Q: no cats + stock catback
05-07-2009, 09:12 AM | #1 |
54
Rep 886
Hi,
I have 'ar design' catless DPs installed. I want to go fully catless as I want to use Stage 3 maps (waiting for a FMIC to arrive). However, I don't want to change the catback as I don't like it loud. The sound is almost perfect for me now. What are the options? Change the whole midpipe? To cut out the cats and put resonators? Anything else? Welding will be needed anyway, right? Thanks in advance. edo
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
05-07-2009, 09:36 AM | #2 |
Rep 10,587
I think cutting out cats and putting in resonators would be fine.
otherwise I think it will be quite raspy.
05-07-2009, 09:44 AM | #3 | |
54
Rep 886
Can you recommend where to get the resonators from?
05-07-2009, 11:42 PM | #5 |
Rep 3,432
+1 just keep the second cats...no point getting the extra smell and rasp for 5hp...and the "stages" are flexible, not fixed...just lower the UT slightly if you dont feel comfortable running the second cats on stage 2, although I think you'll be perfectly fine with default setting
05-08-2009, 12:16 AM | #6 |
54
Rep 886
Well, I got destroyed by E92 M3 and IS-F tonight (will post videos this weekend) and this really sucks. Everyone is telling that one can't get much more power with cats in the exhaust system. Shiv has also written several times that the difference is huge.
Why should it rasp if I put resonators and leave stock catback? I thought that catback and resonators are the most important rasp, noise 'killers'... And no, the difference is not 5hp between stage 1 and stage 3.
05-08-2009, 12:39 AM | #8 |
Rep 298
let me know how this goes.... I'm in the same boat . I have catless dp's with stock exhaust. Just an idea.... put the i/c in and try running the stae 3 map on the dyno with your current set up. If you are not happy with the results then try removing the secondary cats and redyno the car. The mufflers are not a straight through design and may be the next problem. After all your work you may see only 10 whp difference from removing the cats. All yourmpower will be made from running the stage 3 map ...
AA boosted 500+ hp
05-08-2009, 12:39 AM | #9 | |
Rep 3,432
05-08-2009, 12:59 AM | #10 | |
54
Rep 886
Even when I raise UT to 72, performance gets a bit worse. So if I use stage 2 maps, it could be much worse (more aggressive map, default UT settings - 80).
05-08-2009, 01:19 AM | #11 |
Rep 273
Ugh.. I hate IS-Fs. such a shit car. was it a girl driving it? chick car.
05-08-2009, 01:25 AM | #12 | |
54
Rep 886
A friend of mine (guy) was driving it. But let's get back to topic. I hate being destroyed... And I need more power.
05-08-2009, 01:33 AM | #13 |
Rep 274
how bad is the smell with just the primary cats removed? I want the AR catless DP's but is the smell that bad or is it only bad when you also remove the secondary cats??
[SIGPIC][/SIGPIC]
05-08-2009, 01:50 AM | #14 |
54
Rep 886
I can't smell anything. Same as with catted DPs.
05-08-2009, 07:10 AM | #15 | ||||
Rep 4,764
You have to do some logging and analysis on the performance at stage 2. Quote:
One of the DP vendors uses magnaflow high flow cats (model 59959)in their setup, you could look for something similar to fit with the right inlet and outlet circumfrences, like model 59956. http://www.car-sound.com/02product/u...al/599spun.asp |
05-08-2009, 07:14 AM | #16 |
Rep 10,587
I did not find that my 335 was that stinky when it was catless.....my m3 was much worse for some reason.
05-08-2009, 07:47 AM | #17 |
54
Rep 886
Thanks for the info, scottp999.
I'll log runs with stage 1 and 2 maps with different UT settings. Maybe you're right and I'll get better results with stage 2 maps...
05-08-2009, 07:49 AM | #18 |
54
Rep 886
Could you smell it inside the car? Or just when you were standing outside next to exhaust pipes?
05-08-2009, 08:46 AM | #20 | |
Rep 4,764
I would think an exhaust shop could easily fit a 2.5 high flow cat in there. |
05-08-2009, 08:56 AM | #21 |
Rep 759
What about getting the riss racing mid pipe that just deletes the secondary cats...that piece requires no welding
http://www.e90post.com/forums/showthread.php?t=161070 |
05-08-2009, 09:17 AM | #22 | |
Rep 2,842
However, stage 2 did leave me with more inconsistent performance (perhaps ongoing part throttle adaptation?) and was not as smooth and fluid as stage 1 is. So I don't think it would make you any slower.....just might not make you any faster either. If that's the case, then you will know your car is not up to the stage 2 maps. BTW, I used 75% UT on stage 2 - not the recommended default of 80%. |
