06-19-2006, 04:15 PM | #1 |
Rep 369
Lexus IS350 Dyno results
Just thought I might share this with you guys. Pardon me if it has already being posted before.
HP from engine is 306, dyno result is 268= 87.5% efficiency Torque from engine is 277, dyno result is 231 ft.lbs=83.40% efficiency http://www.dragtimes.com/2006-Lexus-...aphs-8856.html |
06-19-2006, 04:34 PM | #4 |
Rep 1,024
You might notice, the run listed as #1 is the baseline run, the #2 run appears to be with a Dual Exhaust. The base IS350 appears to be 246hp 212ft/lb.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
06-19-2006, 04:58 PM | #5 |
Rep 548
Here's another 350, with similar HP numbers as the baseline run on the other car. Only upgrade is an intake inlet pipe -- stock airbox and filter remain.
http://www.dragtimes.com/Lexus-IS350-Timeslip-9020.html |
06-19-2006, 05:09 PM | #6 |
Rep 1,069
the 246 hp # seems about accurate...80% efficiency for toyota drivetrain
The bmw will be closer to about 88-90% efficiency producing about 225-230hp.
2019 G20 330i RWD
2014 F30 328i RWD 2009 E90 328i RWD 2006 E90 330i RWD 2002 E46 330i RWD |
06-19-2006, 05:24 PM | #7 | |
Rep 369
06-19-2006, 05:28 PM | #8 | |
Rep 1,069
2019 G20 330i RWD
06-19-2006, 06:18 PM | #9 |
Rep 2,067
In the engine section of this site, a few California members were nice enough to post up their dynos from a recent dyno get-together. The manual 330i put down in the range of ~210 and ~195 for the auto.
06-19-2006, 07:44 PM | #10 | |
Rep 884
BMW, Lexus, and everybody else use the same basic drivetrain configuration (to such an extent that almost all of them subcontract the production and even the design of components such as transmissions), and most of the losses are due to friction within the mechanical portions of the drivetrain itself. Some companies have slightly more efficient drivetrains, though the use of more efficient alternators and other parasitic devices (like the electric water pump in the E90), but it's not so significant that it could account for 10% of a difference or more. The bottom line is that virtually all manufacturers underrate the stated output of their engines to some extent for a number of reasons. BMW in particular has been known to significantly underrate - if a given car or model appears to have an unusually small drivetrain loss (a very efficient RWD drivetrain will lose 15%), it is almost certainly due to the fact that the engine is making more power at the crank than the manufacturer claims.
Avid collector of the very finest Deutscher Schrott
06-19-2006, 07:46 PM | #11 | |
Rep 1,024
06-19-2006, 09:34 PM | #12 | |
Rep 369
Thanks for pointing that out to me. |
06-19-2006, 10:33 PM | #13 |
Rep 6,750
Cool stuff. Thanks for posting this. That LMS aftermarket exhaust seemed to increase the wHP by 22, a 9% increase. Ambient temp was also only 69 degrees and about the same despite the different run dates.
The link to the California dyno runs is http://www.e90post.com/forums/showthread.php?t=22625 and in my sig. |
06-21-2006, 06:52 PM | #14 |
Rep 10,407
interesting
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
