BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Garden Hose Recommendations?
      05-22-2025, 12:44 AM   #1
JoeyO
Drives: silver car
Where can I get a good-quality old-fashion garden hose that is extra thick, super rubbery, doesn’t kink up, and will last for many many years?
I need one for bucket washes when washing my car. I’m sick and tired of all the cheap quality hoses out there.
      05-22-2025, 08:11 AM   #2
slilley
Drives: 2023 X5, plus others
I've purchased at least 5 hoses over the last 5 years. I've tried the best that Lowes, Home Depot, and Ace had to offer. I also tried Amazon's top-rated hoses. Returned most of them, but I remember giving one away (couldn't be returned after using it) and stashing one as a spare under the back porch where it will probably never get used again. But this time last year I did FINALLY find a hose that I'm satisfied with! Is it perfect? Hell no! But I don't ever curse when using it.
Griot's Professional Water Hose, Item#94761
https://www.griotsgarage.com/professional-water-hose/
Expensive, but good. I got the 60' version. Next time I'll get the 100' version, because what I really need is a 80' version but they don't sell one of those.
If you look at the Griot's hose reviews, there are a surprisingly high number of negative reviews. I think that's because people aren't storing or using the hose with a proper hose reel. This is the one that I LOVE. I'm on my second one, because they only last me about 3-4 years. But they make it super-easy to use the hose anytime I want to wash the car:
NeverLeak Steel 150-Feet Container Hose Reel:
https://www.lowes.com/pd/NeverLeak-S...e-Reel/4363423
Good luck!
BWBike295.50
      05-22-2025, 10:27 AM   #3
CTPJ
CTPJ's Avatar
353
Drives: BMW M2
Eley makes great hoses and reels. They are not cheep but they are worth the premium price. Everything they make is high quality including their quick connects and nozzles. I have a number of their reels, hoses, and quick connects. They have all lasted many years.
https://www.eleyhosereels.com
BWBike295.50
slilley188.50
      05-22-2025, 11:01 AM   #4
DrVenture
DrVenture's Avatar
2036
Drives: M550i 2022
2022 BMW  [10.00]
Keep in mind that "extra thick, super rubbery, doesn't kink" tends to mean really heavy and hard to use with many hose reels. Not particularly flexible. I did have a 5/8' 100' rubber hose from a big box store that lasted 20 years. It did kink though.
I have had decent results with Flexzilla hoses. Very kink resistant, light weight and durable, for the most part. No idea if they will last 20 years. I do not like vinyl hoses. And commercial grade rubber hoses are very heavy and inflexible.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Premium Pkg|Luxury Seating|M668 w/ DSW06+
      05-22-2025, 11:04 AM   #5
Littlecoupe
Drives: 2023 M240i
I also recommend a hose reel. I have a 100ft heavy duty hose that I picked up from Costco a few years back. It doesn't kink easily and feels durable, but I absolutely despise packing it around and storing it. I'm not weak, but it's rather heavy. Trying to coil it up for storage is a pain. I basically only use it for draining the Intex pool if we set it up since it has a good flow rate being a solid hose.
A hose reel may have solved the problems, but I cheaped out and bought another semi-collapsible one from Costco.
      05-22-2025, 12:24 PM   #6
biz77
Drives: 2021 X3 M40i
I second the Eley hoses. Expensive, but they are light, kink resistant and very well made with a good warranty. I've also had decent luck with Flexzilla garden hoses, although they tend to look nasty after sitting outside a couple of years.
CTPJ352.50
      05-22-2025, 12:27 PM   #7
STATIC A$TRO
NEWBIE
Niger
51
Drives: 08 BMW 335i
      05-22-2025, 12:51 PM   #8
Littlecoupe
Drives: 2023 M240i
Originally Posted by STATIC A$TRO View Post
IMO, there is one glaring flaw with these hoses for bucket washes - flow rate or poor laminar flow. That valve on the end causes the water to come out in a spray pattern rather than a consistent stream. Why does this matter? A well coated car with good hydrophobic properties allows one to essentially "dry the car" with water. That smooth flow creates sheeting that sheds most of the water off the car, something I haven't been able to accomplish with these expandable hoses. With a standard garden hose, the smooth flow of water allows me to sheet off more than 90% of the water making an incredibly simple and efficient drying step.
      05-22-2025, 05:35 PM   #9
starlights
Drives: G05 50i
Our Costco Hose (with self retracting reel) is going strong after 4 seasons. I do remove it and bring it into the garage in winter when it snows here.
      05-22-2025, 05:43 PM   #10
powerplaymike
Drives: 2021 M2C 6MT
Continental tends to be well regarded.
Yes, that Continental.
