brake bulb failure
05-27-2009, 01:12 PM | #1 |
Rep 3,923
brake bulb failure
warning light came up today with the bong, said brake light out, sure enough drivers side not working, checked bulbs two of, both look ok but not working, does anyone know if one bulb blown will the other one not work also. suspect this is one for tony.
05-27-2009, 01:18 PM | #2 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Bulbs will be independant of each other - the second bulb only illuminates under heavy braking mind.
05-27-2009, 02:37 PM | #4 |
112
Rep 5,541
I'm not sure.......not looked at my rear lights working!
05-27-2009, 02:40 PM | #5 |
Rep 522
Both bulbs either side light up on mine. As far as I'm aware the brake force display is a US feature, I haven't been able to trigger this even when breaking very hard and ABS nearly going off. Had a mate follow me from a far and no extra brake light.
If both bulbs have gone then have a look at the bulletin I posted on this thread. The light fittings may be a bit loose and cause the bulbs to arch. http://www.e90post.com/forums/showthread.php?t=265415 |
05-27-2009, 03:18 PM | #6 |
Rep 3,923
two bulbs in each outer lamp and one for the brake force display located in the lamp in the bootlid. on closer inspection i found one of the bulbs had a tiny amount of corrosion and when moved worked again but with less voltage going through, a bit of wet and dry solved the problem, i suspect it may have been slightly loose and as you say was arcing
05-28-2009, 08:04 AM | #7 | |
Rep 8,114
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
05-28-2009, 12:16 PM | #8 |
Rep 522
05-28-2009, 02:08 PM | #9 |
Rep 615
I wondered this as well, sure i read somewhere in the blurb from BMW that my E93 has this, but have never seen it trigger, even when following the car
05-28-2009, 04:33 PM | #10 |
Rep 522
Based on the last paragraph on this page then it would seem that it only lights up when the ABS is going off. Kind of makes sense.
http://www.ultimatecarpage.com/car/2...35i-Coupe.html |
05-28-2009, 05:02 PM | #11 |
Rep 7,519
Drives: 2009 E90 335i MT
On the outer unit there are two bulbs for redundancy. If either is failed then the computer detects less current into the unit and shows there's a bulb out. On the E92 there is an issue with the bulb sockets which cause loss of contact with the resultant dashboard alarm. This is repairable under warranty and TSB.
The bulb in the unit in the boot lid is a single bulb that doubles as the active brake light and fog light, one on each side. Like its counterpart in the quarterpanel, if it fails you get the alarm. On the LCI the active brake light supposedly functions slightly different to the pre-LCI in that when the car slows nearly to a stop the emergency flashers start blinking. I've seen a similar setup on another car and, believe me, it does get your attention.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
