05-07-2024, 01:31 PM | #1 |
Rep 22
Is BimmerCode app a scam?
Recently purchased the BimmerCode app and a Veepeak ODB bluetooth reader. I tried to disable the auto start stop function and it didn't work. I then tried to enable the drive mode memory so that it would remember the last driving mode I was in at the next start up. That didn't work either. This is for a 2022 X7 40i. Anyone have success with this? Feeling kind of ripped off right now. Or am doing something wrong.
05-07-2024, 01:37 PM | #2 |
Rep 3,607
wrong obd reader. the veepeak only supports coding up to the F series chassis.
i would do ethernet cable, the bluetooth dongles are super slow. see here: https://bimmercode.app/adapters/ under each adapter it tells you what series is supported. X7 is a G chassis
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
DaMoose3.00 |
05-07-2024, 01:53 PM | #3 | |
Rep 22
05-07-2024, 02:15 PM | #4 |
Rep 22
When I was using the Veepeak obd reader, the app did say some of the functions were not available with that obd reader. But the auto start stop was not one of them and it allowed me to go through the coding process. Just didn't change anything when I tried starting and driving the car, even though it said it was successful with the coding, nothing changed. I'm not having much confidence it will work even with the new OBD dongle. Will see.
05-07-2024, 02:57 PM | #5 |
Rep 3,607
depending on your current software level, disabling start stop might not be possible. my X7 is an LCI and not codeable. when i had my G01, i coded my default drive mode to sport individual and then set the modes there for drivetrain and suspension.
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC Last edited by Orient330iNYC; 05-07-2024 at 03:03 PM.. |
DaMoose3.00 |
05-07-2024, 02:59 PM | #6 |
Rep 398
Check your vehicle software version. BMW took the ability to disable Auto Start/Stop above version 03/2023.50. You can still code the default drive mode at startup, so if you select Sport or Sport Individual, then ASS is disabled in these modes anyway - that's the workaround.
05-07-2024, 03:11 PM | #7 | |
Rep 22
05-07-2024, 03:33 PM | #8 |
Rep 3,607
BDC can only be coded with the odblink adapters (i have the MX). i had one of the cheaper dongles from my F platform car and couldnt code BDC on my g01.the MX could but be warned it is slow. ethernet is much faster and much more stable.
Default driving mode The standard driving mode that is activated when the car is started. Values: ADAPTIVE COMFORT COMFORT INDIVIDUAL COMFORT+ ECO PRO ECO PRO INDIVIDUAL ECO PRO+ ELECTRIC ELECTRIC INDIVIDUAL HYBRID HYBRID ECO SPORT SPORT (Hybrid) SPORT INDIVIDUAL SPORT INDIVIDUAL (Hybrid) Requirements: “Body Domain Controller” BDC_BODY3 control unit
DaMoose3.00 |
05-07-2024, 07:57 PM | #9 | |
Rep 22
05-07-2024, 10:18 PM | #10 |
Rep 22
My OBDLink CX arrived. Amazon is crazy fast. I ordered it earlier today and a few hours later its delivered.
Anyway, I went out and tried it. I changed the default driving mode to Sport Individual and it seems to be working correctly. Thanks to everyone for your help and to Orient33iNYC for directing me in the right direction. Also, now since I have the bimmercode app and the OBDLink CX adapter, is there any other things or settings you guys would recommend I should consider changing? I disabled the seatbelt chimes. But I'm open to any other suggestions if you guys have any. |
05-08-2024, 04:15 PM | #11 |
Rep 7,586
Why not just go down the list of coding parameters and select the ones that YOU would like?
Just click this link below to go directly to all of the coding parameters for the BMW G07 X7 (pre LCI)...click on the heading (they are in alphabetical order) and you can see what can be coded and it also tells you which module the coding can be found...and some of them have additional links for what adapter you need to do the coding: https://bimmercode.app/cars/g07/ Make a list and jot down which ones that suit what you would like to code...then you can go to that module and select.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
admranger2999.50 |
05-08-2024, 09:15 PM | #12 | |
Rep 22
05-09-2024, 05:19 PM | #13 | |
Rep 7,586
You can select the "codings" you want...then do all of the ones that are associated with the same control module and bang them all out. Then, as you mentioned, if the time is starting to get long, you can stop to prevent depleting your battery...and come back later to do more. Or you may find you only want to do a few, and you can line them up and do the "coding" and again, you're done. This can also give you a "diary" to go back to if you decide later that you don't care for the coding & you want to go back to the default or select another coding parameter if there were multiple selections to chose from. You can quickly go back in and make the change using your diary.
DaMoose3.00 |