I picked quite a few of these up last year when HD had them on super clearance for like $12.
https://www.homedepot.com/p/Continen...8070/100580705
Only had them a year, so time will tell, but seem very durable thus far dragging along my concrete driveway and always being scraped/pinch by the edge of my plastic fence door lol
CTPJ352.50
      05-22-2025, 05:47 PM   #11
Mech Spec
Mech Spec's Avatar
Drives: '25 M240xi
For a large diameter quality hose, but heavy and hard to move around.
Giraffe Tools Garden Hose 25ft x... https://www.amazon.com/dp/B0CDB5CRCR...p_mob_ap_share
If you need longer than 25ft I would size down from 3/4 to 5/8.
No complaints with this hose so far
Flexzilla Garden Hose 5/8 in. x... https://www.amazon.com/dp/B01N9OCWJO...p_mob_ap_share
2025 M240i Xdrive TNM
~~Build Thread~~
      05-22-2025, 06:01 PM   #12
powerplaymike
Good luck!
That griots has aluminum fittings, so that’s a no-go for me and I’m even careful about disconnecting hoses when not in use.
For those recommending flexzilla … I’ve heard they’re good, and I’ve actually got some short ones for other uses, but like others have said they will get disgusting with what looks like mold.
(Granted it was picked up used, but I’ve got a flexzilla PW hose and no amount of cleaning seems to get it back to the original non-moldy color)
The flexzilla ones I have use aluminum fittings as well, so that’s another element to consider with them.
As mentioned above, if you’re diligent with proper hose care and storage (using a reel that’s covered, only having it connected to the spigot when needed, etc) those considerations likely won’t be as big of an issue.
But, let’s face it: there’s definitely plenty of people that just leave their hose sitting out in a bundle on the ground permanently connected to an exterior spigot.
slilley188.50
      05-22-2025, 08:02 PM   #13
BWBike
BWBike's Avatar
Drives: 2025 X1 Xdrive28i & others
I do need a new hose and I’m liking the Eley hose. I have to be sure before spending that kind of money.
Vehicles: 2025 X1, 2020 Ford Mustang, 2015 Dodge Challenger, 2015 Jeep Renegade, 2014 H-D Road King
      05-22-2025, 08:27 PM   #14
stbm5
Drives: 2018 M5 DG
the Eley look great but 500 for a hose and reel kinda sucks. I have the Continental hose and hate it, its heavy and kinks easily.
      05-22-2025, 08:41 PM   #15
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
A few mentioned Costco, and I wanted to add that I have a great hose purchased from there... 10+ years old, still flexible and no problems. Love it.
      05-22-2025, 09:42 PM   #16
JoeyO
Drives: silver car
Thanks for the feedback everyone. Nice to see I’m not the only one who appreciates a good quality hose.
      05-23-2025, 09:17 AM   #17
CTPJ
CTPJ's Avatar
353
Drives: BMW M2
I can second the recommendation regarding Continental hoses. I currently have 3 that I have had for over 5 years. They are left outside year round and, other than a "red" one's color fading because it lays on the ground in direct sunlight all the time, I have never had an issue with any of them.
      05-23-2025, 10:16 AM   #18
BeEmVe
Drives: '14 X1 x28i M-Sport
IMHO buy a good quality pure rubber hose. It will last decades. I have several that are all from Craftsman. Not sure they can be found any more. As such, here is what I would suggest:
https://shop.briggsandstratton.com/p...rden-hose-75ft
Regardless of the brand, pure rubber is the way to go.
      05-23-2025, 06:13 PM   #19
Portimao Blue M440ix
Portimao Blue M440ix's Avatar
266
Drives: Bmw m440ix g22
Another vote here for 100% rubber hose. I have had some for well over 25 years always stored outside never drained of water in the winter. I have them on hose reels and never had a problem.
CTPJ352.50
      05-23-2025, 07:16 PM   #20
jkoral
Drives: 2017 M2 LBB 6MT
Last year got rid of my 100% rubber Craftsman 75' hose bought in 1991. My wife was sick of it because it was too heavy. Would have lasted another 25 years or longer, it was like new after 33 years.
      05-23-2025, 09:19 PM   #21
John in VA
Drives: 2015 228i M Sport
Got mine in 1989 - still going strong!
jkoral1240.50
      05-24-2025, 09:43 AM   #22
e90Dawg08
Drives: 08 e90 M3
I'm a fan of the zero G hoses because they deflate when not in use. Less chance of damaging them and they don't keep water in them when not in use. The humidity and sun doesn't seem to wear them as quickly as some others like continental either. If you're not in a hot and humid climate, the pure rubber may be better.
https://www.lowes.com/pd/Zero-G-NXT-...ode=1533&gQT=1
