Procede V3 Rev 1 + built in O2 simm on a non-modified car..Will it throw codes?
04-10-2009, 10:00 AM | #1 |
Rep 5,876
If I were to put in a procede into someone's car that hasn't been modified yet and this procede had a built in o2 simm, would that throw codes?
04-10-2009, 03:14 PM | #3 |
Rep 738
i did the sims via shivs DIY and never got codes, lights or anything. completely stock. had catless DP's on the way so i figured i'd do it before hand. sold the rev1 unit and bought the rev2, then installed the rev1 on a different 335i with stock dp's and no issues. i guess since one guy had issues you wont know till you do it
teri
http://videos.streetfire.net/video/s...rays_37268.htm
gotta do what i gotta do to get them donuts 04 spec-v: rip dec07 |
04-10-2009, 03:49 PM | #4 |
Rep 5,780
Yes it would. Take a picture, high res, of the harnes and I should be able to show you were to cut. It would be just one wire and could be hooked up again later.
04-10-2009, 05:40 PM | #5 |
Rep 5,040
I had my o2 sim on my jb3 harness with the stock o2 sensors & downpipes and it did not throw a code or behave any differently.. except the jb3 which made the car pull like a raped ape
04-10-2009, 08:42 PM | #9 |
/r/trees
50
Rep 875
These are the relevant codes pulled not long after the CEL:
2CA9: 2CA9 Lambda probe heating behind catalytic converter 2, function 2CA8: 2CA8 Lambda probe heating behind catalytic converter, function This was the DIY hack that shiv posted; 2 cut wires, and 2 resistors. This was reversed by simpy cutting out the resistors, and patching back the 2 wires. |
04-10-2009, 09:01 PM | #10 |
Rep 5,040
depends if the voltage divider was connected properly, the resistors themselves (some have 10% tolerance values) and the ranges the ECU will accept as valid test values
04-10-2009, 09:08 PM | #11 |
Rep 5,780
04-10-2009, 09:54 PM | #12 |
Rep 5,040
so the ECU will read as open? Whats the point of the voltage divider then?
Not saying you are wrong, but from my understanding, the O2 sensors output a range of voltages during normal operation, which is proportional to the chemical/thermal properties of the exhaust gas? |
04-10-2009, 09:57 PM | #13 | |
Rep 5,780
04-10-2009, 10:00 PM | #14 |
Rep 5,040
