BMW X1 U11
X1/X2
73.2KVIEWS
10REPLIES
19APPRECIATES
4ACTIVE PEOPLE
04-28-2026LAST POST
08-27-2025
analogue user avatar
analogue
937 REP
Here you will find all of the service bulletins BMW has submitted to NHTSA for the X1 and X2 (U11/U10). Bulletins usually take several weeks to appear in the NHTSA database after they are published internally in BMWTIS.
This thread will be updated with recent bulletins after they land at NHTSA and a reference is published here: https://itsanalogue.github.io/bmw-tsb/U11.html. You can find all of this information on the NHTSA website if you know where to look, but this is a consolidated list and should help search engines find and index the SIB PDFs faster.
Appreciate8
08-27-2025
analogue
937 REP
Recent Bulletins
SIB 65 12 26 (2026-04-13)
BMW X1 2025
BMW X2 2025
(plus 2 other models)
ELECTRICAL SYSTEM
After updating the vehicle to I-level …25-07-5XX, the spoken language of the navigation instructions changes from the set language for the voice assistant without the customer initiating the change.
MC-11031578-0001.pdf
SIB 65 09 26 (2026-04-06)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
The customer reports that the Intelligent Personal Assistant (IPA) does not respond to the "Hey BMW" wake up word, or to the push-to-talk (aka voice activation) button on the steering wheel. Also, various voice commands are possibly not correctly executed.
MC-11031577-0001.pdf
InVeh-InApp-Comm (2026-03-25)
BMW X2 2025
ENGINE
It was determined that the oil return line for the turbo charger was installed with a bolt of the wrong size. The bolt for the oil return line needs to be replaced.
MC-11030318-0001.pdf
SIB 12 03 26 (2026-03-19)
BMW X1 2023,2024,2025,2026
BMW X2 2023,2024,2025,2026
(plus 12 other models)
ELECTRICAL SYSTEM, ENGINE, UNKNOWN OR OTHER
PROGRAM CONTROL UNITS (OBD)
MC-11030305-0001.pdf
SIB 51 22 24 (2026-03-18)
BMW X1 2024,2025
BMW X2 2024,2025
(plus 9 other models)
STRUCTURE: BODY, UNKNOWN OR OTHER
On the main door seal, detachment behaviorcan be detected at the sealing joint . Over time, the seal gradually and increasinglydetaches which can cause it to- Dangle Become visible to the customer Prevent the door from closing properly
MC-11030306-0001.pdf
SIB 65 07 26 (2026-03-17)
BMW X1 2026
BMW X2 2026
ELECTRICAL SYSTEM
The following message is displayed on the central information display (CID): “Storage space running out”.Afterwards, apps can no longer be updated, and additional content can no longer be loaded.
MC-11030311-0001.pdf
SIB 65 08 26 (2026-03-16)
BMW X1 2025
BMW X2 2025
(plus 10 other models)
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, existing activation points for the “Automate My Habits”function no longer work.
MC-11030312-0001.pdf
SIB 33 01 26 (2026-03-02)
BMW X1 2023,2024
BMW X2 2023,2024
SUSPENSION, WHEELS
1. Noise complaint: Humming or clicking type noise in the speed range of 15 – 65 mph can be heard from the rear axle. Seeattached video “V33 01 26 Humming” and “V33 02 26 Clicking” The noise may be amplified depending on road speed. Or 2. Fault memory entry: Customer has Dynamic Stability Control malfunction indicator lamp and/or related Check Control Message. The following fault codes are found in the Integrated Brake module fault memory: 4809B7: Wheel speed sensor - rear left - tooth missing 4809C2: Wheel speed sensor - rear right - tooth missing 480AB4: Wheel speed sensor - rear right – noise monitoring 480AAD: Wheel speed sensor - rear left – noise monitoring
MC-11030056-0001.pdf
SIB 61 01 26 (2026-02-20)
BMW X1 2025
BMW X2 2025
(plus 8 other models)
ELECTRICAL SYSTEM
During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified
MC-11029070-0001.pdf
SIB 65 03 26 (2026-02-17)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
In Augmented View, the arrows are rotated by 180° (shown inverted below) when displayed on the CentralInformation Display (CID).
MC-11028926-0001.pdf
SIB 51 03 26 (2026-02-17)
BMW X1 2025
BMW X2 2025
(plus 1 other model)
SUSPENSION
While driving on rough surfaces, a “creaking” noise can be heard from the B-pillar trim panels.
