05-29-2009, 04:00 AM | #1 | |
Rep 12,446
2009 Audi TT RS First Drive
Audi Tries To Make a Porsche By Alistair Weaver 05-28-2009 Quote:
The 2009 Audi TT RS bears not a little weight of expectation. This is the latest product of Quattro GmbH, Audi's crack tuning division responsible for the acclaimed R8 and RS4. It also enters a sector of the market enlivened by the arrival of the brilliant new Lotus Evora, the Nissan 370Z and the revised Porsche Cayman. If you can raise the funds, there's never been a better time to indulge in a baby supercar. The 2009 Audi TT RS enters the fray with no shortage of firepower. The turbocharged 2.5-liter inline-5 offers up a mighty impressive 335 horsepower and 332 pound-feet of torque. It can, in other words, stand front splitter to front splitter with the Porsche Cayman S. Priced at $68,400 in the U.K., the TT RS also matches the Porsche for price, however. As things stand, Audi has no plans to bring the RS to the U.S., although there's no technical reason why it can't. "We'd need to do a bit of emissions work but it's not a big deal," says Stephan Reil, the head of Quattro GmbH. If the marketing boffins can make a case for the hottest TT ever, then America will be indulged. Well, the TT Did Race in the DTM, You Know We've become used to Quattro GmbH serving up subtle but effective makeovers. Think RS4 or RS6. Even the R8 makes the requisite supercar statement while remaining true to Audi's modest, Teutonic brand values. But the TT RS is different. It is (whisper it) a bit aftermarket. To separate its appearance from the regular TT, the RS gets a front aero splitter, extended rocker sills, new 18-inch cast-aluminum wheels, bigger tailpipes and a new rear aero diffuser. Such modifications are to be expected and tick the "add sportiness" box on the order sheet. More controversial, though, is the vast rear wing. With its bulbous aluminum mountings and flat plane, it looks ill at ease on the TT's otherwise curvaceous rump. It's the sort of thing you might expect to see on a 1980s Honda Civic driven by an acne-ridden 16-year-old. Clearly there are some at Audi's Ingolstadt HQ who agree, because it's a delete option. The alternative is a discreet, retractable wing that purrs into action at 70 mph. Much more Audi. Modest but Appealing Fortunately the RS's extroverted exterior isn't matched by a cabin done in a similar style (a job best left to the numerous tuning companies now specializing in Audi products). Audi's interior stylists don't do tasteless and the RS maintains the air of carefully coiffured modernity that characterizes the standard TT. The most noticeable revision is the introduction of two extravagantly sculptured seats that prove exceptionally comfortable as long as you've resisted the supersize temptation. There's a new steering wheel, a new gearstick for the short-throw gearbox and a revised driver's information system that includes boost pressure, oil temperature and a lap timer. There's also no shortage of RS decals, but the overall effect is still understated to the point of modesty. Not that it really matters. The TT's cabin is still a fine place to be. No material is ill-chosen and the quality is nothing less than superb. You get the impression that it'll still feel this good in 10 years' time, which is not something that can be said of the interior of the new Lotus Evora. Not a Porsche Engine On paper, the 2009 Audi TT RS would appear to have it all. The turbocharged, direct-injection 2,480cc inline-5 produces 335 hp, a fraction more than the Porsche Cayman S's normally aspirated, horizontally opposed six-cylinder. It also delivers a lot more torque than the Porsche, 332 lb-ft compared with the Cayman S's 273-lb-ft. And it gets to 100 km/h (62 mph) from a standstill in 4.6 seconds, also outrunning the Stuttgart reptile. Top speed is electronically limited to 155 mph, or if you pay an outrageous $2,070 extra, Audi will swap the ECU and let you do 174 mph. Subjectively, though, the TT RS never feels very fast. The power delivery is so linear and the engine note so consistent that you never really feel the force. There's a Sport button that changes the throttle response, stiffens the optional magnetic ride damping system and also opens a valve in the left-side exhaust pipe for more noise, but even this does little to inject excitement. The inline-5 turbo doesn't sound bad, but the five-cylinder thrum is no match for the Cayman's glorious soundtrack. It's all too clinical and efficient. Not a Porsche Chassis, Either Sadly, the same criticism can be leveled at the chassis. The RS's ride height has been lowered by 10mm and the familiar strut front and multilink rear suspension setup has been extensively retuned. Every test car at our disposal had been fitted with the optional magnetic ride damping system with a Sport mode. Compared with a TTS, the ride is noticeably firmer (even in standard mode) and the body control is now so aggressive that the car can bob awkwardly on the highway. You can't adjust the damping independently of the throttle response or exhaust note, so it's either full attack or nothing. This wouldn't be so bad if the trade-off was an increase in poise and fluency, but the 2009 Audi TT feels clumsy where the Cayman or Evora flows. The electrohydraulic steering is the culprit; it's horribly lacking in road feel. You turn into a corner and you feel an increase in steering effort, but there's nothing to tell you what the front tires are up to. The brake pedal also feels disappointingly mushy for what is meant to be a performance car. The ultimate performance of the brakes is not in doubt, but the delicate feel of the Lotus Evora is once again missing. Even on the famous Zolder racetrack in Belgium, where we also tested the car, the TT RS failed to come alive. There's no shortage of grip or ultimate traction, but there's no delicacy. Push the limits and you'll be met by safe, dependable understeer. In sum, this car feels too much like an Audi of old — capable and competent but ultimately uninvolving. From Audi and especially from Quattro GmbH, we've come to expect so much more. We drove both the coupe and the roadster versions. The structure of the latter is impressively stiff — remarkably so if you've ever driven a first-generation TT roadster — but you suffer a surprisingly high level of wind buffeting at speed. Another Member of the TT Family In Europe at least, the 2009 Audi TT RS will appeal to members of the Audi family who simply want to have the latest, fastest and most expensive TT. Some will be drawn to the roadster version for the added pose value, but Audi expects around 70 percent of customers to opt for the coupe. No doubt a large proportion of these buyers will revel in the RS's exclusivity, pace and ease of use. But, straight-line speed aside, the TT RS has little to recommend it over the much cheaper TTS. Ultimately, the 2009 Audi TT RS lacks the sparkle, the special ingredient that's so endeared us to other fast Audis of late. After a series of match-winning performances, Quattro GmbH has dropped the ball.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
05-29-2009, 04:56 AM | #4 |
Rep 8,034
A disappointing results given the high expectations considering the spec of the engine and the overall weight. It probably will still lap as quick as the new Cayman S and be as quick if not quicker on the track than the M3 but lack the involvement of either.
