US signal light modification
06-08-2009, 01:20 PM | #1 |
Rep 1
Hi,
I've lived in the US and when I moved back to Denmark og brought my '06 BMW 325i. As you probably know, US cars have a constant orange light in the frontlight. (signal) This needs to be changed in order to get it on danish plates. Does anybody know how to do that or someone who can assist, as dealers I have spoken with can't help. Thanks in advance. Brgds Lasse |
06-08-2009, 01:26 PM | #2 |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
You need to do a full headlight swap (US spec to Euro spec). Check with your local dealers for parts and labor.
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
06-09-2009, 02:09 AM | #3 |
Old Geezer
362
Rep 1,193
Drives: 08 E92 N53B30
It can be done without the expensive swap. The US headlights have two filament bulb for parking light and signal light. You have to cut the wire for parking light and connect to angel eyes. If you don’t have EA you can install white LED for parking lights. You also have to modify light switch to activate rear fog light.
06-09-2009, 04:06 PM | #4 |
Rep 577
You can't just cut wires and connect them elsewhere because the orange light that stays on is also the signal light. In fact you won't even be able to fix this problem with a headlight swap. You need the EU spec module which will not leave the signal lights running permanently. Good luck arguing with BMW.
06-09-2009, 04:56 PM | #5 | |
Old Geezer
362
Rep 1,193
It works I’ve done it.
06-10-2009, 02:21 AM | #6 |
Old Geezer
362
Rep 1,193
This is how it’s done:
06-10-2009, 04:06 AM | #7 |
Rep 577
Oh, we're talking E90 here. Sorry, I thought the OP had an E92. I suppose its different on the E90 then. The next question is whether the OP has Xenons or halogens. If he has halogens he will still need to swap them due to the different US DOT beam pattern which will not pass European inspections (in Germany at least).
06-10-2009, 08:10 AM | #8 |
Old Geezer
362
Rep 1,193
The car conversion to European standards is theoretically simple. That’s what I thought but it took lots of running around and lots of hustle. The question is if it’s worthy. Last year I was thinking of bringing another car from Canada but with the experience I had I decided to by the car locally.
06-10-2009, 09:13 AM | #9 |
Rep 577
+1. I also took a US spec into Europe and had similar experiences...which is what BMW wants . I think I saw your postings before in other conversion threads.
07-02-2009, 10:10 AM | #10 |
Rep 1,569
When I was stationed in Germany, a freind of mine (German) had an E46 sedan and he could switch between having the orange lights on or off. He said that the Local dealer could do it using the computer to change between U.S. spec or Euro spec lighting. Thats what makes the lights come on or off.
07-02-2009, 10:28 AM | #11 | |
Rep 17,767
07-02-2009, 03:17 PM | #12 |
Rep 577
This is not possible on the E9x platform anymore.
07-04-2009, 08:53 AM | #13 | |
Rep 80
In all, I bought the car in the US when the exchange rate was close to 1 EUR = 1.50 USD. So I have a fully specced out 335i for under 40k EUR that if I was to buy here, it would cost me over 80k EUR. Is BMW assist and RTTI worth 40k EUR??? I think not. |
07-05-2009, 09:35 AM | #14 |
Old Geezer
362
Rep 1,193
I my case the problems with the registration wasn’t the only reason for not importing the car. I was getting 08 model and at that time I couldn’t get the M packet in Canada. The other reason was N52 engine on the 328 compared to the N53 with a direct injection. In my case the saving wasn’t worthy.
07-06-2009, 12:05 AM | #15 |
Rep 22
Easy answer, check on www.ebay.de
You should be able to find a few available, sometimes in pairs. Im not sure how it works in Denmark but here in Germany the lights have to have the TUV sticker on the top of the housing or they wont accept it. |
