Air cold side diagram - 30ff intermittent code
05-01-2024, 05:07 AM | #1 |
27
Rep 180
Does anyone have a line diagram for the engine cold side where the air box and charge pipe is? I have an intermittent 30ff code boost not meeting target. It happens randomly and the target would be 16.5 but it will only hit 13.5psi. Other times it gets 16.5-16.7psi.
I replaced the ofhg and disconnected three vacuum lines (#5,#6 and another going around the air box which I think goes to brake booster?) and the rear diverter valve. This has likely caused the issue and a diagram would help before I think of fixing a pinched intake manifold gasket. On realoem I could only find the hot side vacuum lines. |
05-06-2024, 03:04 PM | #4 |
27
Rep 180
I think I left this unlocked. After turning it to the opposite position, the car has stopped throwing a 30ff shadow code. Don’t know why it works if all it does is route bypassed air back to intake.