It a shame considering the price being asked, though I doubt Audi will have any probable shifting all they will make. Last edited by footie; 05-29-2009 at 07:07 PM.. |
05-29-2009, 10:21 AM | #7 |
Rep 4,013
I really wanted this car to do well, with the RS4, RS6 and R8 success, you'd expect that the TTRS would be true just like the ones that came before it. Sigh, T_T. I'd still test drive it tho.
05-29-2009, 10:44 AM | #8 |
Rep 4,483
Not surprised. Dropping a more powerful engine into a TT (or A5) does not a sportscar make.
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
05-29-2009, 12:03 PM | #9 |
D to the X to the B!
362
Rep 2,106
Damn....I really wanted this car to do great because this is the first time I have ever loved the looks of a Audi TT. I just love the huge Air intakes in front. The whole car looks
ANyway, I respect edmunds as they are one of the car mag companies that aren't biased to one company or so. So they must be telling the truth
11 corvette C6
05-29-2009, 12:12 PM | #10 |
Rep 1,917
Looks great too bad the performance doesn't match.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport |
05-29-2009, 06:38 PM | #12 |
Rep 1,964
Fuckit'! I'll have to wait 'til other reveiws or until I try one myself... I thought this thing would blow everybodys MIND!
________ Oxygen Vaporizer ________ New Mexico Dispensaries ________ LIVE SEX WEBSHOWS Last edited by Hula-Hula; 08-27-2011 at 09:35 AM.. |
05-30-2009, 12:56 AM | #15 | |
Rep 4,013
"I think one of the main issues with the reviews is that EVERYONE and I mean EVERYONE was expecting more of a rear wheel influenced car and more overall performance like a nissan z370/bmw 135i/porsche cayman. The one big thing that hit the TTRS hard is that it has a RS badge, with that, ppl are expecting a hell of a lot more and it just didn't deliver with all the over hyped expectations. As a fan of Audi, I too was expecthing porsche crushing results. It is a RS car right!?! Another thing that hurts it a hell of a lot is that it cost too much. They really are pushing porsches' way at selling cars. Stock got nothing unless you begin adding packages to the car. Everything is an extra. They did the same with the R8." |
05-30-2009, 04:46 AM | #17 |
Rep 10,404
Have you lost your marbles? As fast as the M3 at the track? Absolutely no way. Not with this power to weight ratio. Hmmm then again maybe with non showroom pads, wheels, tires a bit of under rating and an ex F1 pilot maybe it will....
05-30-2009, 10:41 AM | #18 |
Detailer & Fitness Freak
23
Rep 514
+1 looks amazing inside and out
+1 performance numbers are impressive -1 price -1 no intended import into the US overall great looking car...but too much $$
135i coupe...Alpine White // Glacier Silver Aluminum Trim // Heated Coral Red Leather Seats // M-Sport Package // I-pod // PDC // 6-Speed Manual
05-30-2009, 11:06 AM | #20 | |
Rep 8,034
I am disappointed that it don't appear to be as involving as I had hoped, but some people opinion of involvement means throttle control which has no real bearing on things. I will hold judgement until I get a drive myself as what may please me might not please the next person. |
05-30-2009, 01:44 PM | #21 |
I'm kind of a bitch
400
Rep 895
My wifey bought a tt when they FIRST came out, and boy did that car get a lot of compliments and comments. It fell apart on the inside though, knobs coming off in the hand, pieces breaking, glove box handle fell off.
We won't be getting another Audi when there are so many others to try! I do love those little lights on the front though.
E93: Montego/Cream <---- E46 (Coupe): JB/Black <---- E30 (Cabrio): Alpine White/Black
05-30-2009, 03:02 PM | #22 | |
Rep 8,034
I reckon you were very unfortunate. I thing I would add is the new one feels incredibly well built and is as special inside as cars costing three times the price. |
