RixEffects Vent Gauge / Map Switcher *FOLLOW-UP REVIEW*
04-01-2009, 05:26 AM | #1 |
Rep 5,175
I have been a huge fan of the RixEffects Vent Gauge for a long time. I love the integrated design, map switching options, and accuracy of the gauge. It's funny, I was actually not a fan at all of digital gauges before this venture, and I cannot imagine going back now. Well, long story short, I did a review a few months ago about his first production gauge:
http://www.e90post.com/forums/showth...ght=RixEffects The purpose of this review will be to cover some of the new features that RixEffects has included in their latest version of the Vent Gauge. Packaging As is always the case RixEffects, everything was packaged and protected well. The surfaces were well protected from scratches to insure you get the product without defect. Installation Very little is different when you upwrap the gauge. The installation instructions remain very detailed. The kit comes with a reference card for quick reviewing of the gauge's features. So, what is different? Good question! Wait I asked that question. Faceplate changes The faceplate of the gauge has traditionally be reflective black and I thought that looked fantastic. RixEffect's decided to change the faceplate to "match" the OEM look better, and I really thought that was a huge mistake because it integrated so nicely. Well, I got the new vent cover and he was right, the new faceplate is better. The gauge section remains a reflective black, while the vent section is a matte black. The matte black is a spot on match with all the trim and the other vent sections. Just an tip, do not try to peel anything off the gauge when you get it. The faceplate is ready to go when you open the package. The color remains a spot on match. Calibration Menu Some new items have been created here. Now, you hold the button on the face down and press the start button a few times to access the "CAL" menu. First item is the calibration. It still references the atmosphere to get a good 0 and shows a nice "END" when completed. Remember this gauge is not using the TMAP sensor, but it is located on a "T" near the diverter valves so it does measure after intercooler or manifold pressure. This gives you very accurate boost readings, without false pre-intercooler spikes. It also shows vacuum which I like to see and can be useful if you ever have to trouble shoot a boost leak. Valet Mode This is a cool option. RixEffects now allows you to valet the gauge so it will not turn on when the car is started. Why would you want this? It will stay dim on dealer visits and you can lock a stock map if you valet your car. Just makes a great set of user options better. Map Switching The Rix gauge has always switched maps for JB3, but now does Procede maps as well. The menu allows you to choose JB3, Procede, or None. The JB3 option also allows switching of 10 maps, but I am not sure how that works yet on the 5v plug. Hopefully Rix can chime in here. The map switching still works "on the fly". Conclusion My conclusion remains the same. RixEffects always had a winner and now they improved on an already stellar product. The face plate looks awesome and the valet mode allows you to protect your car now. I still think this is a must, must for every tuned car. |
04-01-2009, 07:55 AM | #2 |
Rep 4,764
Very nice review. I bought the original pod gauge, and just purchased and installed the vent gauge last week. I can only echo how great it looks in the car.
Outstanding job Rick! Thanks for coming up with a perfect solution for us. |
04-01-2009, 08:10 AM | #4 | |
274
Rep 6,510
Thanks for the updated review! glad you are still enjoying the gauge! To answer your question... For jb3 map switching, you have access to all 10 maps, because you must pre-select your map for slot #2. It takes the convenience of the pedal map switcher, and then adds "real time" switching of 4 maps, including your customized one. bc.1 is race gas (jb3 map 7) bc.2 is pedal selector (as if gauge was not there at all.. you configure this map) bc.3 is high boost (jb3 map 3) bc.4 is stock/valet Just put it on bc.2 , and then program that map to be whatever you want, any of the 10 maps with the pedal selector, and then you can real-time switch between your chosen map, stock/valet, high boost, and race gas... on the fly! These other 3 maps were chosen by Terry, and he said he will allow people to customize those as well if needed... Last edited by RiXst3r; 05-23-2010 at 08:27 AM.. |
04-01-2009, 10:51 AM | #5 | |
Rep 5,175
05-10-2009, 09:09 PM | #6 | |
Jewbacca
10
Rep 219
05-11-2009, 06:23 AM | #7 |
Rep 5,175
05-11-2009, 07:33 AM | #9 |
Rep 5,175