MC-11028923-0001.pdf
SIB 12 03 24 (2026-02-12)
BMW X1 2024,2025
BMW X2 2024,2025
The Engine Malfunction Warning is illuminated, and the following fault code is stored in the DME- FC 034AEF Exhaust Cold Start, Not Controllable
MC-11028920-0001.pdf
SIB 65 27 25 (2026-02-11)
BMW X1 2025,2026
BMW X2 2026
(plus 13 other models)
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the infotainment system such as: Resets of the head unit Delayed start-up of the head unit (longer than 30 seconds) Failed start-up of the head unit Sporadic or permanent problems with navigation Sporadic or permanent Bluetooth connection problems Sporadic or permanent audio problems Sporadic or permanent speech / IPA (international phonetic alphabet) problems Missing displays, radio stations, camera images or applications
MC-11028927-0001.pdf
SIB 31 01 26 (2026-02-04)
BMW X1 2024
BMW X2 2024
(plus 5 other models)
SUSPENSION
When driving over an uneven road surface, a “thumping” noise can be heard from the front axle. Seeattached video V 31 01 26. Under certain weather conditions, a “groaning” noise may be heard during steering movements
MC-11028921-0001.pdf
SIB 28 01 25 (2026-01-27)
BMW X1 2024,2025,2026
BMW X2 2024,2025,2026
POWER TRAIN
SITUATION A Check Control message (CCM) displays for “Transmission oil service required” (ID 2120). This warning will typically trigger based on one of the following that applies: From 60,000 miles (~95,000 km) to 78,000 miles (~125,000 km), or After six (6) years: The “six years” time interval is determined the production date of the vehicle. It is not based on the day/date of the first registration, or the completion date of the pre-delivery check (PDI). If the vehicle is driven more than approx. 1900 miles (~3,000 km) after the first CCM, then a secondmessage will be display for “Transmission fault!” (ID 368). Note: If this service appears to have prematurely displayed as due, please follow standard technical reporting procedures before proceeding.
MC-11027985-0001.pdf
SIB 65 02 26 (2026-01-16)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
While using BMW Intelligent Personal Assistant, the activation word (“Hey BMW”) must be reactivated afterevery terminal change, BMW Remote Software Upgrade; or customer profile change. Additionally, after a BMW Remote Software Upgrade, the setup process for the voice assistant must be runagain. This was not the case previously.
MC-11027776-0001.pdf
SIB 51 01 26 (2026-01-06)
BMW X1 2025
(plus 4 other models)
UNKNOWN OR OTHER
A reference label for the tailgate SmartOpener (SMO) function (aka “touchless open,or “kick to open”) was mistakenly applied tothe bottom edge of the tailgate trim panel(either of the general locations circled) duringvehicle production.
MC-11027767-0001.pdf
SIB 31 01 22 (2026-01-03)
BMW X1 2023,2024
BMW X2 2023,2024
(plus 17 other models)
SUSPENSION, WHEELS
During inspection and/or diagnosis there is noticeable dirt/grease buildup on the axles near the inner and/orouter CV boots.
MC-11027761-0001.pdf
SIB 65 28 25 (2025-12-10)
BMW X1 2026
BMW X2 2026
ELECTRICAL SYSTEM
The vehicle may experience various operational issues with the Multifunction Display such as: Intermittent black screen Permanent black screen Intermittent head unit functions not displayed (i.e., Navigation screen only is black)
MC-11026964-0001.pdf
SIB 54 03 25 (2025-11-20)
BMW X1 2025
STRUCTURE: BODY
Contamination on the outer track(s) of thes unroof cassette. This can occur on either one or both side of the sunroof cassette.
MC-11025677-0001.pdf
SIB 16 01 24 (2025-11-12)
BMW X1 2024,2025
(plus 7 other models)
ELECTRICAL SYSTEM, FUEL SYSTEM, GASOLINE
RSU availability. The engine cranks but will not start.
MC-11025670-0001.pdf
SIB 36 02 25 (2025-11-06)
BMW X2 2024,2025
(plus 6 other models)
STEERING, WHEELS
The wheel bearing and the brake disc are not correctly aligned; are not concentric (circled). When applicable work is being performed, it is therefore difficult to remove the wheel bolts from, or fasten them into the wheel bearing hub.
MC-11025672-0001.pdf
RECALL 25V717000 (2025-10-22)
Affecting 1024 total vehicles built between 2025-07-30 and 2025-09-27
BMW X1 2026
BMW X2 2026
(plus 3 other models)
SEAT BELTS: REAR/OTHER: RETRACTOR
BMW of North America, LLC is recalling certain 2026 2 Series Gran Coupe, X1, X2, and Mini Countryman S ALL4 vehicles. The housing pin in the rear (left and/or right) seat belt retractors may have been damaged during production, resulting in the retractor not locking the seat belt as intended. As such, these vehicles fail to comply to Federal Motor Vehicle Safety Standard number 209, "Seat Belt Assemblies."
RCRIT-25V717-4381.pdf
SIB 65 24 25 (2025-10-09)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
After the software update to version …25-07-5XX, currently connected Bluetooth devices are not able to automatically reconnect to the head unit 6 (HU-H6).
MC-11024342-0001.pdf
SIB 65 23 25 (2025-10-09)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
Occasionally the SiriusXM (aka SXM) Satellite Radio may be unavailable in the head unit 6 (HU-H6).
MC-11024341-0001.pdf
SIB 84 06 25 (2025-10-03)
ELECTRICAL SYSTEM
In some situations, an emergency call may be triggered in the vehicle without either the customer pressing the SOS Call button, or an airbag deployment event. In some cases, the customer may not even be inside the vehicle.
MC-11024211-0001.pdf
SIB 65 22 25 (2025-10-03)
ELECTRICAL SYSTEM
While using the BMW Intelligent Personal Assistant (IPA) to initiate a phone call to a specific contact, eitheranother contact is dialed, or the IPA cannot locate the requested contact.
MC-11024210-0001.pdf
SIB 34 08 25 (2025-09-18)
ELECTRICAL SYSTEM
Starting from I-level …24-07-500, it is possible that the Automatic Hold function is not automatically storedfor the next journey. The function must be activated again by the driver at the beginning of every trip. After asoftware update to 25-03-500 and higher, this occurs more frequently.
