01-08-2025, 10:51 PM | #1 |
![]() 51
Rep 213
Wheel Cleaner with CCB
This my first set of CCBs, and my wheels are ceramic coated. What are you guys using as a wheel cleaning spray when there’s low dust and no iron contamination? I assume I want to stay away from any cleaner that is meant for steel brakes since they’ll like contain caustic compounds for iron dust. PH neutral is a must I guess. Any suggestions appreciated.
2025 G80 M3 6MT / Imola Red II / Silverstone / Carbon Buckets / Carbon Exterior Package / CCB / HKStudie Exhaust
1999 E36 M3 / Titanium Silver / Black Vaders / Supersprint / Jim Conforti Tune / Fikse FM10 / Single Owner |
01-09-2025, 10:41 AM | #2 |
![]() 511
Rep 1,302
Leftover car wash shampoo ......
If you have a Pressure Washer, it's really just the surface film that is needed on a mechanical wash post HP rinse Be mindful when you dress the rubbers Last edited by chefwong; 01-09-2025 at 10:56 AM.. |
01-23-2025, 11:15 PM | #3 |
![]() 3038
Rep 2,511
Drives: INDIVIDUAL F90 M5C LCI
I use Gtechnique "Iron fallout remover" and the "Citrus foam soap" in a completely differely bucket and brushes
NOW: '21 M5|FSHNGRY|TARTUFO|CCB| MPE|KW|IND|EVENTURI|EISENMANN|DINAN|BBS|
GONE: '15 F82 M4|YMB| IND|MPE|KW|BM3| GONE: '11 E92 335iS|BLKSPHR|OYSTER| GONE: '05 E46 ZHP|DINAN STG3 PKG| https://www.youtube.com/channel/UCva...WCpLE9CH6t9Jeg |
01-24-2025, 06:45 AM | #4 | |
ホンダ
1881
Rep 559
The reason is because the carbon core of the disc oxidizes when exposed to oxygen (or temps over 600°F), which causes the disc to degrade. If you look closely at the edges and vanes of the disc you'll see a grey metallic coating, and it's this coating that keeps oxygen (air) from getting to the disc. On the face of the disc you'll see the tell-tale cracks, and wear indicator circles. Inside these cracks and circles is this same metallic coating, protecting the disc from oxidization. Using products with various chemicals in them can degrade this protective layer over time and cause the disc to lose integrity. I'm a CCB guy, so if you have any other questions, feel free to DM me. |
IL8Apex50.50 |
