04-23-2024, 10:47 PM | #1 |
Riding BMWs since 1976
170
Rep 597
Tire wear measurement
I understand how tire pressure can be monitored and estimated, but how does the X1 monitor and assess tire wear?
2024 X1 xDrive28i (Space Silver), 2014 BMW X1 (E84) (sold), 2010 MINI Cooper S Clubman, 2011 BMW R1200GS Motorcycle and various BMW motorcycles since 1976
04-24-2024, 02:39 AM | #2 |
Rep 940
Drives: BMW iX1, U11
04-24-2024, 03:28 AM | #4 | |
Rep 940
Specific to the tire wear; in Europe, we don’t even get this in the app or car. |
04-24-2024, 08:15 AM | #5 |
BMW Owner
138
Rep 449
Drives: 2024 BMW X1 28i
What myBMW app do you have? I’m in USA with 3/2024.30 & does not show tire wear.
04-24-2024, 08:32 AM | #6 |
Rep 278
I’m UK based with a UK spec car and the app shows Tyre Wear. Go to Check Status/Tyre Condition/View All on the app.
Mind I think as others have said a fairly useless bit of information- far better and safer to inspect your tyres occasionally for any damage and wear. |
04-24-2024, 10:05 AM | #7 |
Rep 88
I actually read about this a while back. Teslas have software that use the ABS sensor to count the revolutions of the tires... as tires wear down, the revolutions change. The software uses that to determine the wear. I can't imagine that such method is proprietary because I remember reading about that on a Mercedes before.
https://driveteslacanada.ca/software...pth-heres-how/ |
04-24-2024, 11:25 AM | #8 |
Rep 1,992
As above this isn't useless as some state. Its a help that could indicate if an individual tyre or likely set have much more wear than the rest.
So in a FWD or RWD car only it could point towards lots of hard starts and excessive wear vs the other axle that has very little. Using the ABS sensors to detect the amount of rotation does this fairly easily. For 4wd its often slightly harder to see a big difference but ironically I checked the tyres on my X3 and the rears are wearing faster than the fronts probably due to the rear bias in the setup, the opposite is probably true of ICE X1s. |
04-24-2024, 12:06 PM | #9 | |
Rep 88
04-24-2024, 08:16 PM | #10 |
170
Rep 597
App version is 4.3.2 and vehicle software is 3/2024.30 USA
04-25-2024, 11:41 AM | #11 |
BMW Owner
138
Rep 449
I don’t get BMW apps?? I have the same update & software as you mentioned & yet I don’t have ability to see tire wear. WHY?? I’m in New York & you’re in Florida (both east coast)
Does BMW really rollout these changes in very specific markets before other markets? This is my first BMW so I’m puzzled by such inconsistencies. From someone who has experienced this from BMW previously, what am I missing? |
04-25-2024, 01:09 PM | #12 | |
Rep 271
04-25-2024, 02:58 PM | #13 |
BMW Owner
138
Rep 449
😜 CRAZY!
Now I’m even more confused by BMW’s updates. I’ve tripled checked & I have the same software 3/2024.30 & 4.3.2 MyBMW update & don’t have either the tire wear or ability to add the tire manufacturer. (Unless there’s a setting I missed in the x1) I have the 28i with ID9. Is it possible the features are only available on the M35i? |
04-25-2024, 04:55 PM | #14 | |
170
Rep 597
The only thing I can think of is if you haven't run the app in ID9 to calibrate/recognize ((not exact wording) the tires. If you have, perhaps try a reboot or call Genius.
markronnie138.00 |
04-25-2024, 07:54 PM | #15 |
I Shoot People For Money
1222
Rep 2,135
Drives: 2023 Portimao MSport X1
I'm on the most current version of the app and iOS and can't see tire wear, but I do have ID8 and an early production model (9/22). It does note that I am not using BMW star marked tires though, which I'm not.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
04-26-2024, 08:18 AM | #16 |
BMW Owner
138
Rep 449
I can’t see any way to update tires in X1 or in app. I don’t see amount tire wear. I’ll call BMW Genius & see if they can enlighten me.
04-26-2024, 03:37 PM | #17 |
Rep 30
I just had the 10k service performed and placed the anti-theft socket on the passenger seat but apparently tire rotation is not part of the service after checking from my dealer. Immediately doing a quick search to better understand, there’re a lot of BMW dealers that don’t recommend scheduled rotation for fwd xdrive vehicles. I plan to do it myself now.
markronnie138.00 |
04-26-2024, 04:36 PM | #18 | |
170
Rep 597
Mine are Turanzas.
04-26-2024, 06:46 PM | #19 |
BMW Owner
138
Rep 449
I have the BRIDGESTONE TURANZA LS100A as well. The PSI has always been displayed properly with X1 as well as the MyBMW App. The tire wear has never displayed.
I don’t recall setting up “special approval” tire procedure reset before. (The dealer may have) If you think by following the procedure you noted it will capture what the ID9 needs to determine tire wear I’ll give it a try. |
04-26-2024, 06:55 PM | #20 |
170
Rep 597
There's no harm in trying.
markronnie138.00 |
04-27-2024, 08:10 AM | #21 | |
Rep 88
I knew that tire rotation was not included in the free BMW oil change for the first three years. I asked the dealer to do it because they only charged $52(after tax). They rebalanced all fore tires and did the front-to-rear rotation.(left front to left rear, right front to right rear and vice versa) My local tire shops or even Costco charge about the same when tires are not purchased from them. Even if Costco does it for me for free, I'm sure I can easily spend a couple hundred bucks inside while waiting for them to rotate the tires. Letting the BMW dealer do it at the same time saved me time for only a few bucks more. I can do it myself, but I'm too lazy these days. My torque wrench broke last year and I didn't feel like spending $140 to buy another one. FWD cars like the xDrive X1 drive on the front wheels 99% of the time. The front tires will no doubt wear faster than the rear tires, so rotation is definitely needed in order to even out the wear. Last edited by Petroleum; 04-27-2024 at 08:30 AM.. |
markronnie138.00 |
04-27-2024, 08:30 AM | #22 | |
1222
Rep 2,135
Personally, I like to rotate my own wheels, as it allows me to give them a deep clean and coating before mounting them again. I just check to see if there's any wheel weights that have fallen off and get them rebalanced only if I notice one missing.
