boost leak?
04-30-2009, 04:25 PM | #1 |
Rep 677
boost leak?.... Yes Boost Leak!!
Could this be a boost leak? (limp as soon im pushing a bit and boost goes over 5 psi) The error code with the bt is
30FE: 30FE Exhaust fume turbo charger, high pressure side Error will not cause a warning light Error is not currently present Test conditions have been completed Event 1 Odometer ambient pressure 976.44 hPa ambient temperature 5.25 °C pressure in front of throttle valve 167.00 kPa speed 2,860.00 rpm (I installed the FMIC last weekend and didn't use the car since then) If i stay "off boost" everything is ok. What do you think
59 Corvette, 72 240Z, 73 Espada, ZXR
04-30-2009, 04:30 PM | #2 |
274
Rep 6,510
hmm, thats a "boost too high" code... car thew a code because it saw an unexpected 9+ psi in front of the throttle valve (167.00kpa - ambient)
anything else change besides the intercooler? |
04-30-2009, 04:55 PM | #3 |
Rep 2,842
Definately not a leak then.
Could possibly be boost mapping is too aggressive resulting in an overboost code which this is. Doesn't mean anything is broken....just that the DME has detected that boost is too high. Are you running a more aggressive map? |
04-30-2009, 06:14 PM | #4 |
Rep 677
No, I'm runnig stage 0 and didn't change anything else and default settings (ok oil cooler, but this doesn't matter)
04-30-2009, 06:18 PM | #5 |
21
Rep 684
Drives: 07 Blk e92 335i
dont think boost leak throw a code, my intercooler pipe blew apart and didnt get any code, boost barely hit 5psi with tune. Just loud air noise under the car
04-30-2009, 06:21 PM | #6 | |
Close to bein Bannned
106
Rep 5,068
if you got a procede then datalog and post the results |
04-30-2009, 06:35 PM | #7 |
21
Rep 684
04-30-2009, 08:35 PM | #9 |
106
Rep 5,068
you can hear the turbo's overspooling like crazy
04-30-2009, 10:49 PM | #10 |
Rep 10,587
stop driving the car and recheck all your connections and retorque them. Be safe, no reasn to push the turbo's if you think you have a boost leak.
05-06-2009, 04:39 PM | #11 |
Rep 677
Thanks to everyone. I Found the boost leak. Was a really hard one.
Both Pipes blow off the FMIC... Stupid me didn't click in the pipes properly in. So much about an easy install with a 19" problem. Took it on the lift today (didn't have time till today) and startet to shake my head about my self. Installed it, went on the Highway and had a show down with an AMG 62. Dead even 80 to 150 MPH im happy.
05-06-2009, 05:07 PM | #12 |
21
Rep 684
AMG 63? C class?
05-07-2009, 02:02 AM | #15 |
Rep 677
No it was an M I know its a tank but still happy with FMIC and tune only.
VK Motorwerks
