BT Scan:2D5A Control motor torque limitation?
03-21-2009, 12:32 PM | #1 |
**N54 Power Baby**
29
Rep 680
Hey guys..had a weird code pop up..I turned my car on and as soon as it turned on,I had a limp/Engine Malfun. Here's where it starts to get weird..the car started sputtering kinda crazy..rpms jumping up and down,as if it had a rough idle cam like a muscle car..as I threw it into reverse I had to really hold the brake down tight as it felt like it was gonna launch in reverse ! anyway I've never had that happen to me..does anyone have any idea what the hell this could be ?
03-21-2009, 01:58 PM | #3 |
**N54 Power Baby**
29
Rep 680
no tune as of right now..was running JB3 but took it off to install and let a friend try it out on his e90..I got the BT Tool recently to scan for codes,etc. and the only codes I've gotten has been some accelerator pedal module code..but this one is new..very weird..ofcourse my car does have 32k on it..so they may have something to do with it too..
03-21-2009, 03:15 PM | #5 |
**N54 Power Baby**
29
Rep 680
no manipulation codes here..i'm msd80 pre 29.2..My SA seems to think its a software issue..hopefully they wont upgrade me to the latest progman..
03-22-2009, 01:20 AM | #6 | |
829
Rep 3,982
If they think its a software issue, they will upgrade it to the newest progman.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
03-22-2009, 03:48 PM | #7 |
Rep 274
that happened to me once when i was installing the sprint booster on my accelerator pedal.
The problem was that i didnt have the wires pushed in all the way into their connectors and the gas pedal wasnt making a complete connection with the ECU. my car started shaking violently while at idle and still parked. if you are getting an accelerator pedal code malfunction, i would double check the gas pedal wires to make sure they are properly connected. could have become loose and disconnected temporarily. |
03-22-2009, 05:01 PM | #10 |
Rep 911
I have had the same after I not completly correct installed my procede.
It also gave a drivetrain error code. After fixing the cables and a BT reset, things were fine again. Maybe this helps you a bit.
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
03-22-2009, 06:23 PM | #11 |
Read the manual please, just do it before asking!
11
Rep 397
I had the same thing happening with my car after installing a bad flash tune.
It was a very scary experience due to the engine revs that was jumping 1000 rpms up and down and I had problem to get into neutral on my AT beacuse of the engine was not idling... I was considering disconnecting my battery just to stop the engine! |
03-23-2009, 11:05 AM | #13 |
Rep 911
Cables correct connected?
Power cables all correct?
03-26-2009, 06:59 PM | #14 |
**N54 Power Baby**
29
Rep 680
yep..quick update guys..my SA didnt find any issue,but thinks its a software issue..so they want to install the latest progman but I told them I read a bulletin that the newest software causes lag,and they were like ''well all we can do is clear the faults then'' ''the software upgrade is the best way to take care of the problem..'' what do you all think ?
03-26-2009, 07:07 PM | #15 | |
Rep 1,779
Have you tried out a car with the updated software? I don't notice any lag in my 2009... Can you live with lag that is almost invisible or can you live with this problem? You choice. I would update. |
03-26-2009, 07:27 PM | #16 |
**N54 Power Baby**
29
Rep 680
well from my understanding,the newer ecu's with the updated software dont really have lag issues..its the guys that have the old MSD80 ecu AKA pre 29.2 guys that get updated to the new software that experience the lag.
03-26-2009, 07:45 PM | #17 | |
Rep 1,779
But like I said, your car is sputtering and BMW's fix is an update. So you have to decide if you want to live with this problem, or live with lag. This is their "fix" to the problem which is why they came out with the update...too bad it has its negatives also. |
05-02-2018, 06:10 PM | #18 |
Supreme Galactic Commander (one galaxy over...)
675
Rep 1,778
Yes, I am necroing this thread, but I am getting this code (sans the strange idle behavior, just some hesitation in the 3-4k RPM range. What resolved it?
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
09-06-2019, 01:25 AM | #19 |
Rep 192
09-06-2019, 06:24 PM | #20 |
675
Rep 1,778
It just stopped. Wish I had more.
Best,
