Procede installed
05-15-2009, 01:15 AM | #1 |
Autobahn Driver
15
Rep 106
Procede installed
one year ago i installed my aa active processor in my car. it's a great tune for the n54 enginge. but now it was time to change.
i dont know what i should take. JB3, Procede ore whatever. it was a terrible decision. now, tataaaaa .... its the procede. a big "THANK YOU " goes to Robert from Vishnu. for his help and patience. and for the excelent shipping selection and preparartion. only 4 days from california to germany. thats a number. and now the procede is in my car. it works fine. the adaption is not finished yet but the car is quik - very quik. at this time i think the power delivery is much smother than with the aa processor. we will see lars
M6 - Singapore Grey
05-15-2009, 08:43 AM | #2 |
Rep 1,480
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Congrats and welcome to the club!
What map/user torque are your using?
05-15-2009, 12:37 PM | #3 |
Autobahn Driver
15
Rep 106
that i must show detailed later.
i put the procede out of the box, put it in the car and drive away later i must compare the map. earlier today i establish the connection between procede and my laptop. yesterday i have no usb-serial adapter. now i find an old palm connect usb - serial adapter. and you will not believe it - its fully functional. with windows xp drivers on a vista pc. then i saw that the ut is 90 by default and the max psi is 16. i think its to mutch for my car setup? i dont know.
M6 - Singapore Grey
05-15-2009, 02:07 PM | #4 | |
The Stig
31
Rep 1,232
05-16-2009, 04:00 PM | #5 |
Autobahn Driver
15
Rep 106
hello,
now i have reduce the ut to 70. the car is much slower but i have no misfires. my bt shows much misfires at cylinder 1. next thuesday my car becomes new spark plugs (the dealer has it not on stock). the old ones runs now ~40.000miles and ~20.000miles with the aa processor. i think i must replace it. whats your settings of ut, max boost and other things in my config (dci, procede canbus, rest stock) or whats your recommandation? thanks lars
M6 - Singapore Grey
05-16-2009, 09:17 PM | #6 | |
Rep 1,480
Try this first: Swap the ignition coil from cylinder 1 to cylinder 2 and then rescan for misfire, if it goes from cylinder 1 to cylinder 2 replace your ignition coil, no need to replace the the spark plugs if its not the issue.
Hope this helps, I had similar problem that I debugged same way: http://www.e90post.com/forums/showthread.php?t=250979 Quote:
05-22-2009, 04:09 AM | #7 |
Autobahn Driver
15
Rep 106
wednesday i changed the spark plugs. now the car have no misfires, no limps - nothing.
i'm very happy with the procede. under wet conditions i logged with proscan the following values 60' Time ......... 2,065sec 0-60 MPH ........4,482sec 1/8 Mile Speed..89,367mph (143,8km/h) 1/8 Mile Time ...8,376km/h 1/4 Mile Speed..110,494mph (177,8km/h) 1/4 Mile Time ...12,873sec i know it is not the fastest. but it was wet and it was my first run. then it began to rain again and i stop my tests. i ran stage 1 map with ut 90%. here a 100-200km/h run
M6 - Singapore Grey
05-22-2009, 07:47 AM | #8 |
Rep 2,224
I find the latest 5-08 maps and firmware the best so far. I run stage 1 70% on map 1 and 75% on map 2 for when the weather is cooler. Car pulls like a beast. I haven't data logged yet, so haven't tried pushing it higher but I definately feel an improvement at 75% on a cool evening. I have DCI intake, mid pipes and cat back and use 98RON gas.
You might want to wind back your UT mate as 90% is very high. Default for stage 1 is 70%. |
07-11-2009, 05:41 PM | #9 |
Autobahn Driver
15
Rep 106
today i made a vmax test at the autobahn - yes, in germany we have autobahn
here you can see a video : (the video is cuted at the end, no visible changes over 280km/h) the procede has the 123 firmware and i run the stage 1 map with 80% UT. i have logged the speed and the rpm with an obd tool. the speed freezes at 255km/h ... but the rpm was correct. the max rpm at this run was 6970 (it's an at car) in dependency of scale of tires, gear ratio and axle the max speed was between 307 and 317km/h. thats great ... fantastic thank you Shiv for this great tune ..... and thank you BMW for this great enginge and car
M6 - Singapore Grey
07-11-2009, 07:02 PM | #11 |
1750
Rep 17,960
Drives: A Lot
New top speed record???
07-11-2009, 08:18 PM | #14 | |
Rep 2,224
Hey man have you datalogged your runs? 90 and 80% UT on stage 1 with DCI is getting up there. Would be pushing 16psi possibly?? |
07-11-2009, 10:05 PM | #15 |
Rep 10,858
Autobahn beast!
Make sure you have the proper suspension & tires to handle 300kph+ I have got to do an extended ED -- wonder if German customs would confiscate a Procede...
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
07-12-2009, 07:12 AM | #18 |
Autobahn Driver
15
Rep 106
maybe - i dont know
more boost is not possible with my car. over ut 80 i become misfires at high rpm.
M6 - Singapore Grey
07-12-2009, 02:45 PM | #19 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
07-12-2009, 03:05 PM | #20 | |
Autobahn Driver
15
Rep 106
i'm using only ROZ 100 Gas (Shell V-Power). i dont know the comparable gas in u.s.??
M6 - Singapore Grey
07-12-2009, 03:14 PM | #21 | |
Rep 507
07-12-2009, 06:05 PM | #22 | |
Rep 2,224
Shiv, I suppose you mean by safe conditions, you mean datalog a run to see max boost? |
