DPs or FMIC ?? Which one first ??
04-16-2009, 04:37 PM | #1 |
Rep 821
If money is the issue which one first....DPs or IC ???
Eventually both offcourse....
04-16-2009, 04:49 PM | #3 |
Rep 4,484
This question has been asked a few times before.
Search for the results of those posts. Most will say DP's for power, but IMHO FMIC for the more warranty friendly/safe, environmentally respectful, as well as reliability and prolonging of engine life. FMIC also allows more power and hugely combats heat soak which takes power away. I wouldn't even get DP's. Not worth the hassle, warranty troubles, for 20 more hp, unless of course you are racing for prize or money and need every last bit of power the car is capable of. |
04-16-2009, 04:51 PM | #4 |
Rep 158
Id say Downpipes first because im more for performance. With or without other supporting mods i believe you will see respectively more gains with DP'S. If the area where you live though is always hot , IC maybe a good thing to think about ...
04-16-2009, 05:01 PM | #5 |
Rep 821
Eventually both will be installed Im just getting a good deal on both but money for one...
04-16-2009, 05:46 PM | #10 |
Rep 821
DPs = more less 30 HP
What about FMIC BTW Im running JB3
04-16-2009, 05:48 PM | #11 |
Rep 274
get half and half
well i live in Vegas where its gonna be 110 degrees soon. I want DPs for the power and performance, but for the sake of the car and with summer coming, IC first
[SIGPIC][/SIGPIC]
04-16-2009, 05:51 PM | #12 |
Rep 4,764
1)Tune
2)Intake 3)Catback 4)FMIC 5)DP's That's the order I am going. Might not be the best order, but the DP's are the hardest to get out for a warranty issue. Hopefully 3 will be done next week and 4 within a month. 5 might wait until next spring, but they are calling my name. |
04-16-2009, 05:59 PM | #13 |
Rep 1,649
1) Tune
2) Intake 3) FMIC 4) DPs That's the order I'm going thru. I'm still undecided on the benefits of a cat-back exhaust and whether its worth the cost/performance. There's no doubting the sound department, but I'm not so drawn to that aspect. |
04-16-2009, 10:01 PM | #14 |
Rep 4,484
People also keep pointing to the "performance" aspect of downpipes.
You take two identical otherwise stock cars, one with upgraded FMIC and one with catless DP's. In the first race the catless DP car will probably pull 1-1.5 CL's in 40-120 run On the second run the DP car will probably pull .5 CL's On the third run the FMIC car will probably pull .5-1 CL On the 4th run the FMIC car will probably pull 2+ Add the same tune (JB3 or PROcede) to those otherwise stock cars and the FMIC car will see the advantage even faster. Throw the same cars on a track and the DP car will probably lap the first lap faster, the second lap will be probably equal and every following lap the FMIC car will have the advantage. Heat soak is a bitch to these cars. Catless DP's doing nothing to combat it. Good upgraded FMIC does and therefore performance wise, if racing or tracking, it's the one that offers the better "performance" unless by performance you simply mean increase in power for 1 or 2 quick races or 1 lap at a track. And again, not too many dealers will void warranties for upgraded FMIC that simply keeps the engine running cooler and therefore HELPS it and prolongs it life. Catless DP's on the other hand, don't know of a single dealer that will be ok with them for any powertrain service work you need, and putting them on and taking them off is a bitch too. |
04-17-2009, 12:07 AM | #18 |
54
Rep 886
I went with DPs first (because of power gains, quicker turbo spool). Now waiting for FMIC. If I lived in a very hot climate, I'd consider getting FMIC first.
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
04-17-2009, 12:08 AM | #19 |
Phantom at large
35
Rep 1,997
1. tune
2. Intake 3. DP's 4. (maybe IC) thats me.
2008 335i Black Sapphire| Black Interior| Navi| Silver Aluminum Trim |Tint l BMS intake l JB3 l Riss Racing downpipes | Miro Staggered Hyper Silver 19 inch CSL Reps |Nitto 555's ***RIP 2011 335i Jet Black| Red Interior| Bone Stock ***RIP 2013 M3 Space Gray|Carbon Tint| Matte Black Eurotek CSL Wheels| Nokya White Halos| AFE Stage 2 intake| AFE Power Pulley| Reflector Delete|
04-17-2009, 12:25 AM | #20 | |
Rep 3,713
got the tune, intake, bastuck exhaust with 2nd cat delete pipe...now i need to save for a FMIC den DP again if not DP before FMIC haha |
04-17-2009, 02:34 AM | #21 |
Rep 1,211
emjei, I know from experience how hot and humid is over there year-round. Get the FMIC first, it will definitely help with the reliability and longevity of your car. Even though TX is not as humid, I'm still considering getting the FMIC first.
04-17-2009, 04:51 AM | #22 |
Rep 5,175
I used to think an intercooler was just a novelty item and not really as necessary as some thought, but there was no indepentent testing. Well, I decided I would do it. The bottom line is that we found the stock IC is extraordinarly bad. I am not sure an OEM item is worse. What I realized is that there are 4 things that must be done on this car. They are the non-negotiables... tune, downpipes, intercooler, and intake. After the tune, each is just as important as the next.