MC-11024205-0001.pdf
SIB 63 08 25 (2025-09-18)
EXTERIOR LIGHTING
The front interior reading light(s) (arrows) willrandomly turn ON and OFF while driving. The reading lights are normally activated by touching the small icons (circled).
MC-11023253-0001.pdf
SIB 52 12 25 (2025-09-18)
SEATS
A clicking noise can be heard from one or both front seat backrests. This noise is heard when leaning against the backrest of the seat or while the vehicle is cornering.
MC-11023249-0001.pdf
RECALL 25V616000 (2025-09-17)
Affecting 1571 total vehicles
BMW X1 2025,2026
BMW X2 2025,2026
SEAT BELTS: FRONT: RETRACTOR
BMW of North America, LLC is recalling certain 2025-2026 X1 and X2, MINI Cooper Convertible, MINI Cooper, Mini Countryman S ALL4, and 2025 MINI Countryman SE ALL4 vehicles. The torsion bar in both front seat belt retractors may have been damaged during production.
RCRIT-25V616-9357.pdf
SIB 61 15 25 (2025-09-03)
ELECTRICAL SYSTEM
SITUATION The power windows and exterior mirrors do not function on the driver and/or passenger side. The fault occurs on either driver or on the passenger side. It does not occur on both sides at the same time.
MC-11023250-0001.pdf
SIB 51 12 25 (2025-08-20)
BMW X2 2025
STRUCTURE: BODY
A “groaning” noise is heard from the tailgate when driving on rough roads.
MC-11022106-0001.pdf
SIB 51 03 24 (2025-08-20)
STRUCTURE: BODY
While opening any of the doors, a groaning sound is heard from the door brake. Doors open and close stiffly.
MC-11022103-0001.pdf
SIB 41 12 25 (2025-08-20)
BMW X2 2024,2025
STRUCTURE: BODY
MC-11022102-0001.pdf
SIB 63 10 23 (2025-08-19)
BMW X2 2024,2025
EXTERIOR LIGHTING, EXTERIOR LIGHTING: TAIL LIGHTS, VISIBILITY/WIPER
Condensation is present in the inner surface in one or both (inner and/or outer) taillamps.
MC-11022112-0001.pdf
SIB 65 10 25 (2025-08-12)
BMW X1 2024,2025
BMW X2 2024,2025
ELECTRICAL SYSTEM
In certain situations, a mobile device with Android operating systems (Google, Samsung, etc.) may not be able to connect to the vehicle OR the Android phone may not be able to connect via Android Auto.
MC-11022114-0001.pdf
SIB 65 18 25 (2025-08-08)
BMW X1 2024
ELECTRICAL SYSTEM
When the alarm system is activated and doors are locked, within a short period the doors will unlock, and a “double beep” acoustic confirmation is heard from vehicle.
MC-11021819-0001.pdf
SIB 63 04 18 (2025-07-21)
BMW X1 2024
(plus 47 other models)
AIR BAGS, ELECTRICAL SYSTEM, EQUIPMENT, EXTERIOR LIGHTING, EXTERIOR LIGHTING: HEADLIGHTS: DAYTIME RUNNING LIGHTS: BULBS, VISIBILITY/WIPER
One or more of the LED daytime running lights are dim or discolored.
MC-11020927-0001.pdf
SIB 66 09 25 (2025-07-14)
BMW X1 2025
BMW X2 2025
VISIBILITY/WIPER
When the rear-view camera display is activated, moving objects appear to be juddering in the image.
MC-11020917-0001.pdf
SIB 66 03 25 (2025-07-14)
BMW X1 2024,2025
BMW X2 2024,2025
ELECTRICAL SYSTEM, STRUCTURE: BODY
Check control message is displayed indicating the parking assistance systems have limited functionality dueto errors detected within PDC sensors. The warning indicates parking assistance features have limitedfunctionality while the errors continue to be detected. Following faults may be stored 8031BA Ultrasonic Sensor Rear Side Left Software Error 8031CO Ultrasonic Sensor Rear outer left Software error 8031AE Ultrasonic Sensor Rear Outer Right Software Error 8031A8 Ultrasonic Sensor Rear Side Right Software Error 8031B4 Ultrasonic Sensor Rear Middle Right Software Error 8031C6 Ultrasonic Sensor Rear Middle Left Software Error
MC-11020916-0001.pdf
SIB 34 10 25 (2025-07-14)
BMW X1 2024
BMW X2 2024
SERVICE BRAKES
After programming from the I-Levels between …24-03-505 and lower than …24-03-540 to I-Level …24-11-530 or higher, the following CCM may be displayed: “CCM-2525: Brake system. Drive at moderate speed”
MC-11020910-0001.pdf
SIB 61 10 25 (2025-07-02)
BMW X1 2024
BMW X2 2024
STRUCTURE: BODY
The washer fluid reservoir (filler neck circled)may be leaking, and drains out through thewheel well liner. When the vehicle is parked, apuddle of washer fluid may be present underthe right front corner.
MC-11020913-0001.pdf
SIB 41 05 25 (2025-06-27)
BMW X1 2024
BMW X2 2024
While attempting to fuel/charge the vehicle,the fuel/charge door will not open.
