BIMMERPOST Universal Forums General BMW News and Cars Discussion Stupid Newbie Questions and info for the new BMW Owner
      11-22-2024, 12:03 PM   #1
Vindicator3
Vindicator3's Avatar
449
Drives: 2025 BMW 540i
Having driven Hondas/Acuras for over 30 years, I'm learning a few things as I await my new 540i. What else am I missing that those new to BMW might not expect coming from other marques?
1) BMW brand motor oil without a standard viscosity rating, really? I mean, Honda "wanted" you to buy Honda-brand oil, but nobody did. They specified 5w20 or 5w30 or whatever and I could go buy Mobil 1 or Valvoline or whatever. Now all I have for a spec is Longlife-22 Fe++, whatever the heck that means. Does everyone just suck it up and buy the BMW oil?
2) My G60 won't have a dipstick and I'm supposed to wait for an indicator light to add oil? The oil indicator on Hondas was an emergency signal, not to be used for regular maintenance - I just checked the oil with the dipstick once a month. The idea of waiting for the computer to tell me to add oil makes me nervous. Of course, on my prior cars I rarely had to add oil between changes until they hit 100,000 miles or so and I hope my new 540 will be likewise.
3) Special "Star" marked tires? Are these available at independent tire dealers and discount chains or only via a dealer?
4) What else am I blissfully unaware of as a newb which I will soon learn is different when it comes to caring for and maintaining my BMW compared to previous non-BMWs?
      11-22-2024, 03:03 PM   #2
tracknut
Drives: 2016 M4; 2025 M8C this week!
Regarding the tires, BMW's star is not unique among auto brands, several others have their own similar brand-unique designation. You can get them at Tire Rack, etc.
M5Rick70949.00
      11-22-2024, 03:46 PM   #3
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
1) BMW motor oil has viscosity ratings and you don’t have to buy BMW oil. The viscosity is pretty low these days. Like 0W-20 or so. You need to do more research if you’re coming up with BMW oil not having any viscosity rating. It’s not uncommon to be able to buy the appropriate European rated oil at Wally World. But, the fact is BMW oil from the dealer is not much more than at other retailers. Just to be sure, you are aware BMW will do your oil changes for the first three years, right?
2) Yes, it’s stupid that BMW (and many others, including Porsche and Mercedes, and probably Audi) doesn’t have dipsticks anymore. But, you don’t have to wait for the sensor to tell you to add oil. You can check the oil level with the iDrive system anytime you want. I can’t recall ever reading a report of a catastrophic oil level sensor failure.
3) Buying “Star” tires is not a requirement. Unless you are leasing and need new tires before you turn in the car. There are plenty of non-BMW Star tires that are perfectly acceptable for your BMW.
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
celsdogg358.50
Llarry22231.50
co_440i201.00
M5Rick70949.00
      11-22-2024, 04:05 PM   #4
celsdogg
E4 Mafia
359
Drives: E30, E36/5, E46x2, F22, F30
yep. I actually put benz tires on the F30 and found them at Tire Rack.
As for oil, there is a lot more to selecting what to run other than viscosity, such as API category. BMW LL-XX is just another one. In all my years I have very rarely bought BMW's branded oil, there are lots of other oils that meet the requirements.
Squad - '90 E30 325i MT (226k) | '98 E36/5 318ti MT (160k) | '03 E46 325i MT (156k) | '04 E46 330xi MT (195k) | '15 F22 M235i MT (66k) | '15 F30 335i MT (85k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k)
Bring back the purple M stripe
      11-22-2024, 06:09 PM   #5
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [8.01]
BMW Oil is Castrol Oil if I remember correctly. Previously it was Shell Oil.
BMWCCA member Puget Sound Chapter
M5Rick70949.00
      11-23-2024, 04:28 AM   #6
tturedraider
The other way around. Used to be Castrol. Now Shell.
www.bmwcca.org
DanG11522.50
      11-23-2024, 07:49 AM   #7
Bc2005
Drives: 2021 M340i
It’s a good idea to use the iDrive oil level check about once a month, since it seems to get flaky once the oil level is around 2 quarts low. I had an oil leak on the filter housing seal and lost two quarts in less than a day. I knew it was low, but could not get a reading from iDrive.
The iDrive oil level check function would just quit at about 80% of the check, until I put are least one quart in and got the oil up closer to normal.
