10-11-2024, 03:36 AM | #1 |
Rep 70
Transmission issue or just typical DCT behavior?
I wanted to ask fellow i28 owners if they've and/or are currently experiencing this with this SUV:
Any time I come to stop and I'm about to take off again, I press on the gas, the engine revs, making you think you'll take off but nothing happens for a few seconds and then there's a substantial jerking motion as the clutch finally seems to engage. This makes trying to have a nice smooth ride virtually impossible. It happens all the time and is consistent. I drive in "personal mode" and haven't tried sports mode but I don't really want to do that since I feel SM keeps the gears way to high for too long for day to day driving. It drives fine the rest of the time. I find it's even worse the first few stops in the morning but is always there. Anyways, I was curious if this is just how DCT works or if I'm experiencing something that's not normal. I was planning on asking my dealership soon about it. Out of all the annoyances I've had with this SUV, this is by far the most enjoyment sapping one. :-( |
10-11-2024, 05:11 AM | #2 |
Rep 1,992
Give the forum a search, very common problem for the US models that don't have the Mild Hybrid solution in most other geographies.
It's an issue with the clutch engagement really rather than anything throttle related it seems, long standing element that so work around, others hate and sell the car other barely notice it with there driving style. |
10-11-2024, 05:22 AM | #3 |
John27
Rep 130
As MontyB1 says, doesn't seem to be a problem on the UK version of the X1 with mild-hydrid power-trains. However, many VW owners with dual clutch transmissions have reported the same issue.
For VW's, the reason apparently is to help the car meet emission standards and I assume, this is the same for BMW? Putting the car in sport mode should largely remove the issue but an alternative to consider is perhaps fitting a pedal box such as https://www.pedalbox.com/en/bmw/x1-u.../pedalbox.html I am not recommending this pedal box (as I've never used it) but a number of people on the VW Tiguan forum have reported good results using this item. Undoubtedly, the same or similar product will be available in Canada? Just an option to consider if you can't live with this - certainly cheaper than changing the car. |
10-11-2024, 07:18 AM | #4 |
BMW Owner
138
Rep 449
Drives: 2024 BMW X1 28i
As mentioned in several threads the FTC married to the Auto Start Stop function in the new generation x1 & x2 in North America, with the ICE engine, is an issue for the reasons you’ve experienced. Some say it’s gotten a little better with recent 07/2024.40 software update.
Personally I got in the habit early on to deactivate the engine’s Auto Start Stop function when I start out so I have not experienced the problem. There are several methods to “DISENGAGE “ the function. If you like you can do so even before starting the engine. That’s what I’ve been doing since I picked up my 2024 in late December 2023. BTW: if you like the slightly stiffer steering while in SPORT MODE but do not like the way the gears shift you can set up the Transmission to Normal & leave the other settings as sport. If you do this once, each time you put it in SPORT, thatwill be the setting. You’ll still need to “DEACTIVATE” the Auto Start Stop function. Last edited by markronnie; 10-11-2024 at 07:46 AM.. |
10-11-2024, 11:15 AM | #5 |
Rep 70
Thanks for the replies and suggestions.
I totally forgot to mention that I ALWAYS disable the auto start/stop feature when I get into the car. This is something else outside of the start/stop stuff. |
10-12-2024, 03:17 AM | #7 |
John27
Rep 130
10-12-2024, 02:31 PM | #8 |
Newguy
Rep 17
Mine has always done the same. There’s the auto start stop delay, then when the engine turns back on, a transmission delay. Dealer says this is normal.
I think it’s bad programming, not a faulty transmission. Running in sport mode, the transmission engages flawlessly |
11-22-2024, 04:40 PM | #10 |
Rep 2
Grabby transmission at cold start
I feel your pain. I just returned from the BMW service center. My 2023 X1 has recently developed an issue where it hesitates from stop (with autostart off every time I start the car), then suddenly grabs. I've driven it for almost 11,500 miles without an issue, now, as the weather gets colder, it has developed.
This is my first BMW with an automatic. Four priors were all manual, but a recent mistaken foray into Mercedes as well as my sister's BMW 3-series automatics had a transmission problems with a $10,000 repair price tags. So I got nervous. Service manager says they couldn't duplicate the issue, but that it is common. Great. My concern is that sudden grab is not only a pain, but over time, that has to hurt the transmission. |
11-22-2024, 08:57 PM | #11 |
Rep 493
It is a very old Bmw problem that randomly hits certain cars. It seems to be caused by the throttle control. Nothing to do with DCT.
Google search "BMW tip in delay" and you will find posts dated back to 2010 and many other models (with basically no real solution). My previous 5 series had this and it was the worst car that I ever owned. It had the 8spd ZF transmission |
11-23-2024, 05:19 AM | #12 | |
I Shoot People For Money
1222
Rep 2,135
Drives: 2023 Portimao MSport X1
I will say, it has gotten better since the last OTA software update I had though, enough to notice the difference but it's still there.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
