New PROcede beta maps posted (v3.2 2-19)
02-20-2009, 12:30 AM | #1 |
1750
Rep 17,960
Drives: A Lot
More user adjustables! Pre-set datalog variable set-up! New fandangled maps!
Maps/firmware Posted here: http://216.120.252.228/forum/showpos...78&postcount=2 Make sure you download the new self-installable User Software posted here: http://www.vishnutuning.com/Pde_Reader.zip Make sure you use Window's add/remove software utility to remove the old version of the PROcede software before installing this new version. I also updated the User Adjustable Parameter documentation. Check it out here: http://216.120.252.228/forum/showthread.php?t=1002 Cheers, Shiv |
02-20-2009, 01:00 AM | #5 |
1750
Rep 17,960
Drives: A Lot
02-20-2009, 02:34 AM | #7 |
Rep 7,705
worked fine on my Win Vista based PC. peak boost 14.3 psi @ 4830 rpm...oh and I left everything in Default setting. Car feels great as it is so why bother seriously...PROceed is the S***! LOL
02-20-2009, 02:48 AM | #8 |
Rep 1,217
Drives: 2014 435i
Good stuff Shiv!
Couple of things though: -For those of us running 32.1, do you still recommend the lag fix be turned on? -In the User Adjustables Explained documentation under User Torque Map1 it says the default should be 80% should that be 90%? Cheers! |
02-20-2009, 04:49 AM | #10 | |
Bodhisattva
14
Rep 181
The new user adjustable parameters look just like you showed us they must look like. Thanks
Salut, Gilles! 335I E92 6AT - V3.2 - GRUPPE M - FMI - RR DOWNPIPES - AE EXHAUST HFC |
02-20-2009, 06:08 AM | #11 |
Rep 2,320
this table is for people that use 3.2 sw in a bmw or its for people that have also 29.2 or pre 29.2? as i understand its just an exsample?
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
02-20-2009, 06:36 AM | #12 |
54
Rep 886
Do you already have RevII? You'll se this "table" with any version of your DME software.
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
02-20-2009, 08:42 AM | #13 |
Rep 2,320
i was just checking are those numbers in a collums are different in each stage
still waiting for better dolar rate (USD 2,7411 +0,0036) hope it will go down a little
02-20-2009, 08:55 AM | #15 |
Rep 677
No, 100% in stage 0 is not 100% in stage 3. The map itself is different and needs to correspond with your mods.
59 Corvette, 72 240Z, 73 Espada, ZXR
02-20-2009, 09:03 AM | #16 |
she likes the flavor......
85
Rep 1,622
yeah new maps!
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
02-20-2009, 09:09 AM | #18 |
Rep 2,320
thanks so in stage 1 also numbers are different
02-20-2009, 09:14 AM | #20 |
Rep 2,320
thanks jpsimon so that tables data is okay to use on STAGE 1? dd and nondd map
02-20-2009, 09:21 AM | #21 |
Team Zissou
3084
Rep 10,198
02-20-2009, 09:33 AM | #22 |
Rep 2,320
thanks jpsimon, your help is always appreciated
thanks again, and that section LAG FIX 1 if i have 29.1.1 i can make LAG FIX 0, so my sw not has that lag, but if i leave it 1 is it gona be a difference?