MC-11020066-0001.pdf
SIB 65 14 25 (2025-06-11)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
After the software upgrade to …24-11-5xx, the customer is no longer able to log onto Alexa in the vehicle.The system reacts to the customer’s voice (a blue line appears on the central display), but Alexa does notwork.
MC-11019573-0001.pdf
SIB 65 11 25 (2025-06-11)
BMW X1 2025
ELECTRICAL SYSTEM
When navigation is selected, only the start animation with the text “Starting navigation system...” isdisplayed. The Navigation application does not start. This only applies to vehicles where Navigation hasbeen enabled and has been verified to work previously.
MC-11019572-0001.pdf
SIB 34 04 25 (2025-06-11)
BMW X1 2023,2024
BMW X2 2023,2024
ELECTRICAL SYSTEM, SERVICE BRAKES
As a result of a data input error, certain fault memories are permanently stored. The permanent storage offault memories does not comply with the legal specifications of the authority (California Air Resources Board– CARB). The fault has no effect on the use of the vehicle by the customer.
MC-11019563-0001.pdf
SIB 12 04 25 (2025-06-11)
BMW X1 2023
BMW X2 2023
(plus 11 other models)
ELECTRICAL SYSTEM
EMISSIONS RECALL 25E-A02: PROGRAM CONTROL UNITS
MC-11019554-0001.pdf
SIB 65 35 24 (2025-06-03)
BMW X1 2024,2025
BMW X2 2024,2025
ELECTRICAL SYSTEM
Customers may report that the Central Information Display (CID) side of the Multifunction Display flickersonce on and off. This flickering is not continuous but may occur once every 15 to 50 seconds. No fault memory entry is stored for this customer complaint.
MC-11019580-0001.pdf
SIB 65 16 25 (2025-06-02)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
Customer may discover that after a sleep cycle, any paired Bluetooth devices may have been deleted from the head unit and any personalized menu settings may have been set back to factory.
MC-11019574-0001.pdf
SIB 66 07 25 (2025-05-30)
BMW X1 2024
BMW X2 2024
(plus 14 other models)
ELECTRICAL SYSTEM
The speed limit warning adopted speed, which is set by the customer, is automatically reverting to lowervalue after an extended duration of the sleep cycle.
MC-11018732-0001.pdf
SIB 84 02 25 (2025-05-13)
BMW X1 2024
BMW X2 2024
ELECTRICAL SYSTEM
When making phone calls via BMW Bluetooth (not Apple CarPlay) in the vehicle, the person in the calloutside the vehicle hears a distorted voice reproduction.
MC-11018554-0001.pdf
SIB 06 31 25 (2025-05-07)
BMW X1 2024
BMW X2 2024
POWER TRAIN
Inspection and Return - Output Drive Repair Kit
MC-11018832-0001.pdf
SIB 51 30 19 (2025-04-29)
(plus 16 other models)
STRUCTURE, STRUCTURE: BODY
A groaning noise is present from the door frame of any door, most commonly when driving over rough roadsor during body flex. This situation may be worse in vehicles which are regularly waxed in th e area of the door jamb.
MC-11017506-0001.pdf
SIB 65 08 25 (2025-04-28)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
Central Information Display (CID) side of the Multifunction Display may intermittently black out.
MC-11017569-0001.pdf
SIB 41 02 25 (2025-04-25)
BMW X2 2023,2024
STRUCTURE: BODY
While driving on a smooth and/or uneven road, a “popping” sound is heard from the bottom of the C-pillar area. This can occur on one and/or both sides on the vehicle C-pillars.
MC-11017277-0001.pdf
SIB 28 01 23 (2025-03-21)
POWER TRAIN
Check control message (790) “Emergency gearbox release activated” is displayed immediately after starting the engine. This applies only to U11 equipped with the 7-speed M-DCT transmission.
MC-11015855-0001.pdf
SIB 52 04 25 (2025-03-19)
BMW X2 2024,2025
SEATS
Customer states he/she sees a check control message for the rear seat not being locked. The following fault codes stored in the air bag ACSM6 control module: 930C19 - Backrest Sensor right 2nd seat row: open circuit 930D76 - Function rear restraint system restricted
MC-11015841-0001.pdf
SIB 65 03 25 (2025-02-28)
BMW X1 2023
The customer states that the air bag warning lamp is illuminated. A fault is stored in the airbag control module ACSM6 for either of the front seats: 930982 - side air bag PASSENGER : resistance too high 93097C - side air bag DRIVER : resistance too high
MC-11014668-0001.pdf
SIB 52 05 25 (2025-02-28)
BMW X1 2025
ELECTRICAL SYSTEM
The customer states: The driver’s seat will not return to its last saved position. No seat memory. The heated seats settings in the menu are missing/different than in their previous BMW vehicle. They canno longer select, under the climate rules, at what temperature Fahrenheit the heated seats willautomatically turn on. Certain other “apps” and functions are not available The driver’s seat moves to an unknown memory position
MC-11014660-0001.pdf
SIB 51 04 25 (2025-02-22)
BMW X1 2025
BMW X2 2025
STRUCTURE: BODY
BMW Service Action - Tailgate Lock B51 04 25
MC-11014969-0001.pdf
SIB 18 01 25 (2025-02-21)
BMW X1 2025
BMW X2 2025
POWER TRAIN
The rear silencer is discolored.
