05-01-2024, 03:30 PM | #1 |
![]() 10
Rep 55
can you put run flat tires on 2024 X1?
this question may have an obvious answer but I am having a hard time finding it here.
I have a U11 M Sport on order that should be arriving within the next 3 weeks. this is my first car in 9 years without run flat tires. I would rather pay $500 a tire and have the sense of security having run flats on my car and not have to go through the trouble of being on the side of the road and wait for AAA to come help change a tire. I am also becoming limited w the range of mobility in my arms and cannot change a tire. since the U11 comes with non run flat tires, is the car equipped to have run flats put on without any issues? will the car automatically detect RFTs are on the car, or will the settings need to be changed? |
05-01-2024, 03:46 PM | #2 |
![]() 1680
Rep 2,028
From my understanding your issue will be the rims, run flat tyres from memory need an extra bump inside that standard wheels mostly don’t have. This is to help keep the tyre from slipping inside if it deflates.
Settings in the car you won’t need but the ride will become much firmer, cars designed or run flats often have different suspension settings to limit the firmer sidewalls that run flats have. So yes you can do it but would need new wheels, and tyres and face the firmer ride. Or ask yourself when was the last time you had a flat and is the switch worthy the hassle? In the EU now rarely do and spare tyres get provided anymore for weight saving. |
BMWZ41929.00 |
05-01-2024, 05:29 PM | #3 |
![]() 42
Rep 119
I mean I can understand him.
I had blown tire twice. One in my E87 and one in my F20. Both were runflats and tbh I didnt even realise I had a bad tire. The warning just came in. I remember the first time in my E87 stopping the car and circling the car and kicking the tires to find out after some time which tire had lost pressure. I also remember driving unstressed to the tire shop. For me the firmer/noisier drive is worth it for these bad tire days. |
05-01-2024, 09:06 PM | #4 | |
![]() 10
Rep 55
I'm in NY and I have to drive 20 miles on uneven back roads for my commute. seeing a blown tire on the side of the road is one of the scariest things, it's like someone stuck a stick of dynamite inside to blow it up and now your wheel is destroyed. I never realised the loud road noise was from the RFTs and tbh it doesn't bother me bc I'm so used to it after 9 years. I am small and only 100 lbs. and I do not have the core or limb strength to physically change a tire. I will talk to the dealership when I get my new car. and if it comes down to it and I have to order different wheels for run flats, it's worth it. |
05-01-2024, 09:53 PM | #5 |
Riding BMWs since 1976
178
Rep 621
I'm planning to change to RFTs when the OEM tires wear out. According to this web site, no special rims are needed.
https://www.tires-easy.com/blog/run-...how-they-work/
2024 X1 xDrive28i (Space Silver), 2014 BMW X1 (E84) (sold), 2010 MINI Cooper S Clubman, 2011 BMW R1200GS Motorcycle and various BMW motorcycles since 1976
05-02-2024, 04:16 AM | #6 |
I Shoot People For Money
1269
Rep 2,177
Drives: 2023 Portimao MSport X1
Another option would be a tire plug kit. I've been using them for years in place of a spare tire, and have run the tires to the limit with the plugs in the tread. With proper technique, you can plug a tire in less time than it takes to break the lug nuts free changing a spare. If your mobility is too limited though, I can see that being an issue.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
BMWZ41929.00 |
05-02-2024, 08:29 AM | #8 |
![]() ![]() 1929
Rep 5,115
You'll may end up regretting the RF's. I had them on my first 5 bmw's because my wife & I spent quite a bit of time on long highway drives every month & didn't want to get stuck along the way (even with the available roadside assistance). In any case, a few reasons I stopped buying RF's:
1. Cost 2. Don't last as long 3. Harsh ride, given the already stiff suspension nature of bmw's 4. When the tread starts to wear down, the added road noise is obvious on highway drives 5. Having to buy winter RF's was painful as well Edit: All/most bmw's now come with pumps/goo to blast into the tire to temporarily plug most holes. I've had the pump included in my last 4 vehicles. If not, you can buy them from the dealer. I think they're about ~$150CAD
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
05-02-2024, 08:32 AM | #9 | |
![]() ![]() 2555
Rep 4,701
Drives: '23 X1 28i xDrive
05-02-2024, 08:33 AM | #10 | |
![]() ![]() 2555
Rep 4,701
05-02-2024, 10:02 AM | #12 | |
![]() ![]() 2555
Rep 4,701
https://en.wikipedia.org/wiki/Michelin_PAX_System |
05-02-2024, 10:28 AM | #13 |
![]() 31
Rep 88
I was considering the X3 previously. The ride was so harsh even with the base model on runflat tires. Yes, I drove it on the same bad roads that I'm driving with my X1 right now. I know at least two X3 drivers who switched from runflat to regular tires becasue of this.
BMWZ41929.00 |
05-02-2024, 03:52 PM | #14 | ||
![]() 10
Rep 55
05-02-2024, 05:20 PM | #15 |
1269
Rep 2,177
Every BMW lease I had, upon return, the tires just had to be the correct size and speed rating. Other than that, it just had to have the minimum tread depth. This was also confirmed to me by a good friend who used to be a technician there.
