E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > shiv, what is the speed (tach) signal ECU pin?
Reply
      05-16-2009, 12:31 PM   #1
marconi118
Drives: 06/07 e93 335i
what is the ECU pin that receives the tach signal?
Maybe by removing this signal the ECU will not limit car speed to 250KM/h ?
      05-16-2009, 03:29 PM   #2
munters
munters's Avatar
11
Drives: E91 335XI AT Dakota Black M
It's not just that. you need to feed a sig^nal.
I think Shiv will not help you. last time he did it it endet with brain sucking.
With the search button in Procede version 2 treads (1 year old) and green wire you can learn a bit.
59 Corvette, 72 240Z, 73 Espada, ZXR
      05-16-2009, 07:13 PM   #3
335iheLLraiseR
اوليسيس
335iheLLraiseR's Avatar
Drives: e92 335
2007 e92 335  [10.00]
what is it with people starting a thread addressed solely to Shiv like its an email?
you need to intercept that signal, you cant just unplug it. its not a civic.
Originally Posted by lawdude View Post
Anyone who can transition seamlessly from defending one vendor and bashing another vendor to bashing the one he formally defended and defending the one he formally bashed has a instant credibility problem.
<---Sign up Now for Bonus Storage! Up to 10gb!
      05-16-2009, 07:25 PM   #4
thegeneral101
Drives: '15 Z06,'13 750Li,'11 Raptor
jeez I know....
and hes right must be intercepted not unplugged
      05-16-2009, 07:27 PM   #5
marconi118
I could simply inset a divider by 2 on this wire so that the ECU receives 1/2 of the impulsion and believe that the car is going 1/2 of the ral speed. this could be rather simple and cheap...
      05-16-2009, 07:37 PM   #6
335iheLLraiseR
اوليسيس
Drives: e92 335
yes, but have you taken into account the possible ramifications on, oh i dunno, say the ABS, or your traction control?
      05-16-2009, 09:27 PM   #7
dmurray14
The Stig
dmurray14's Avatar
Drives: Quickly
It is beyond me why people try to ghetto rig 50k+ cars....
      05-17-2009, 08:39 AM   #8
marconi118
traction control and ABS use the 4 wheel sensor, then there is a signal coming from the ABS + DSC unit and going to the MSD80 to tell the speed. It is this signal that I vould manipulate.
Procede is doing the same thing
But I whould only pass the speed limit without a tune, so I don't need procede, only to manipulate this signal...
I I only knew the wire pin...
      05-17-2009, 09:24 AM   #9
bolty
/r/trees
bolty's Avatar
50
Drives: 08 e92 335xi
why the tach pin??
why not the boost pin? Instead of a divider, you can use a multiplier and get 2 times the boostage.
And youre right about the 4 wheel sensor, so put a few multipliers on there too. You will stop faster and get better traction.
      05-17-2009, 09:58 AM   #10
marconi118
I don't need a tune, only to pass the 250Km/h
So the only pin I need is the one where the ECU receives the speed pulses from the ABS DSC unit
      05-17-2009, 12:22 PM   #11
335iheLLraiseR
اوليسيس
Drives: e92 335
so you are planning on telling the ECU one speed and the ABS and DSC another?
why not just get the speed delimiter from AA?
      05-17-2009, 01:01 PM   #12
marconi118
the AA speed delimiter is doing exactly this. tell the ECU a different speed than the real one that is measured by the ABS module.
If I only knew the pins the AA delimiter uses.
If someone has an AA please could you tell me the pins?
There should be only 3 wires going from AA to the ECU: +5v GND and the tach signal
Please do the E90post comunity a favour, I will post all the detail how I achieve this if it works for me.
      05-17-2009, 01:09 PM   #13
matt
Germany
61
Drives: munichs finest
just get a box, its only like 200euro.
only deactivates the limiter, no added hp.
f*ckin' love my car <3
      05-17-2009, 02:50 PM   #14
marconi118
why buy AA delimiter for 200euro if I could try to do it myself?
It is interesting to learn and experiment
The same you are doing with the X6 or 740I intercooler.... you could buy one in the US for 1000$ ....
really HOPE that someone that has the AA SDL could give me the info about the pins of ECU
      05-17-2009, 02:55 PM   #15
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
The VSS is a 12 volt digital signal. Pin 17 on the gray subconnector. Vehicle speed is used for many aspects of the tuning so you can't just disconnect or clamp it. You need to alter it as you approach the speed limit.
Mike
      05-17-2009, 03:01 PM   #16
matt
Germany
61
I remeber its a yellow cable...had a delimiter..
      05-17-2009, 03:06 PM   #17
smdandb2
this space left intentionally blank
smdandb2's Avatar
15
Drives: Blue One
No shit.
      05-17-2009, 03:52 PM   #18
lawdude
lawdude's Avatar
Drives: 335i ZPP ZSP TiAg MT
Originally Posted by smdandb2 View Post
No shit.
What do I know? I'm insane.
      05-18-2009, 06:13 PM   #19
ar design
ar design's Avatar
Drives: 04 M3
-Critter
      05-18-2009, 06:19 PM   #20
OpenFlash
Drives: A Lot
It's a frequency signal. So using a voltage divider to reduce the voltage readings wont do anything other than trigger a code. Or did I misunderstand?
      05-19-2009, 10:49 AM   #21
chiefsotos
chiefsotos's Avatar
42
Drives: BMW 335 E93
Are you serious man? You can't just unplug wires or playing with the volts of them hoping you achieve more speed than 250km. Did you wonder if playing around this burn the control unit? That is a lot more money than a single delimeter box... And why do you want to make experiments with the speed wire coming from abs, and dtc sensons in order to achieve very high speeds??? You don't even know how these sensors will react after changing this signal.
Please RESPECT your live and other people lives!!!
      06-02-2009, 05:07 AM   #22
marconi118
Hi Shiv, yes of course I know that these are pulses proportional to the car speed.
By a divider by 2 I mean a digital divider like a flipflop, that will divide by 2 the number of pulses.
Will the ECU work if it reads half of speed? Or should I reduce the number of pulses only after a certain speed? How is your algorithm working?
I know about analog and digital signals.. as I am Electronician...
Reply
e90post