MC-11014423-0001.pdf
SIB 51 08 24 (2025-02-14)
BMW X1 2024
BMW X2 2024
UNKNOWN OR OTHER
The Augmented Reality Camera (ARCAM) shows up blurry when activated.
MC-11014509-0001.pdf
SIB 51 04 25 (2025-02-07)
BMW X1 2025
BMW X2 2025
STRUCTURE: BODY
Due to changes in the opening mechanism ofthe trunk/tailgate latch, it is possible that thetrunk/tailgate may not completely lock afterclosing it.
MC-11014036-0001.pdf
SIB 51 46 16 (2025-02-03)
BMW X1 2023,2024
BMW X2 2024
(plus 71 other models)
STRUCTURE: BODY, STRUCTURE: BODY: TAILGATE
Upon opening and closing the tailgate, a creaking/groaning sound can be heard from tailgate actuator.
MC-11014038-0001.pdf
SIB 34 01 24 (2025-01-29)
BMW X1 2024
After replacement of the Integrated Braking system (IB)/Power Brake the total distance covered might be lower than when handed over to the workshop for the repair.
MC-11013438-0001.pdf
SIB 63 04 24 (2025-01-10)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
After the vehicle has been programmed with either RSU (Remote Software Update) or ISTA (I-Level 24-07-5xx), the ambient light on the door panel speakers will only illuminate in white.
MC-11013053-0001.pdf
SIB 63 03 24 (2025-01-10)
BMW X1 2024
BMW X2 2024
UNKNOWN OR OTHER
The welcome light image displayed from the exterior mirror assembly is distorted.
MC-11013052-0001.pdf
SIB 61 11 24 (2025-01-07)
BMW X1 2023,2024
BMW X2 2023,2024
ELECTRICAL SYSTEM
After performing a BMW Remote Software Upgrade (RSU), the functionality of the Comfort Access and Passive Go/Exit features may be reduced.
MC-11013050-0001.pdf
SIB 65 40 24 (2024-12-27)
BMW X1 2024
BMW X2 2024
ELECTRICAL SYSTEM
Customers may report various issues in the vehicle, to include: Bluetooth Malfunctions Head Unit Performance Telephony Malfunctions
MC-11012101-0001.pdf
SIB 28 02 24 (2024-12-20)
BMW X1 2023,2024
BMW X2 2023,2024
POWER TRAIN
Micro-movements combined with frictional corrosion can increase wear on the longitudinal splined connection between the double clutch transmission (DCT) and the transfer box.
MC-11012087-0001.pdf
SIB 61 30 24 (2024-12-19)
BMW X1 2023,2024
BMW X2 2023,2024
ELECTRICAL SYSTEM
Due to a software error in the Basic Central Platform (BCP), Remote Software Upgrade (RSU) is no longerpossible.
MC-11012092-0001.pdf
SIB 51 29 24 (2024-12-05)
BMW X1 2023
BMW X2 2023
STRUCTURE: BODY
The tailgate/trunk will not latch when closed.
MC-11012082-0001.pdf
RECALL 24V829000 (2024-11-04)
Affecting 3312 total vehicles
BMW X1 2025
STRUCTURE: BODY: ROOF AND PILLARS
BMW of North America, LLC (BMW) is recalling certain 2025 X1 xDrive28i and X1 M35i vehicles. The left and right-side B-Pillar reinforcement plates may have been manufactured with insufficient structural strength.
SIB 65 31 24 (2024-10-22)
BMW X1 2024
BMW X2 2024
ELECTRICAL SYSTEM
When the customer attempts to use the Bluetooth system, they find it is not functioning. It is not possible toestablish a connection to any paired devices. Additionally, the Bluetooth function can no longer be activatedin the Mobile Device menu. The following fault memory entries are present: A76319 - Bluetooth module: Communication to hardware failed B7F921 – BT/Wi-Fi function is not available
MC-11009418-0001.pdf
SIB 65 29 24 (2024-10-19)
ELECTRICAL SYSTEM
During a parking maneuver with activated Park Distance Control (PDC), intermittently the parking instructions displayed in the Central Information Display (CID) are shown in German. The text in the instructions read: "Mit dem Parken beginnen" or “Einparken Starten” (start parking).
MC-11009003-0001.pdf
SIB 34 03 24 (2024-10-11)
BMW X1 2024
BMW X2 2024
SERVICE BRAKES
Improved diagnostic software for the brake system.
MC-11008992-0001.pdf
RECALL 24V739000 (2024-10-02)
Affecting 11579 total vehicles built between 2022-11-12 and 2023-10-18
BMW X1 2023
(plus 15 other models)
ELECTRONIC STABILITY CONTROL (ESC), SERVICE BRAKES, HYDRAULIC: POWER ASSIST: ELECTRIC: CONTROL MODULE
BMW of North America, LLC. (BMW) is recalling certain 2023-2024 X1, X5, X6, X7, XM, 530i, i5, 740i, 760i, i7, and 750e vehicles. Please see the recall report for a complete list of models and model years. The integrated brake (IB) system may malfunction and result in a loss of power brake assist or cause the Antilock Brake (ABS) and Dynamic Stability Control (DSC) systems to not function properly.
