 PM | #22 |
Rep 63
