Broken Boost Line...
05-10-2009, 02:16 PM | #1 |
Jewbacca
10
Rep 219
So I'm installing the RixEffects gauge, and I'm going to splice the boost line that goes to my BOV, right? Before anyone flames me on this, I just need some help. The boost line that goes to that Y-Fitting (see image)...where does it connect to on the other end? I was pulling the Y-fitting off and my hand slipped and the OTHER end broke .
HELP PLEASE!! |
05-10-2009, 03:35 PM | #3 |
اوليسيس
198
Rep 4,678
if the plastic nipple which is part if the manifold broke off, then you are screwed. you need to buy an entire new manifold. about $700.
i have another solution for you, but first verify what actually broke. Edit: jsut checked Tischer and its $573.17
05-10-2009, 03:57 PM | #4 |
Jewbacca
10
Rep 219
It is, in fact, the nipple on the manifold #)(*&%$#)(@U%)(@U. I checked Tischer and found it to be $478. I know this sounds retarded...but for a temp fix until I get a new manifold...could I not just superglue/jb weld the damn thing back on, run a coat hanger through to make sure its still open and use it that way? I know its ghetto rigged that way, but I need the car.
05-10-2009, 04:20 PM | #6 |
اوليسيس
198
Rep 4,678
you might be fine, and you could of driven it even with it off, you just cant go onboost. Go to a local shop either have them tap the same hole with a brass fitting, or seal up the original and tap a new one.
05-10-2009, 05:06 PM | #7 |
Jewbacca
10
Rep 219
That's actually an excellent idea, thanks. The superglue held fine at full temp for 20 min under 13psi, so I think it should be fine. I'll keep an eye on it, though, and eventually get that tapped with a brass nipple. Thanks guys!
05-10-2009, 06:01 PM | #8 |
Rep 2,304
superglue is not a really great idea, do as 335ihellraiser said and get it tapped. you still going to order a new manifold?
05-10-2009, 06:23 PM | #10 |
274
Rep 6,510
Sorry to hear about that, looks like those vacuum lines don't have much slack going to your BOV in that photo... could have developed a crack over time... you should have some more slack in there now after installing the new vacuum line extension and T that comes with the gauge kit. I would do what others have said and re-tap it, or what scalbert suggested should work good too!
05-10-2009, 07:52 PM | #11 |
Rep 2,304
JB weld is the best. my grandpa jb welded an engine block of a rototiller and it held for 5 years lol
05-10-2009, 08:13 PM | #12 |
اوليسيس
198
Rep 4,678
JB Weld is great, dont know how it will hold up with the manifold though as its plastic, always used on metal never on plastic.
05-10-2009, 08:18 PM | #13 |
Rep 2,304
it will bond with both plastic and metal great
05-11-2009, 08:24 AM | #14 |
Rep 5,780
It will hold well. I broke the nipple off the bypass valve actuator on an Eaton blower and used JB Weld. It held up for several years before selling the vehicle after which I never heard of a failure.
