E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > JB3 Install Help
Reply
      05-18-2009, 05:48 PM   #1
egon10psi
Drives: 335i
JB3 Install Help
Ok so i am pretty sure i have everything hooked up right. But i ran into a few problems.
I CAN NOT get the slider clips back in are these completely necessary????
Also when i hooked the last wire back up the car started buzzing under the engine bay??? I left the car sleep for 20 minutes and my key is nowhere near the car.
Hope i didnt Fck nothing up
      05-18-2009, 05:56 PM   #2
cn555ic
cn555ic's Avatar
Drives: 335i
buzzing noise is not good...one of the wires or connectors are in the wrong slots, or the PNP are not aligned correctly...I would email Terry or Mike for some help
      05-18-2009, 06:01 PM   #3
egon10psi
Drives: 335i
well yeah i notices that one was not plugged in right so i fixed it and the noise went away. All noises are gone all the wires are plugged up and tight. As long as you absoluteley do not need the sliders in i will try to drive it
      05-18-2009, 06:26 PM   #4
yandy
yandy's Avatar
Drives: 2009 e92 MR "Civic" ///M3
2009 BMW M3  [0.00]
the sliders that go on the plastic harness? yes they should slide and clip in all the way. If they don't then you have a wire in the way, maybe loose or something.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
      05-18-2009, 06:27 PM   #5
JeffL
JeffL's Avatar
35
Drives: C63
???The sliders hold and lock the connecters to the ECU. You NEED the sliders. Well I guess it will probably run for a little while but I would think over time the connectors would work them selves loose. Only one slider needed to come off, the smaller one.
no sig.
      05-18-2009, 06:55 PM   #6
lpphreakx06
Professional Moose Racer
lpphreakx06's Avatar
Vietnam
316
Drives: SG 335i E92 RIP + 2015 SS M3
Make sure the arrow points in, disconnect the battery!
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1
|HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM
      05-18-2009, 08:41 PM   #7
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
I think we have him all fixed up
Mike
      05-19-2009, 10:12 AM   #8
egon10psi
Drives: 335i
haha so i broke a recrord and it only took my dumbass 3 hours to install. lol. This in nobodys fault but mine. I read into it way more than it was. One simple phone call to mike ( i love you mike!!) and everything was good to go. I mean i just had the entire ecu pulled apart and my car wouldnt start.....no reason to panic right???? lol
as far as the jb3 goes.....HOTT DAMN!!!! lol. I cant wait to try map 5.
Reply
e90post
