2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum LCI Cupholders Retrofit DIY Guide
      04-23-2024, 10:13 AM   #1
Fraysa
Drives: BMW M235i
Introduction
I recently stumbled upon a rather old thread by pochetemix explaining how to retrofit the LCI cupholders on the F22 (here). This looked like quite a cool retrofit, as the new cupholders come with a lid to cover them, and as someone who rarely drinks anything in his car, keeping the lid closed provides me with a better feeling in the interior overall and reduces clutter.
Unfortunately, the guide is not so depth, doesn't go into important details or provide a lot of pictures of the process, so I decided to create an in-depth one while I was retrofitting mine. My car came with the folding tray at the back of the cupholders. I found this tray completely useless as you can't fit anything there, and I really liked the "flat" tray in the newer center console.
Vehicle used in this guide
2016 BMW M235i (F22) with ZF8 transmission
Vehicles that this guide is applicable to
Any pre-LCI BMW F20/1/2/3.
Parts required
  • 51166993607 - Center console trim with cup holder (est. cost 100$ USD)
Fitting
1. Remove the iDrive knob trim. For this you'll need to put a pry tool between its panel and the panel under it and just pull up slowly as you'll feel the clips releasing. After removing the trim, disconnect the harness connected to it by simply pulling it, there is no retaining tab. There are a ton of videos online showing how to achieve this, so I won't go into details here.
2. Remove the shift lever surrounding trim. This can also be done by using a pry tool, and comes rather easy.
3. Remove the drive mode buttons and their trim. This can be done by simply putting your finger under them, using the free space from the shift lever. If you've never taken this part before, it may be a bit hard but you can use both your finger and a pry tool. Make sure to remove the top part first and then slowly release it. After removing the buttons assembly, disconnect the harness connected to it by pulling.
4. Remove the only T-20 screw holding the cupholders, and slowly prying the whole piece up and towards you, until it comes apart. The screw is marked in yellow in the picture below.
5. This step is optional. For some odd reason, my assembly came out without the cupholders - they were separate parts. Because of that, there was another T-20 screw holding them in place. The new cupholders do not have this, so this screw is irrelevant when reinstalling, but it had to be removed in order to pull the old cupholders. Said screw is marked in yellow.
6. While removing the cupholders, disconnect the cigarette lighter socket connector by pulling it. In addition, disconnect the small connector from the keyless entry antenna located in the back of the cupholders - there is a small clip that's holding the connector that needs to be released in order to release the connector.
7. Remove the keyless entry antenna from the back of the cupholders by removing yet another T-20 screw, marked in yellow.
8. Now that's everything removed, you'll need to remove a small plastic clip that'll prevent you from installing the new cupholders. I'm not entirely sure why BMW decided to get rid of it, but the new cupholders simply won't fit with it in place. I simply used a cutter and filed it down gently so it's flush.
9. Reinstall the keyless entry antenna in the new cupholders.
10. Move the old cigarette lighter socket from the old cupholders to the new assembly.
11. Install everything in reverse order, making sure not to forget to connect any harness.
Results
This retrofit was looking rather easy from the guide by pochetemix, but as with all retrofits - when you actually come to tackle it, you find out that everything's not so easy, hence why I created this guide.
... and for the final result (sharp-eyed people will notice that I'm missing the rubber mat in the new assembly, for some reason mine came without it even though it should have. I ordered a new one):
Good luck and feel free to ask any questions!
Fraysa.
Dom147102.50
John in VA1002.00
      04-23-2024, 10:44 AM   #2
Dom147
Drives: 2014 BMW 228i, 2017 BMW M240i
2017 BMW M240i  [0.00]
Awesome guide! I didn't even know the LCI models had different cup holders!
      04-27-2024, 01:01 PM   #3
Cosworth
Drives: 2017 230i xDrive
Nice write up. Thanks for sharing. Definitely like the cleaner look with cup holder cover.
Had been toying with the idea of this mod for a while, your post has got me off my a$$ and I ordered an LCI unit of eBay last night.
Might go ahead and add the BimmerTech wireless charger while I'm at it.
Appreciate the details and tips!
      05-03-2024, 02:59 AM   #4
DS_BMW88
Sweden
21
Drives: BMW 218i Coupe
Thanks for the write up. Mine didn't came with any cover at all. Seeing that there is even an option to get one covering the cupholders is even better! Mine do get a bit dirty and dusty overtime as it was never covered. Do you know if the cup holder inserts can be still used?
      05-03-2024, 05:38 AM   #5
leftoverture
leftoverture's Avatar
Drives: 2016 BMW 228i
Nice write up. I use my cup holders so much I would never close the cover any way, so I'm happy with the way my car came, but your write up was first rate and will be helpful for all those who want to make the change, or who need to disassemble their console for other purposes.
2addicts