      11-23-2024, 07:54 AM   #8
DanG
DanG's Avatar
2018 BMW M2  [8.01]
I thought I read that they were switching back to Castrol. But it seems that they just signed an extension with Shell.
      11-23-2024, 08:46 AM   #9
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
My 2018 M5 is rated LL-01FE for oil. FE stands for fuel efficiency. I use regular LL-01 oil, which is common BMW spec outside of the US. I also would not hesitate to put non-BMW Star spec tires on my BMWs and usually do, though I make sure the load spec is correct. The mist important thing is finding a good mechanic if you do not want to pay high dealer prices for work. I mostly DIY.
      11-23-2024, 10:12 AM   #10
Vindicator3
449
Thanks, all. Yes, we have a couple of very well-thought-of local BMW-specialist independent mechanics I can use once the free maintenance period is over.
      11-23-2024, 03:31 PM   #11
BMWCCA1
BMW Owner Since 1971
2552
Drives: 1964 700 Sport Cabriolet
2013 BMW 128i  [10.00]
I've owned BMWs for over 50-years and sold them as a profession for nearly 47-years. My first encounter with the Star-branded tires was when a customer who was notoriously cheap took his E34 to the local Michelin dealer and came back with his four new tires complaining of a handling or "feel" issue with his car. I checked for the star and, when not seeing it, checked the sidewall for a description of the tire construction. Even though it was the same style of Michelin as what came off the car as OE, and even though it had the same speed-rating, the construction description molded into the sidewall showed two-fewer plies in the sidewall on the non-star Michelin (four plies versus six). Obviously enough of a difference to change the slip-angle of the car when using the non-star tire. He took it back to the local Michelin dealer and they got him the correct starred Michelins and was happy again.
POBEP428.00
co_440i201.00
eugenebmw2171.00
      11-23-2024, 08:31 PM   #12
tturedraider
Very interesting and good information!! I must admit that never would have occurred to me.
www.bmwcca.org
      11-23-2024, 08:57 PM   #13
Spydrman
Drives: 2025 X5 40iM,2017 Corvette,
Hi,
I am new here.
I recently bought a 2025 X5 40i M for my wife.
We are considering buying a X5 M too. Do you know what suspension is with the M? do you know where to look at the site? I wanted to see if people had problems with the more sophisticated version. I think it has an air component.
We just got rid of a 2012 Mercedes that lots of problems with the air suspension once it was a couple of years old. I do not want any of those issues.
      11-23-2024, 08:59 PM   #14
Spydrman
Hi,
I am new here I recently bought a 2025 X5 40i M for my wife.
Do you know what suspension is with the M? Do you know where to look at the site? I wanted to see if people had problems with the more sophisticated version. I think it has an air component.
      11-24-2024, 09:48 AM   #15
RockCrusher
Drives: BMW 2024 M8 Competition Coupe
I use -- well the dealer uses -- BMW oil. All of my BMWs: 2022 230i, 2024 230ix, 2023 M2, and my 2024 M8; came/come with free service for 3 years 36K miles. For the M2 and M8 this includes the running in service at 1200 miles.
When the time comes that my M8 no longer qualifies for free service I'll still have it serviced at the BMW dealer and filled with BMW oil.
My feeling is why use my nice (and $$$) car as a test bed to try to find suitable alternative oils? Life's too short to try to fix what ain't broke...
The electronic oil level measuring system checks the oil level on its own. But as has been my habit now for years with a new car I'll check the oil level more often -- just to confirm the engine is not experiencing abnormal oil loss, and I check the oil level at every fill up.
I don't want to wait for the system to flag a low oil level to the point I have to add oil. If the level is dropping I want to know ASAP. And I carry spare oil so I can top the oil level up then make arrangements to get the car in and have this oil level drop investigated.
When I changed my own oil -- this in my Porsche cars which also were fitted with an electronic oil level measuring system -- I would follow the service manual drain instructions then add the right amount of oil then start the engine -- after counting the empty oil bottles *twice* -- and check carefully for leaks then back the car off the ramps and let the engine idle.
I'd clean up then check the oil level to ensure the electronic oil system system reported the oil was level was where I expected it to be (at full) given I had put in the called for amount of oil.