RCRIT-24V739-1109.pdf
RCRIT-24V739-5692.pdf
RCRIT-24V739-5275.pdf
RCRIT-24V739-9702.pdf
RCRIT-24V739-5310.pdf
RECALL 24V697000 (2024-09-19)
Affecting 309 total vehicles built between 2024-05-08 and 2024-05-08
BMW X1 2023,2024
BMW X2 2024
ELECTRONIC STABILITY CONTROL (ESC): CONTROL MODULE, SERVICE BRAKES, HYDRAULIC: ANTILOCK/TRACTION CONTROL/ELECTRONIC LIMITED SLIP: CONTROL UNIT/MODULE
BMW of North America (BMW) is recalling certain 2023-2024 X1, 2024-2025 X5, 2025 X6, 2023-2025 X7, 740i, 760i, 2024 XM, 530i, 540i, i7, 750e, X2, 2024-2025 i5, 2024 Rolls Royce Spectre, 2025 MINI Countryman S ALL4, JCW Countryman ALL4, and 2025 MINI Hardtop 2 Door (Cooper, Cooper S) vehicles. Please refer to the recall report for the complete list of models. The welds in the servomotor of the integrated brake control module may break, causing a loss of power brake assist and rear brake function. In addition, the Antilock Brake System (ABS) and Dynamic Stability Control (DSC) system may not function.
RCRIT-24V697-3953.pdf
RCRIT-24V697-3624.pdf
RCRIT-24V697-4497.pdf
RCRIT-24V697-5803.pdf
RCRIT-24V697-1756.pdf
RCRIT-24V697-2103.pdf
RCRIT-24V697-2669.pdf
RCRIT-24V697-8245.pdf
RCRIT-24V697-2666.pdf
RCRIT-24V697-8204.pdf
RCRIT-24V697-4928.pdf
RCRIT-24V697-6869.pdf
SIB 65 24 24 (2024-09-12)
BMW X1 2024
BMW X2 2024
ELECTRICAL SYSTEM
The vehicle may have issues with SiriusXM operation. Specifically, SiriusXM may not be available oroperating in the vehicle; OR SiriusXM audio is interrupted sporadically. The following faults may be stored in the head unit (HU-H6): B7F912 – “Communication between SDARS application and RAM SXM module is not possible” B7F924 – “SDARS SXM360L function not available”
MC-11008123-0001.pdf
SIB 65 23 24 (2024-09-11)
BMW X1 2024
BMW X2 2024
ELECTRICAL SYSTEM
Various concerns with Bluetooth operation may be reported in the vehicle, including: The Bluetooth connection between the vehicle and telephone breaks down sporadically. The devicecan be paired again. The Bluetooth connection between the telephone and the vehicle breaks down. The device can nolonger be paired. The initial pairing of the telephone with the vehicle is not possible No fault memory entry is stored for these customer complaints.
MC-11008122-0001.pdf
SIB 65 22 24 (2024-09-11)
BMW X1 2024
BMW X2 2024
ELECTRICAL SYSTEM
Various concerns with Apple CarPlay may be reported in the vehicle, including: The Apple CarPlay connection is sporadically terminated The connection to Apple CarPlay cannot be established Apple CarPlay cannot be activated No fault memory entry is stored for these customer complaints.
MC-11008121-0001.pdf
SIB 12 07 23 (2024-08-26)
BMW X1 2023,2024
ELECTRICAL SYSTEM, ENGINE, ENGINE AND ENGINE COOLING
Vehicle exhibits a slight acceleration delay when taking off from a MSA (automatic engine start-stop function) stop.
MC-11006720-0001.pdf
SIB 28 03 24 (2024-08-16)
BMW X1 2024
POWER TRAIN
There is a “rattling/clattering” noise from the engine compartment area. The noise is mostly perceptible when driving past a wall with the side window of the driver's door open(sound reflection). The noise complaint can occur in the following situations: Constant-speed driving on rough road surfaces: Speed range 5 - 11 mph, 1st or 2nd gear, accelerator pedal position: lower partial load range Uphill driving: Driving off forwards in 1st gear, uphill Driving off backwards (reverse gear), uphill Downhill driving: Driving off in 1st gear, downhill Driving off in reverse, downhill Stopping on a hill: Driving off in 1st gear, uphill driving, then stopping Driving off in 1st gear, downhill driving, then stopping Driving in reverse, uphill driving, then stopping Driving in reverse, downhill driving, then stopping Overrun (off throttle)/traction (engine brake) and traction/overrun transitions (throttle to off throttle,vice versa): Speed range5 - 11 mph, 1st or 2nd gear, accelerator pedal position: lower partial load range Speed range 0 to 2 mph, reverse gear, accelerator pedal position: lower partial load range Very slow speeds 0 –3 mph Driving off without pressing the accelerator pedal, with or without the brake applied: 0 to 3 mph Driving at a constant speed without pressing the accelerator pedal, with the brake applied: approx. 2mph Brake the vehicle to a full standstill
MC-11006726-0001.pdf
SIB 28 01 24 (2024-08-16)
BMW X1 2024
POWER TRAIN
Micro-movements combined with frictional corrosion can increase wear on the longitudinal splinedconnection between the double clutch transmission (DCT) and the transfer box.
