03-23-2025, 07:54 AM | #1 |
![]() ![]() ![]() 251
Rep 453
Washing Microfiber towels
I've noticed many of my microfiber towels are losing their water absorbency. Instead of soaking in the water, it usually just pushes it around the body panel.
All of my car wash towels and mitts are washed with each other and nothing else. I don't wash them with fabric softener or dry them with dryer sheets. Our typical detergent is either Tide High Efficiency liquid detergeant or Kirkland's (Costco) same product. I've even tried using a specific microfiber towel wash from Chemical Guys and am still having the same issue with water absorbency. Am I doing something wrong? Using the wrong products? Suggestions for what I should use? Thanks! |
03-23-2025, 10:03 AM | #2 |
![]() ![]() 7979
Rep 5,557
I have been using the Chemical Guys product and my microfiber towels are still holding up. I think that after multiple washes any microfiber towel will lose some absorbency.
BroDoze2808.00 |
03-23-2025, 10:05 AM | #3 |
![]() 2808
Rep 2,737
This stuff rocks. Mine are holding up great with it.
https://www.amazon.com/dp/B001TJXWH4...n_title_1&th=1
///M
03-23-2025, 01:02 PM | #5 | |
Rep 453
How much do you use? I presume you put it in the normal detergent reservoir. What cycle are you running the washing machine on? I'm typically putting it through the sanitize cycle. |
03-23-2025, 01:07 PM | #6 |
![]() ![]() 7979
Rep 5,557
I use the measurements written on the bottle and use a hot water delicate setting. I then use a lower heat setting for the dryer and if they’re still damp, I put them on a drying rack. I don’t cremate my towels in the dryer.
03-23-2025, 05:38 PM | #7 |
![]() ![]() ![]() ![]() 501
Rep 749
you can damage towels drying them at high heat. always dry on lowest setting. also, they just dont last forever.
03-23-2025, 08:24 PM | #8 |
Rep 453
Well that's another thing I'm doing incorrectly then. I'm drying them on the highest temperature.
Thanks all! |
Westside Guy7979.00 |
03-24-2025, 05:06 AM | #10 | |
Rep 453
Again- appreciate the feedback! |
03-24-2025, 07:03 AM | #11 |
![]() ![]() 7979
Rep 5,557
We will have to agree to disagree on this point, using high heat is dangerous to any material including microfibers.
B58-M340iX279.50 Dan B580.50 |
03-24-2025, 07:12 AM | #12 |
![]() 2808
Rep 2,737
LOW and SLOW …
///M
03-24-2025, 07:31 AM | #13 |
![]() 1273
Rep 1,039
Maybe I have higher quality towels?
Two is One and One is None
03-24-2025, 07:34 AM | #14 |
![]() ![]() 7979
Rep 5,557
It has nothing to do with the quality, I was in the fabric business all of my life and a cardinal rule in dealing with material was never use extremely high heat.
I use CARPRO's DHydrate high-quality microfiber towels, except for cleaning the wheels. From Carpro's website, "Microfiber towels should only be washed with other microfiber towels. If you wash with other types of fabrics like cotton, etc, the microfiber will retain lint from those fabrics. Wash with microfiber detergent which contains everything you want and nothing you do not. NEVER use fabric softeners or dryer sheets. When drying either hang dry or dry on a very low heat cycle and never leave them in the dryer long enough to heat up. A dry microfiber that is heated to a certain point melts and becomes a danger to paint." Last edited by Westside Guy; 03-24-2025 at 07:47 AM.. Reason: Edited to add cleaning instructions |
ultrared93112.00 Dan B580.50 |
03-24-2025, 07:59 AM | #15 |
![]() ![]() 1345
Rep 1,145
Drives: '25 M240xi
Just use regular no additive Tide detergent. It's the best detergent made and RebrandGuys cant hold a candle to its efficacy.
Dry on like low heat air fluff into hang dry.
03-24-2025, 08:41 AM | #16 |
![]() 1386
Rep 1,637
It's not so much that the towel will lose whatever quality it has for its intended purpose (eg drying vs buffing) as it is risking marring from the synthetic fibers having melted from too much heat. Is that guaranteed to happen, no, but it can and there is some temperature variability btwn appliance brands (i.e. dryers) when drying and what constitutes 'hot' for hot water when washing.
That's why it is generally recommended to not use hot water or high heat when washing/drying MF towels. For OP, I use Rags to Riches with a proportioner. I got the larger size since it is more exonomical and was the only size available at a reasonable price when I bought it. Cold or warm water to wash (depending on what I used the towels for). For drying, low heat and/or air dry. I try the choose what type weaves I use for simplicity as I have neither the time nor patience to separate different weaves based on type and purpose for washing. As an example, I like waffle weaves for cleaning glass but they'll collect lint from other towels, so mixing them isn't a good idea. I find general purpose MF towels will carry lint less and still adequately clean glass so that's my 'window' go-to since I'll use general purpose towels for other things when cleaning a car. Thus it is more efficient to wash afterwards (vs 1-2 waffle towels). That was more info than asked for. ![]()
- Jeff
bosstones' flickr Last edited by bosstones; 03-24-2025 at 08:42 AM.. |
tracer bullet4527.00 Autoaddict489.00 |
03-24-2025, 12:37 PM | #17 | |
![]() 1273
Rep 1,039
bosstones1386.00 |
03-24-2025, 01:36 PM | #18 |
![]() ![]() 4527
Rep 4,773
I don't have specific advice but will say I soak everything in a combo of dish soap and rags-to-riches overnight, then wash with laundry detergent but no softener, and lastly dry on a medium heat setting. So far so good.
if you use any MF's with a spray on ceramic, I'd keep them to do that job or start cleaning door jambs with them or around the house stuff. They do tend to lose absorbency after a few times. |
bosstones1386.00 |
03-25-2025, 07:41 PM | #19 | |
![]() ![]() 788
Rep 1,257
It would probably be best to buy some new ones, and maintain those. Use MF towel detergent, wash them on hot and dry them on low. |
keg97251.00 |
03-25-2025, 08:44 PM | #20 |
![]() 8742
Rep 2,611
Drives: 9Y0 Cayenne S
I wash microfiber towels in the normal laundry, then dry in the dryer. All good.
03-26-2025, 07:36 AM | #21 |
![]() ![]() ![]() ![]() 23632
Rep 639
I wash and dry them with the regular wash and when they go for a crap I buy new ones, they're pretty cheap. That's about $6 USD, probably less than you guys are spending on special detergent.
03-26-2025, 08:12 AM | #22 |
![]() ![]() 4527
Rep 4,773
Those are great towels, I have a dozen or so in green. I like them for windows and even use them in the house. When they go bad I move them to oil change and similar duties and cut a corner off of them first so I know not to bother washing them again.
However i think most folks are talking towels more like these, double the size and a lot more plush: https://adamspolishes.com/products/a...19941438718049 I've only bought the 12 pack once at about $5 USD per towel. Not cheap but they've been great. No issues with "normal" use or washing, and if they've seen some ceramic removal they too get a corner cut off and see new jobs afterwards. On a related note I'll probably get some of these once I start to run low on the bigger, plush ones: https://www.amazon.com/gp/product/B0...LVBY446LD&th=1 |
