04-11-2024, 04:16 PM | #1 |
Rep 3,034
Drives: 2019 M2 Competition
Upgrading the heat exchanger - fully detailed DIY
All right yall, if you are going to upgrade your charge air cooling system, then you need to upgrade the heat exchanger as well! I saw many S55s (previous M motor) cars with JUST the charge cooler upgraded. While it was a visual upgrade, you weren't getting the full effect without the matching radiator to go with it.
The S58 is no different, that you should upgrade the radiator (heat exchanger) as well, and this might be a hint for the next upcoming project as well. Check out the excellent CSF Radiators heat exchanger from Kies Motorsports and let me walk you through the whole upgrade so you can do it too.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
04-11-2024, 10:22 PM | #2 |
Forced Induction Connoisseur
967
Rep 748
Drives: 23 X5MC / 23 720s
Garage List 2024 G87 M2 [0.00]
2023 Mclaren 720s [0.00] 2005 Honda S2000 [0.00] 2008 BMW M3 [0.00] 2023 BMW X5MC [0.00] 1964 Ford Mustang [0.00] 1968 Pontiac GTO [0.00] |
If this is your video why didn't you bother to track and provide data on the improvement to cooling with some temperature probes? Hell you could of even datalogged it.
How is one to know if this is actually worth anything?
Oy vey, look at all these shekels
Chi5828.50 TheirThere76.00 |
04-11-2024, 11:04 PM | #3 |
Rep 3,034
Because this is an install video friend, not track time or data logging. It was long enough as is.
04-11-2024, 11:56 PM | #4 |
967
Rep 748
So you have no idea of the efficacy of the part you installed?
Edit: To be clear, I live in hot AZ and intend to track. Would of loved if you at least plugged in an OBD scanner and documented the differences. Maybe something like this for your next cooling upgrade?