MC-11006724-0001.pdf
SIB 52 02 24 (2024-08-07)
BMW X1 2023,2024
BMW X2 2023
AIR BAGS, ELECTRICAL SYSTEM, SEAT BELTS, SEATS
Customer states they started to receive Check Control messages for the driver’s seat at the end of eachdriving cycle: One or more of the following check control messages (CCM) were present at that time: CCM 434 Seat calibration required. CCM 108 Driver restraint system. Eventually multiple restarts after they first noticed the CCM the seat stopped functioning, the air bag warninglamp illuminated in the instrument cluster, and they received a new Check Control message: CCM 97 Restraint system. There are now 6 DTC faults stored: ACSM6 Air Bag module 930D86 - Function restraint system driver restricted. C95432 - seat module Driver (seat memory), message status backrest locking standardization required. C95434 - seat module Driver (seat memory), message status backrest locking standardizationrecommended. FAS_I20 Driver's Seat module 8029F5 - initialization seat: limited seat adjustment due to missing calibration 802A03 - Functions seat adjustment FAS limited available. 802A05 - ÜKB: Shut-off ÜKB because of missing calibration. Also, one or both of the following check control messages (CCM) may currently be present: CCM 108 “Driver restraint system” CCM 109 “Passenger restraint system” The seat initialization and memory has been lost. Or Repeat failure of seat initialization after completing the test module via ISTA.
MC-11006734-0001.pdf
SIB 11 01 24 (2024-07-25)
BMW X1 2024
ENGINE
The vibration dampener side cover may not have been pressed in correctly, resulting in a vibration or arough running sensation.
MC-11005211-0001.pdf
SIB 66 04 24 (2024-07-16)
BMW X2 2023
VISIBILITY/WIPER
The washer fluid cleaning system has air remaining in its components, and/or the fluid lines after a previous repair has been performed. The previous repair may have involved draining, opening, and replacingcomponents in the system.
MC-11005246-0001.pdf
SIB 65 09 24 (2024-07-03)
BMW X1 2023,2024
BMW X2 2023
ELECTRICAL SYSTEM
Quality improvements and robustness measures are to be implemented on the affected vehicles via thissoftware update. The software update improves functions in the following areas of the vehicle: Bluetooth malfunctions The start-up phase of the HU has been shortened (faster start of the operating system) The number of disconnections from Apple CarPlay have been reduced Vehicle access and the drive-ready state have been improved The AC charging abort error has been fixed Remote Control Parking without function
MC-11005241-0001.pdf
SIB 65 10 24 (2024-06-28)
BMW X1 2023,2024
BMW X2 2023
ELECTRICAL SYSTEM
Quality improvements and robustness measures are to be implemented on the affected vehicles via thissoftware update. The software update improves functions in the following areas of the vehicle: Bluetooth malfunctions The start-up phase of the head unit (HU) has been shortened (faster start of the operating system) The number of disconnections from Apple CarPlay have been reduced Vehicle access and the drive-ready state have been improved The AC charging abort error has been fixed Remote Control Parking without function
MC-11002657-0001.pdf
SIB 84 02 24 (2024-05-24)
BMW X2 2023
ELECTRICAL SYSTEM
The Check Control Message “Emergency call not available” is displayed to the customer. Check Control Message 299 is stored in the Instrument Cluster check control message list or in the vehiclekey data. This fault may be intermittent and can heal itself after a drive cycle. It may no longer be displayed to the customer in the next life cycle.
MC-11000566-0001.pdf
SIB 63 01 24 (2024-05-22)
BMW X1 2024
BMW X2 2023
EXTERIOR LIGHTING
The overhead reading lights are not bright enough on SP21 (Service Pack 2021) vehicles.
MC-11000509-0001.pdf
SIB 65 06 24 (2024-05-20)
BMW X1 2024
BMW X2 2023
ELECTRICAL SYSTEM
In certain vehicles, the speeds in the Active Safety menu may be incorrectly displayed as 0 miles per hour(MPH).
MC-11000528-0001.pdf
SIB 61 03 23 (2024-04-26)
BMW X1 2023
BMW X2 2023
ELECTRICAL SYSTEM, EXTERIOR LIGHTING, POWER TRAIN
The buttons on the GWS do not work, or the function indicator lighting has failed. One or more of the following faults are saved in the fault memory for the GWS : 80268E - Park button sticking and/or 80268F - Parking button defective and/or 802680 - Functional display defective and/or 802681 - Locator lighting defective and/or 802691 - Release button fault
MC-10253730-0001.pdf
SIB 51 10 24 (2024-04-15)
BMW X1 2023,2024
ELECTRICAL SYSTEM
The tailgate sporadically fails to open when signaled via- The interior button (driver" s door panel) Button on key fob The switch on the tailgate (inside or outside) In some cases, the tailgate will release and open only a short distance before stopping.
MC-10253346-0001.pdf
SIB 51 11 23 (2024-04-11)
BMW X1 2023
LATCHES/LOCKS/LINKAGES, STRUCTURE
1. While driving on a smooth paved road, acracking sound can be heard coming from theright-side luggage compartment capping trimpanel. 2. While driving on a smooth paved or rough road, a cracking sound can be heard coming from the D-pillar trim panel. The sound can occur on one or both sides (left and/or right).
