BIMMERPOST Universal Forums Off-Topic Discussions Board Any good techniques removing adhesive residue from automotive paint?
      11-30-2024, 01:52 PM   #1
XutvJet
XutvJet's Avatar
6110
Drives: 2011 Cayman Base, 2018 M2
I'm in the process of removing various parts from my M235 to sell it. Years ago, I removed the stock lip spoiler and replaced it with the M Performance CF spoiler. I removed the CF spoiler yesterday and of course it left tape residue on the paint. I remember removing the residue when I removed the OEM lip spoiler and it was a biatach to get the residue off. I did Goo Gone and a little heat from a heat gun, but what got it was my fingers which were then blistered for days later. BMW uses a double sided tape that is even stronger than the typical 3M stuff and the residue is something else.
So far, I've tried Goo Gone, petroleum jelly, WD40, as well as some heat and a plastic razor. I've gotten the fluffy tape off, but the final adhesive layer is fighting me hard. A friend swears by just using some gasoline on rag. I don't thing I'm at that stage and I've read people saying it's no big deal and others saying it will cloud the paint. Any other ideas? 3M rubber wheel perhaps?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
      11-30-2024, 02:17 PM   #2
Ask your wife if you can borrow her nail polish remover. Try it. Nothing to lose.
      11-30-2024, 02:20 PM   #3
2018 BMW M2  [9.17]
For the rear spoiler you need an eraser wheel, and then some sort of solvent. I use PPG 330, it's safe for paint, and it works wonders.
      11-30-2024, 04:16 PM   #4
Did you try using more 3M VHB tape over the old tape's goo? With decals, I found that sticking a new (scrap) one over the goo from the old one interacted with the old goo and made it release easier.
You've already tried my other go-to things for decal removal, namely goo gone and WD40. I don't think that a rubber wheel is the answer, since it will probably just plug itself up with melted goo from the heat.....
      11-30-2024, 04:28 PM   #5
chassis
chassis's Avatar
8471
Drives: 9Y0 Cayenne S
Gasoline and naphtha (lighter fluid).
I would avoid acetone, or try it in a small concealed spot. Goof Off is good, and contains acetone, so is on the "last resort" list.
      11-30-2024, 08:58 PM   #6
2nd for Eraser wheel + drill
      12-02-2024, 07:52 PM   #7
lakefront
Drives: Whatever's in the garage
3M makes a number of adhesive removers.....maybe check what would work for your situation?
      12-02-2024, 08:53 PM   #8
RockCrusher
Drives: BMW 2024 M8 Competition Coupe
I'd certainly not use any abrasive method. I'd try something from an auto parts store, like Goo Gone, or some adhesive remover. lakefront mentions 3M and that's a good brand to start with.
Also, like chassis offered test whatever you want to use on a hidden painted area.
You will almost certainly remove besides the adhesive any wax. So after the adhesive is gone wash the area well then dry and apply good automotive paint wax.
      12-04-2024, 12:13 PM   #9
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
WD40 is my go to when removing any kind of adhesive or sticky substance in general.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX
2021 X7 40i MSport, 2006 Z4M 6spd
vreihen1622215.00
      12-04-2024, 01:52 PM   #10
clay bar with LOTS of lubrication
      12-04-2024, 02:33 PM   #11
XutvJet
XutvJet's Avatar
6110
That's the direction I'm going and then follow-up with a polish.
      12-04-2024, 03:54 PM   #12
mjj
Drives: 2025 M4 Comp Verde BR
I have used 3M adhesive remover for years on multiple vehicles. Never an issue. Pick it up at any auto parts store.
      12-09-2024, 02:56 PM   #13
XutvJet
XutvJet's Avatar
6110
Used the 3M eraser wheel. I had all the residue off in a few minutes. No damage at all to the paint, not even light marring. I'll never use a chemical again to get sticker residue off of paint again. Thanks to all that recommended the eraser wheel.
vreihen1622215.00
      12-09-2024, 02:56 PM   #14
XutvJet
XutvJet's Avatar
6110
Used the 3M eraser wheel. I had all the residue off in a few minutes. No damage at all to the paint, not even light marring. I'll never use a chemical again to get sticker residue off of paint. Thanks to all that recommended the eraser wheel.
