04-11-2024, 09:08 AM | #1 |
Rep 3,214
Intermittent slow leak in tire??
I know how crazy this sounds, but I have been experiencing an intermittent slow air leak in one of my tires. It's been going on for about six weeks now. Over the course of five days, I'll lose up to 10 psi in the tire. I fill it up with air and then go five or six days without losing any air.
I brought it to a reputable tire shop that I have good experience with, and they couldn't find a leak - from the tire, valve stem or wheel. I've checked tire pressure several different ways and they all match to within a couple psi as is the norm. This is all crazy to me. I'm going back to the tire shop later today, but I was hoping someone out there may have an idea of what's going on.
CURRENT: '24 M4C Conv
RETIRED : '23 M8C Conv | '20 X4 M40i | '18 M4 6MT | '13 M5 6MT | '08 550i 6MT | '04 545i 6MT | '98 540i 6MT | '94 530i 5MT | '84 528e 5MT Other retirees from Chevrolet, Buick, Subaru, Honda, Acura, Merkur(!), Volvo, Saab, Audi and Porsche |
04-11-2024, 09:19 AM | #2 |
Rep 1,085
Inflate to 45PSI and dunk the wheel in the kiddie pool. You’ll find it. Chances are good it’s a puncture where a small nail got into the tread and just barely punctured the belts and then got flung out and left behind a very small hole or slit. Have you actually taken the wheel off yourself to look? I had one like this… basically had to poke a hole to patch it, it was that small, but I found it.
Take the wheel off and inspect the tread closely all around the contact patch. If you see any imperfections, spray it with soapy water or a little spit and check for bubbles. |
mathys215.00 Bimmerfun827638.00 |
04-11-2024, 09:30 AM | #3 | |
Rep 3,214
btw, I suspect there's a small finishing nail of some sort in there. But it's been the on-again off-again nature of the leak that's so perplexing. And yes, I know it sounds like I don't know what I'm talking about.
04-11-2024, 09:46 AM | #4 |
Rep 25
I have a summer tire like this currently. Inflate to 33, then over a week its down to 27 and holds there. When I swapped to winters I went over the tire with a fine tooth comb and found a broken nail wedged in the depths between the tread blocks. The hole is there, you just haven't found it yet. The pool trick is a good idea, but it may not leak until pressure is applied in just the wrong spot.
hinckley3492.50 |
04-11-2024, 10:00 AM | #5 |
Rep 16
I had something weird happen with my G80 where if I tightened the factory wheel stem cap all the way (finger tight) the tire would start losing air. If I don't tighten the cap all the way my tire holds pressure steady without any issues. Not sure if this is happening with you but you might want to check.
I'm having the dealer look at what's going on with my tire later this week. |
hinckley3492.50 |
04-11-2024, 10:08 AM | #6 |
Rep 652
Stem
hinckley3492.50 StreetLethal44.00 |
04-11-2024, 10:55 AM | #7 | |
Rep 195
Drives: BMW Z4 M40, BMW M4C
Garage List All but Jeep & ... [10.00]
2023 Jeep Wrangler ... [10.00] 1965 COBRA (FFR) [10.00] 1998 FORD Ranger 4X4 [10.00] 2022 BMW M4C [10.00] 2020 Z4 M40i [9.50] 2023 Ford Expeditio ... [10.00] 2009 Yamaha V-Star [10.00] |
04-11-2024, 12:21 PM | #8 | |
Rep 796
hinckley3492.50 |
04-13-2024, 08:09 PM | #9 | |
Rep 803
04-14-2024, 09:24 AM | #10 |
Rep 2,045
I think the air leak is prob coming from the stem or there is prob a hole thats too small that when its not on the car and under no weight, its sealed and so the water test isnt helping. But once you put it on the car, the weight of the car is able to expand the hole/cut and air starts leaking out. Either ways, if the tire shop doesnt find any issues, have them first replace the valve stem and if that doesnt work then might have to replace the tire or tires depending on the thread dept of the other tire
BimmerFix1453.50 |
