335i muffler in detail
04-12-2009, 08:44 AM | #1 |
Rep 329
So yesterday,I and a friend of mine decided to use the spare time to look inside the 335i muffler
We carefully unmounted the whole exhaust up to the pipes that lead to the downpipes. Then we cut it open and well,it was quite suprising how simple the muffler was constructed. But one thing was quite weird... In the left muffler,there is a small section that looks like a cat. So we looked through the exhaust tips using a flashlight and found catalytic material inside as well as any insulating material if it was used as a small extra muffler. So what is this thing good for? Another thing I was wondering is : what is the connecting pipe between the two seperate mufflers good for? Maybe to get a better flow if one muffler seems to "clog" or has a less good exhaust stream flow.. here are some pics to see what I`m talkin about |
04-12-2009, 09:05 AM | #3 |
Rep 329
04-12-2009, 09:05 AM | #4 |
Rep 372
woahh, dissecting muffler?? I think the cat on left side helps with emission when car is cold, because only left side is open when cold, and to help cat get hot faster. now dissect the motor and see what do you find interesting there? lol
04-12-2009, 02:10 PM | #7 | |
Rep 329
We looked inside the left tip with a flashlight and did not see any material inside |
04-12-2009, 03:20 PM | #8 |
Rep 329
I read somewhere that the connecting pipe is acting as a resonator..
is that correct? Does the E93 have a resonator before the muffler section? |
04-12-2009, 03:22 PM | #9 |
Rep 3,735
The connecting pipe is basically an integrated "H-Pipe". Designed to cancel out certain unwanted frequencies in a factory car.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
04-12-2009, 03:48 PM | #10 |
Rep 1,654
Drives: AW M3
someone should do this with an AE muffler
04-12-2009, 03:54 PM | #11 |
Rep 648
The left exhaust tip get's closed off by the exhaust flap. The exhaust in that pipe needs to have somewhere to go, so they route it over to the other side.
04-12-2009, 04:27 PM | #12 | |
Rep 329
But what is this cat-like thing inside the left exhaust? another thing : is that correct ? : |
04-12-2009, 08:03 PM | #14 |
Rep 1,441
Drives: e92 335i, f10 m5 comp
maybe thats what the flap is for?
04-13-2009, 10:42 AM | #16 |
Rep 1,441
i think what you said is a resonator is actually just a Y pipe. if you found catalytic material in the drivers side muffler, chances are, its a cat. the exhaust flap closes to heat it up and opens when youre on throttle.
upstream to the Y pipe are the secondary cats and the primary cats are in the downpipe upstream to that. |
04-13-2009, 11:39 AM | #17 |
Rep 2,304
correct
04-13-2009, 01:06 PM | #18 |
Rep 3,735
that's correct.
04-13-2009, 04:00 PM | #19 |
Rep 329
ok thanks
so my idea is to make straight pipes from the downpipes by cutting out the secondary cats and replacing them by 2 pipes and then in the muffler I would have to close the bypass pipes with a metal plate on each side and for the left muffler I`ll have to replace the small muffler inside by a single pipe. This way the german cops should not be able to see that I have no mufflers and I still can drive with straight pipes is that correct? Thanks guys,I really appreciate your input! |
04-13-2009, 04:03 PM | #20 |
Rep 1,441
you may even be able to pick up more power without that y-pipe, since youre already taking stuff out.
good luck, i hope it sounds to your likeing when its all done |
04-13-2009, 04:09 PM | #21 |
Rep 471
04-13-2009, 04:47 PM | #22 |
Rep 1,184
E93 has exact the same exhaust as E92.
The E90 has a resonator in the X pipe, so it is less loud. The passenger side muffler contains big resonator so it is quiet. The drivers side muffler contains this kind of cat, in fact it is a small resonator that gives the nice sound when the flap is open. I whould subjest only to remove the rock wool inside the mufflers, and close them. It should give a nice sound |
