04-17-2025, 01:49 PM | #1 |
Rep 16
Drives: 2011 M3 Coupe
Mr. Clean Magic Eraser on Glass?
Yes, I just recently decided to replce the tint on my car. Water spots. Everywhere, and unending (softened and triple filtered water well water). I picked up CLR ina plastic spray, and majic eraser pads. Tried the pads and they are TOPS! I kept the solution from touching the paint, cleaned, wiped, rinsed, wiped. 95% of a back window was cleared in two passes. A few remain but they look to be a bit more than a spot. Highly recommend for any detail/tintheads out there!
04-18-2025, 06:35 AM | #4 |
![]() 189
Rep 169
tighfitzgerald6.00 |
04-18-2025, 12:35 PM | #5 |
![]() ![]() ![]() 498
Rep 402
Magic erasers are made out of foam that is essentially like fine grit sandpaper. Not the best thing to use on glass as you're going to etch it and create fine scratches over time.
Westside Guy8450.00 |
04-18-2025, 03:47 PM | #6 |
![]() 130
Rep 205
It shouldn't be used as a daily cleaner. It should always be used with a lubricant/glass cleaner. A couple times a year to remove build up on exterior glass or off gassing on interior windows.
silvermanor497.50 slilley188.50 |
