BT scan on 08 E92 with JB3 last chi upgrade
03-18-2009, 10:26 AM | #1 |
Rep 75
Drives: 2012 f10 M5
Hi Just scanned my car with bt lastest
Any ideas on these codes? anything to worry about? Stability control Current Fault Codes D356 PT-CAN: Message TORQUE_3 (ID 0xAA) not received or wrong message length (DLC). [transmitter: DME] Error will cause a warning light Error is not currently present Test conditions have been completed D355 PT-CAN: Message TORQUE_2 (ID 0x0A9) not received or wrong message length (DLC). [transmitter: DME] Error will cause a warning light Error is not currently present Test conditions have been completed D354 PT-CAN: Message TORQUE_1 (ID 0xA8) not received or wrong message length (DLC). [transmitter: DME] Error will cause a warning light Error is not currently present Test conditions have been completed 5E1A DSC-ECU: ECU-internal: Serial-Peripheral-Interface (SPI): Transmission failure multi IC. Error will cause a warning light Error is not currently present Test conditions have been completed Air conditioner Current Fault Codes E717 CAN message: Dates of engine Error will not cause a warning light Error is not currently present Test conditions have been completed E71A CAN message: Torque 3 Error will not cause a warning light Error is not currently present Test conditions have been completed Light control Current Fault Codes A8B6 Error will not cause a warning light Error is not currently present Test conditions have been completed Car Access System Current Fault Codes A0B4 Fault engine start starter Error will not cause a warning light Error is not currently present Test conditions have been completed D904 K CAN wire error Error will not cause a warning light Error is not currently present Test conditions have been completed Instrument cluster Current Fault Codes A3AD CAN ID 1D0 error: Engine data Error will not cause a warning light Error is not currently present Test conditions have been completed A3AE CAN ID 0AA error: Idle engine speed Error will not cause a warning light Error is not currently present Test conditions have been completed
-E92 M3 AW 2010 -Akra full exhaust - HRE P40 19"-
03-18-2009, 10:54 AM | #3 |
Rep 75
Drives: 2012 f10 M5
I did yes. I used bt to scan and didnt show, this was however the first software release.
Perhaps the newer software picked it up and thats why it showed now? Code free now, will spank around my car and re check for codes
03-19-2009, 12:30 AM | #5 |
Rep 1,779
How do you know which codes to clear and which ones to leave...or there should be no codes shown at all?
How easy is it to clear codes with the BT...is it just pressing the DELETE button, or do you have to manipulate the data a certain way? PS. Sorry for the thread jack. |
03-19-2009, 12:47 AM | #6 |
Rep 2,108
i believe its as simple as pressing a button that says clear codes or something like this, i dont have the BT but i bet its very similar to OBII code readers in terms of clearing codes
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
03-19-2009, 02:40 AM | #7 |
Rep 75
Drives: 2012 f10 M5
You make a scane, you get a overview. You can delete induvidualy codes, or just click delete all codes and thats that.
03-19-2009, 04:10 AM | #8 |
Rep 1,510
You cannot delete individual codes with the BT. You can delete all codes within a specific module or all codes altogether.
To the OP, save the BT log session, clear all codes and rescan at a later time to see if any of these come back. |
