Car Juddering after braking at speeds
03-09-2009, 02:23 PM | #1 |
Rep 1,798
I was noticing it just last week, that when I brake at speeds; the car judders (can feel the vibration on the steering). My car has only done 2600 miles, and I have only taken it only once to Abingdon trackday; and so could not be a warped disc or a cracked disc? Could it? Or maybe it has not been broken in properly? maybe the deposits begins to transform into cementite?
I normally drive like pipe and slippers as well. Have booked myself into Scotthall to have it checked out this Friday. Anyone experienced this on their car with little mileage? Cheers.
03-09-2009, 02:44 PM | #2 | |
Rep 5,493
Juddering from braking at speed indicates one of two things - warped disc from overheating (which is possible after a trackday) or pad imprint on the disc leading to an imperfect surface. The way to find out which one it is is to try and deglaze the discs - find an empty stretch of road, accelerate to 40mph, then brake hard in a straight line to 10mph - do not brake to a standstill. Immediately get on the gas again and accelerate to 50mph. Brake hard again to 10mph, then immediately get on the gas to 60mph. Do two or three repeats of hard braking from 60mph to 10mph, then drive normally without braking for a few miles to cool the brakes. This process will deglaze the discs from having any imperfect pad imprint. If braking thereafter is still juddery, the likelihood is the discs are warped.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review Last edited by E92Fan; 03-10-2009 at 04:59 AM.. |
03-10-2009, 04:54 AM | #4 |
Rep 8,811
Good tip Tony!
03-10-2009, 05:34 AM | #5 |
Dimmer than a dim thing
80
Rep 1,291
Drives: M4 GTS, EQC, X5 40d, simrig
Great advice as always Tone....
My discs have 18k miles on them now and I do get a bit of a noise when using them hard, but this apparently is caused by the drilled holes becoming a bit clogged up with brake dust. There is no juddering or vibration in the steering wheel, just audioble noise... I was concerned at first, but a collegues 996C4S is the same. My instinct is no matter what condition your disks are in the dealer will claim "harsh use, improper warming up before such use.... and the disks are warped"... I guess a lot depends on your dealers honesty. (did I just use dealer and honesty in the same sentence ?!) |
03-10-2009, 05:40 AM | #6 | |
Rep 5,493
The noise generally is either the pad wearing down, or the holes becoming clogged as you've said. And as you've said, dealers will use every which way to get out of replacing discs, especially on a car like an M3. However, as you well know there are some dealers who are a little more understanding than others
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
03-10-2009, 07:38 AM | #7 | |
80
Rep 1,291
03-10-2009, 07:53 AM | #8 | |
Rep 8,111
Air-line is easier and you don't have to bother your arse taking the wheels off. Don't breathe it in though....
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-10-2009, 07:57 AM | #9 |
80
Rep 1,291
03-10-2009, 03:45 PM | #10 |
Rep 1,798
Who is doing your exhaust Paul? And whats the setback?
03-11-2009, 04:38 AM | #11 |
80
Rep 1,291
BMSport are doing the exhaust. I'm getting a deal as they will have had my car for two weeks to use as a template Not sure what the finished price will be, but I'm sure it'll be competative to other systems out there.
Can't frekin wait ! |