If one changes his car's oil he has to be aware the electronic oil level system is *not* really designed to report how much oil is in the engine much beyond full. Thus one must be very careful to add just the right amount of oil but no more.
Now with my BMWs I don't service them myself but I still check the oil level after a dealer service not because I don't trust the tech but rather to be sure the electronic oil level measuring system oil level reading agrees the oil level is correct. Signs of a problem with this system is no reading or a fluctuating reading.
Have not had to buy tires for my BMWs yet, but when it came time to buy tires for my Porsche cars -- which were marked for use on Porsche cars by the presence of an "N0", "N1", and so on (the N was the Porsche equivalent to the BMW star the number was the tire generation number) my local Porsche dealer sold me tires at the same price I could get them from say Tire Rack.
When the time comes to get tires for my BMW I'll get them at the local dealer. The service department is well experienced changing tires on cars/vehicles with *expensive* wheels. It knows how to properly lift the vehicle and by how much to tighten the wheel lug nuts/bolts.
(I had to run out of the waiting room to stop an indy tire store "tech" from lifting my Boxster by putting a hydraulic jack under the bottom of the front trunk -- which was not suitable for lifting the car! This after the manager had assured me his guys knew how to replace the tires on my Boxster.)
As with my other cars same with my BMWs. I'll just follow the factory service/maintenance schedule. This includes besides oil/filter, engine air filter, cabin air filter, brake fluid flush/bleed, and with more miles spark plugs, whatever the factory service schedule calls for and when.
      11-24-2024, 08:02 PM   #16
goosxe
Drives: 2022 M340ix
Following this thread - just switched over from driving honda/acura/lexus products
      11-27-2024, 01:23 AM   #17
tturedraider
You made a good switch.
www.bmwcca.org
      12-03-2024, 12:03 PM   #18
agorski
agorski's Avatar
504
Drives: BMW i5 eDrive 40
The thing that surprised me the most was that you can't just go buy a Sears DieHard battery (like I did) and expect it to work correctly. A service center has to "register" the battery, or something like that.
      12-03-2024, 12:24 PM   #19
Vindicator3
449
Thanks, I'd be interested to hear more about the battery. What's the deal there? So you can still use a national-brand aftermarket battery, but with this added "registration" step, or you can't even use one? Can I do the "registration" myself or does it have to be a dealer?
And now that I've started perusing the owners manual while I await delivery, am I correct that there's no maintenance schedule like I'm used to with Honda (e.g., change oil every X miles, change transmission fluid every Y miles, change spark plugs every Z miles) and it's replaced with "your car will tell you what you need when you need it (kind of like a surprise!) and will even book an appointment at the dealer for you"?
      12-03-2024, 12:43 PM   #20
The Seeker
///MPhatic's Avatar
15590
2018 BMW M2  [9.00]
The biggest difference between JDM cars and German cars is tolerance.
German cars have no tolerance. They want every last hp/tq/anti-squeak/whatever, and they engineer things to work with other things, so when one thing breaks, it breaks several others.
With regards to oil, use Pennzoil Platinum Euro LL04, and make damn sure you don't go past 5K miles.
BMW's simply require you to pay much closer attention vs JDM's allowing you to think about everything else but your car.
Good Luck.
      12-03-2024, 02:33 PM   #21
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
Any battery will work just fine so long as it meets the same specs and is of the same type as your original (i.e. AGM). Registration is an easy process that can be accomplished with most any hand held scanner that is capable of reading the BMW specific hex codes (not just generic P-Codes)
For more of a "long term" ownership maintenance schedule check out Mike Miller's Lifetime Maintenance Schedule. It's a bit dated but, imho, the fundamental principals still apply.
I think the big difference of opinion re: maintenance occurs when talking about the "Lifetime Fluids" - like the transmission oil. Most mechanically minded people don't buy into the concept of a "lifetime fluid".
      12-03-2024, 02:58 PM   #22
Vindicator3
449
This is the first I'm hearing of "lifetime fluids" and I have to agree with the skeptics on that one. I'm just checking out the Mike Miller document, thanks for the tip. Glad to see he's a Red Line fan - I used Valvoline/Pennzoil/etc from Walmart for engine oil in my Hondas/Acuras but religiously used Red Line MTL for my manual gearboxes after it worked wonders on a failing clutch (at nearly 200k) miles in my 1992 Civic, 20 years ago. That stuff is magic.
