Strange limp mode. Any ideas?
05-23-2009, 09:02 AM | #1 |
54
Rep 886
Hi,
I was cleaning my car's interior today. After ~30 minutes I noticed the car starting to shake a bit and after several seconds it went into a limp mode. Shut it of, started again and it went into a limp mode after 5 seconds again. Then I took my c-reader and read the codes - misfire in cylinders 5 and 6, multiple missfire occasions (or smth like that). Cleared the error codes, started the car and everything was fine, didn't go into a limp mode. Any ideas what could be the reason? It's the first time my car goes into a limp mode. HPFP? O2 sims (set at 80%, haven't had any problems)? Anything else?
Mods: RB turbos, JB4, BMS DCI, Scoops, Forge DVs, ar design catless DPs, Milltek exhaust system, Helix FMIC, Quaife LSD, VK MotorWerks OC Kit, Bilstein B16 PSS10
05-23-2009, 09:10 AM | #2 |
54
Rep 886
Well, everything was just fine before. That is why I highly doubt a tune was the reason...
05-23-2009, 12:52 PM | #5 | |
54
Rep 886
Back to topic - any ideas?
05-23-2009, 01:00 PM | #6 |
Rep 2,320
+1 very strange, idle for 30 mins
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
05-23-2009, 01:05 PM | #7 |
Night Sh1ft
467
Rep 3,079
Drives: F95 X5MC LCI
honestly, I had a similar event a few weeks back.
I started my car and then had a call come in, and I was on the call for ~20 mins and got the limp mode. I got the limp mode when I hit the map switcher on my keychain and turned off of valet mode (took about 1 min after I turned it on). I'm betting its because the tune starts to advance timing under 0 load, and your spark plugs are probably not in top form so you got a misfire and limp. Swap your sparkplugs
"Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson |
05-23-2009, 04:13 PM | #8 |
54
Rep 886
Got a second limp mode today, this time when driving.
Yep, I'm 90% sure that I got the limp modes because of my spark plugs. Will change them next week. My car runs great, btw.
05-23-2009, 04:18 PM | #9 |
Rep 2,162
Yeah i'm gonna have to say swap your plugs and recreate the problem. If the other cylinder misfires...you know it's your plugs. I'm positive your plugs are going. Good luck!
