Procede - 335i installed WOW
03-14-2009, 12:16 AM | #1 |
Rep 5,018
Drives: VALNCYA
Hey guys
installed my procede rev1 and wow is this thing fast 125 mph 4th gear one thing i am disappointed in is the governor kicked in at 137...doesn't the procede remove this? Thanks for your help guys and girls love the boards and loving my 335i |
03-14-2009, 12:31 AM | #3 |
Stuntin'.
22
Rep 583
Drives: //Mtrey/K7 GIX600
congrats man! does your 4th really top out at 125? im sure mine redline 4th exactly at 140mph.
03-14-2009, 12:36 AM | #4 |
Rep 5,018
Drives: VALNCYA
idk i wasn't looking that closely lol
i wanted to top it out but it stopped do we know why fellas? did i miss a setting on the programming of the map? |
03-14-2009, 05:30 AM | #5 |
Rep 677
You have to switch the limiter off in the map. default setting is limit on. Hook on your pc, start the procede sw and go to user adjust.
59 Corvette, 72 240Z, 73 Espada, ZXR
03-14-2009, 08:12 AM | #7 |
Rep 5,018
Drives: VALNCYA
Speed Delimiter was at 1 ON ! opps lol NOW its off
any suggestion guys on stage one setup in the user values? Current: Map 1 i want to make stock (dont know those values maybe someone can assist) Map 2 Boost 18 User Tq 90.1961 1st & 2nd Gear Tq 100% Throttle Response 1 all others r default any suggestions would be awesome as im new to this procede i only run 93 or 94 at the lowest i may do more mods then use some CT16 there are a few guys out here in NJ who sell it thanks guys ! |
03-14-2009, 08:50 AM | #9 | |
Rep 10,587
to make map 1 stock you just switch user tq to something like 25% or even 0%, play around with it, you might find you prefer to have a bit more than stock, say boosting 11psi or so. on map 2, leave it alone at 90% unless your mixing in some race gas I think. since you have an xi, you dont need to reduce TQ in the 1st 2 gears, traction won't be your problem.
03-14-2009, 09:00 AM | #10 |
Rep 5,018
Drives: VALNCYA
yea also last nite i reved it up to 5k rpm n tried to launch but the clutch stayed to the floor...is that normal so u cant launch / burn the cluch?
can i raise my speed limit on the XI? i did 137 last night and it just stayed there |
03-14-2009, 09:00 AM | #11 |
Rep 1,306
To make Map 1 stock, set the the UT to 0%. On map 2 I'd suggest setting the Throttle to 5. Also, speed delimiter should be set to 1. This will DElimit your top speed. Where ya at in NJ?
03-14-2009, 09:16 AM | #12 |
Rep 340
That's a new record logged on this procede. Did you mean a 16psi for boost limit vice 18? I don't think I touching the boost settings. Do you have a boost gage? I agree with the others i wouldn't adjust the torque settings. I can attest that raising the torque values doesn't always increase performance. I dialed this in at the drag strip and on that particular day lower torque values resulted in the best et's. hope this helps.
03-14-2009, 11:33 AM | #13 | |
Member
28
Rep 344
Present - 2016 340i, Alpine White, Black, M-sport, 6-spd, Track Handling, Tech pkgs
Past - 2011 E90 335i, Alpine White, Ivory, Sport, Premium, Steptronic Past - 2008 E90 335i, Titanium Silver, Dakota Grey, ZSP, Steptronic, 6FL, Wagner FMIC, Bilstein B12 Pro-kit, M3 control arms, SS F/R brake lines |
03-14-2009, 06:04 PM | #15 |
Rep 5,018
Drives: VALNCYA
with the delimiter off still only runs to 137 !! UGH !!
throttle response at 5 this thing is fast fast fast fast i just drove from Bergen County to mystic connecticut had my gf in the car took that thing up to 120 she even thought it was fast lol but the delimiter still on wtf?! SHIV HELP ME OUT |
03-14-2009, 06:05 PM | #16 |
Rep 5,018
Drives: VALNCYA
psu i put up the doomsday map to stage 2 5 18psi i think wheres that setting at
03-14-2009, 07:09 PM | #18 |
Rep 340
+1
i myself wouldn't set it that high. What other mods do you have? map 2 is for a fully catless system. I don't think this will get you more power and if it did i would question the safety of the power you're putting down(unless of course you are fully catless). be careful out there |
03-14-2009, 07:10 PM | #19 |
Rep 1,306
The boost limit is a saftey feature, not the boost target. It means that if you hit 18 psi for a second or two, your car will revert to valet mode. You should set this to 16 or 17 psi. Also, turn speed delimit to on(1) to turn off you factory top speed limiter. Good luck at the casino. I'm pretty sure that's all there is in Mystic.
03-14-2009, 08:45 PM | #20 |
Rep 5,018
Drives: VALNCYA
can you guys give me stage 1 map 1 and 2 settings recommended at stock...?
also why doesnt the procede shut off my limiter the car stops at 137 ! |
03-14-2009, 09:46 PM | #21 |
Rep 340
I don't know if you have but I would suggest reading this
http://www.vishnutuningforum.com/for...read.php?t=990 IMO i wouldn't use anything higher than stage 1 with a stock car and i wouldn't touch the torque values. I didn't notice much of a difference when changing the throttle response from 4 to 5 but others have said that this is a big difference. as far as speed limiter i never used it since i never had my car fast enough to hit it. what's the fastest the car went stock? |
03-14-2009, 10:04 PM | #22 |
Rep 5,018
Drives: VALNCYA
Sounds like a good idea... Idk that's the first time I topped it out.....but I don't understand why it won't go over 137
