BIMMERPOST Universal Forums General BMW News and Cars Discussion Lowering Spring + Spacer Installation: Am I being overcharged?
      09-30-2024, 11:13 PM   #1
brianx42
Drives: BMW M340
Hey everyone,
I recently received an estimate from an auto shop for some work on my 2023 BMW M3, and I’m concerned that I might be getting overcharged. Here’s the breakdown from the estimate:
Services and Parts Charged:
• Labor: 8.8 hours @ $140/hour = $1,232
• This includes installing Eibach Lowering Springs and a Spacer Kit.
• Parts:
• Eibach PRO-KIT: $350
• Bimmerworld 12mm/15mm Wheel Spacer & Bolt Kits: $300
• 4-Wheel Alignment: $225
The subtotal came to $2,107.00, and with an 8.25% tax, the total is $2,160.63.
My Concern:
The shop mentioned in an email that they “rolled the wheel spacer and bolt kits into the labor cost for the spring install,” which makes me think the labor cost for installing the wheel spacer was already included in the $1,232 charge. However, they also charged me an additional $300 for the Bimmerworld Spacer & Bolt Kits, which I understand is the part cost.
Am I potentially being double-charged for labor here? Shouldn’t the $1,232 cover both the spring and spacer installation, and the $300 just be for the part itself? It feels like I’m paying twice for the labor involved with installing the spacers.
Would really appreciate some feedback. Has anyone else experienced something similar? Am I overthinking this, or should I push back on the shop for clarification? Thanks!
      09-30-2024, 11:28 PM   #2
BlkGS
BlkGS's Avatar
3542
Drives: BMW X5 M50i
If you can't do the work yourself, then you're not being overcharged for anything.
I wouldn't pay that much for a set of springs and some spacers, but I can do work myself. I'm not sure your concern. The $1200 labor is to install springs, spacers, and the bolt kit. Then you've got part costs. Theyre not gonna give you a discount on the parts so this sounds about right.
2 hours per corner for a spring install seems a bit long to me, but it's not totally out of the question for a car that's got so much crap packed in so tightly like an M3. Also, $140 an hour is pretty cheap, so I'd be a little leery of that.
      09-30-2024, 11:42 PM   #3
Drewbkm4
Drives: 2017 bmw m4 zcp
That definitely doesn’t take 8.8hrs to do, you got robbed bro.
Spaxe24.50
xander_g1077.00
      10-01-2024, 12:13 AM   #4
Spaxe
Drives: 17' BMW 440i, 22' Accord
Agreed, I paid around 400 for the springs and spacers... parts were mine
      10-01-2024, 09:28 AM   #5
pikkagtr
Go Spurs Go
pikkagtr's Avatar
3998
Drives: '22 GR Z4 Coup '06 Z4M Rdster
Rear springs take about 20 mins each side
Front springs around 30 mins each side
The bolts take zero time as they just take your own bolts off and put the other ones back in it's place.
The spacer kits take 15 seconds to put on
Alignment is fair priced
      10-01-2024, 11:51 AM   #6
pnwwagon
Drives: 2019 F31 AW MSport
I got multiple quotes from various shops around my area and your quote is largely in line with what I found. 9 hrs of labor is a bit higher than I was quoted, but pretty close. Labor rates are a bit higher up here for me, too, so that balances out (PNW).
I've changed springs myself before on my e46 m3 when I had it and it was only a mild pain for someone relatively inexperienced like me, but I opted to pay this time (partly because I no longer have space to work).
For folks claiming a few hundred bucks for this it'd be nice to see the quote from the shop with the breakdown.
      10-01-2024, 12:06 PM   #7
Hit_Apex
Riding the knock sensor
Hit_Apex's Avatar
3093
Drives: 21 X5MC | 23 M4CSL
2021 BMW X5MC  [10.00]
Most high volume shops use one-size-fits-most flat rate guides for labor hours per their policy. Other more enthusiast oriented tuner shops familiar with the exact parts and car model have done it enough that they can undercut the guide, often substantially, and usually have more capacity/willingness to win the job. As always, it pays to shop around.
      10-01-2024, 12:09 PM   #8
ZL9M2
Drives: '17 M2 ZL9-'20 M2CS-'68 1600
In the end if you don't do it yourself the price is the price. If you don't like the quote then quote it somewhere else and decide who you would like to work with.
      10-01-2024, 12:17 PM   #9
erickonphoenix
erickonphoenix's Avatar
2085
Drives: 2014 Gray 328xi Touring
I seem to recall the book time on a suspension refresh (which is basically what this is) was around 8 hours. However, I could do it in half the time but the alignment was done off site.
btw, the goal was always to try and get a straight service in under the book time. The owner needed to bank that surplus to cover time lost on diagnostics or other unseen issues.
Also, whenever you're getting aftermarket work done on a high end car you're exposed to over charging. Shop the work around reputable shops and see what you can get.
      10-01-2024, 12:19 PM   #10
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
This is why I hate dealing with shops lmao and just do it myself. God damn
      10-01-2024, 12:26 PM   #11
Gemini562
Drives: E90
I’d be a little skeptical too. 8.8 hours for springs and spacers is on the high side. Realistically, it should take around 6 hours, maybe a bit more, but not that much. The parts prices look fine, though. I’d push back and ask them to explain the labor, or check with another shop to compare.
      10-01-2024, 12:30 PM   #12
Drewbkm4
Yea most of them exaggerate on the hours. I’ve never seen a shop that allows a tech to spend their entire workday on putting on a set of springs lol
