BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) BMW X1 (2024) - Unpleasant Smell from Heating System
      01-06-2025, 04:18 PM   #1
ariver20
Drives: BMW X1
I have a 2024 BMW X1. I turned the heating up to the maximum for about 10 minutes because I was really cold.
However, an unpleasant smell started coming out, so I turned the heating off.
Now, when I turn the heating back on, the unpleasant smell sometimes reappears. What could be the issue? What should I do about this?
      01-06-2025, 04:25 PM   #2
J-RO
Drives: 2024 M240ix BMW X1 28i
Check under the hood and see if there are any dead animals in there.
      01-06-2025, 04:35 PM   #3
ariver20
Drives: BMW X1
No dead animals
      01-06-2025, 05:02 PM   #4
kenrok1
kenrok1's Avatar
Drives: 2025 X1 M35i (two)
2025 X1 M35i  [0.00]
2025 X1 M35i  [0.00]
not knowing what kind of unpleasant smell you may get a lot of guesses and suggestions - its always good idea to clean leaf debris out of the inlets under the wiper area and check/replace the cabin air filter. But anything beyond that is probably best left to your service dept
      01-09-2025, 03:30 AM   #5
LondonDubaiX1
Drives: Ix1
You can get AC cleaner, it’s usually called one shot or something similar and you set it off and shut the doors with the AC on full power and it helps kill any bacteria in the system
      01-10-2025, 11:35 AM   #6
DestinationMoon!
Drives: Bmw X1 U11
Do you keep the car inside or out? If outside what's the weather been like? Did you smell anything at lower speeds?
      01-10-2025, 12:10 PM   #7
John27
John27
Drives: X1 xDrive 23i M Sport
As @LondonDubaiX1 says, often smells in heating/air con are from bacteria in the system. Normally, an AC cleaner will fix this but worse case, replace the air con gas. The problem is normally caused by turning off the air con. I leave it on all the time which ensures all the seals remain lubricated etc and the system remains effective.
If that is not the issue, it could be a leaking heating core in the interior of the car. Worth checking if you have ruled out the air con. Using an air con cleaner is the cheapest option so worth trying first.
      01-10-2025, 11:31 PM   #8
Baldilocks73
Baldilocks73's Avatar
Drives: G42 M240i (on order)
Cabin filter dirty?