MC-10253329-0001.pdf
SIB 61 27 23 (2024-03-15)
BMW X1 2023,2024
The original Conditioned Based Service (CBS) Key data point closed with 23-07 soft ware, all CBS systems are now collectively under analysis.
MC-10252023-0001.pdf
SIB 51 06 24 (2024-03-07)
BMW X1 2023,2024
SEAT BELTS, STRUCTURE
An interference noise (rattling noise) can be heard near the rear center seat" s safety belt feed trim (circled) in the headliner.
MC-10252043-0001.pdf
SIB 65 05 24 (2024-02-16)
BMW X1 2024
BMW X2 2023
ELECTRICAL SYSTEM, VISIBILITY
When the Rear View Camera is activated, the Park Distance Control (PDC) display on the central information display (CID) may not display, or may display with errors.
MC-10250376-0001.pdf
SIB 61 05 27 (2024-02-14)
BMW X1 2023,2024
ELECTRICAL SYSTEM
The Early Quality Feedback process is used to detect customer-relevant faults at an early stage. Thisenables rapid defect elimination in production and the fastest possible provision of service solutions. As part of the quality monitoring of the BMW X1 (development series U11) vehicles, we are asking for yoursupport. We request you to report all issues and solutions related to transportation check control messages(CCM) 460 and 461 in a TSARA (Technical Support and Research Assistant) "Information Only" case. Check Control messages (CCM) affected: Check Control 460: Current state of chargeof the 12V battery during transport. The batteryexhibits preliminary damage. Check Control 461: Current state of chargeof the 12V battery during transport. (State ofcharge too low -> recharge)
MC-10250373-0001.pdf
This is an automated post created with code written by a human.
Appreciate7
01-06-2026
analogue
937 REP
SIB 12 03 24 (2025-12-17)
BMW X1 2025
BMW X2 2025
MC-11026948-0001.pdf
BMW X1 2026
BMW X2 2026
ELECTRICAL SYSTEM
SIB 65 27 25 (2025-12-09)
BMW X1 2026
BMW X2 2026
ELECTRICAL SYSTEM
MC-11026963-0001.pdf
Appreciate3
01-14-2026
schnell325 user avatar
schnell325
Bored at work....
1,144 REP
5.7K POSTS
Wow! Thank you
Appreciate0
01-23-2026
analogue
937 REP
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
BMW X1 2025
UNKNOWN OR OTHER
BMW X1 2023,2024
BMW X2 2023,2024
SUSPENSION, WHEELS
Appreciate0
02-03-2026
analogue
937 REP
POWER TRAIN
Appreciate0
02-03-2026
markronnie user avatar
markronnie
BMW Owner
612 REP
1.3K POSTS
WOW!! Would I be correct in saying there seams like a larger number of issues with the new generation x1 & 2 effecting some builds than others models & brands? Or is the quantity average/typical?
Appreciate0
02-03-2026
paulockenden user avatar
paulockenden
Complete and Utter…
1,244 REP
2.1K POSTS
Very typical.
Appreciate1
02-24-2026
analogue
937 REP
SIB 33 01 26 (2026-02-18)
BMW X1 2023,2024
BMW X2 2023,2024
SUSPENSION
MC-11028922-0001.pdf
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
BMW X1 2025
BMW X2 2025
SUSPENSION
BMW X1 2024,2025
BMW X2 2024,2025
BMW X1 2025,2026
BMW X2 2026
ELECTRICAL SYSTEM
BMW X1 2024
BMW X2 2024
SUSPENSION
SIB 61 01 26 (2026-02-02)
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
SITUATION During vehicle start-up the Secure Element (SE) of the BCP may fail causing communication errors. TheCheck Control message “Drive carefully. Driving stabilisation.” will appear. In addition, the fault memoryentries below will be stored within 40 seconds of each other. ACSM: 02010A - Coding: Coding data not qualified VIP: 02390A - VIP control unit: Coding data not released, signature IB: 02290A - DSC control unit: Coding data not released, signature HKFM: 020D0A - HKFM: Coding data are not qualified
MC-11028925-0001.pdf
Appreciate0
03-14-2026
analogue
937 REP
SIB 12 03 26 (2026-03-11)
ELECTRICAL SYSTEM
BMW AG is conducting Voluntary Emissions Recall (effective March 11, 2026) on certain Model Year 2023 -2026 BMW vehicles that were produced between January 14, 2022, and September 16, 2025.
MC-11030061-0001.pdf
BMW X1 2023,2024
BMW X2 2023,2024
SUSPENSION, WHEELS
1. Noise complaint: Humming or clicking type noise in the speed range of 15 ? 65 mph can be heard from the rear axle. Seeattached video ?V33 01 26 Humming? and ?V33 02 26 Clicking? The noise may be amplified depending on road speed. Or 2. Fault memory entry: Customer has Dynamic Stability Control malfunction indicator lamp and/or related Check Control Message. The following fault codes are found in the Integrated Brake module fault memory: 4809B7: Wheel speed sensor - rear left - tooth missing 4809C2: Wheel speed sensor - rear right - tooth missing 480AB4: Wheel speed sensor - rear right ? noise monitoring 480AAD: Wheel speed sensor - rear left ? noise monitoring
Appreciate0
04-28-2026
analogue
937 REP
New 2026-04-28
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
BMW X1 2025
BMW X2 2025
ELECTRICAL SYSTEM
Appreciate0
