Snow foam advice needed please
06-09-2009, 08:40 AM | #1 |
Lons
10
Rep 383
I've done the searches and found plenty to read but doesn't fully answer my questions.
Just bought a load of snow foam (impulse purchase). I have a mid range Karcher with a built in detergent tank. You just pull out the tube and sit it in the bottle of whatever so thought this would work but I'm confused now as the posts suggest I would need a seperate foam gun. Any advice would be appreciated guys
06-09-2009, 10:57 AM | #2 |
Rep 1,060
I purchased a seperate foam gun which inserts into the lance, went for the cheap option (Karcher) and found it works ok. Many on here have purchased expensive types to get a good clinging foam mix, try a search I am sure you will find a few options.
G15, 840i M Sport
06-09-2009, 11:04 AM | #3 |
Rep 1,413
The Karcher tube will foam, but it will be weak.
You need one of these for silly-foam; http://www.cleanyourcar.co.uk/washin.../prod_371.html |
06-09-2009, 11:51 AM | #4 | |
Rep 9,218
http://www.autobritedirect.co.uk/sho...oducts_id=1748 Sounds like a lot of cash for not much, but it works a treat. 1/2 inch of snowfoam in the bottom of the bottle topped off with warm water will do the whole car. |
06-09-2009, 01:35 PM | #5 |
Rep 2,353
Drives: 2009 Z4 sDrive 23i
Megs Hyperwash is pretty good for foaming (as an alternative to snow foam):
http://www.cleanyourcar.co.uk/washin.../prod_326.html
E89 Z4 sDrive 23i... for the more discerning driver
06-09-2009, 02:24 PM | #6 |
Rep 1,314
I use the Karcher one at £17 from Halfords.
http://www.halfords.com/webapp/wcs/s...egoryId_165569 Works fine for me. |
06-09-2009, 02:34 PM | #7 | |
Defected to the dark side.....
211
Rep 5,795
Drives: BMW M5 LCi
I have exactly the same device and with very little snowfoam concentrate topped up with water, absolutely covers the car with a good clinging foam. I leave it to soak for 10 mins and then powerwash off before snowfoaming again and then use a lambswool mitt to clean the car. You can feel that all the grime and grit has already been loosened and then rinsed off before the mitt even touches the paintwork. The neighbours think I am nuts PS: dont buy a hosepipe one, they are crap compared to the pressure washer type. |
06-09-2009, 02:34 PM | #8 |
Lons
10
Rep 383
Thanks guys, that pretty much answers it. As an aside, I bought 20 litres of the stuff (4 x 5 bottle for less than £20 plus £6 p&p and it was delivered in 2 days.
obviously haven't tried it yet but they have excellent feedback. Ebay link: http://stores.shop.ebay.co.uk/CarChe...__W0QQ_armrsZ1
06-09-2009, 02:37 PM | #9 | |
211
Rep 5,795
Drives: BMW M5 LCi
06-09-2009, 02:54 PM | #10 | |
Lons
10
Rep 383
I've got a Renault Trafic as well and that's washed at least once a week so I'm not convinced yet about how long it'll last. Gonna do a search now and order a gun, (foam that is before somebody thinks I'm a terrorist)
06-09-2009, 03:29 PM | #11 | |
Rep 2,353
I'm actually just back in from giving mine a quick wash. As everyone is saying, only a small drop of concentrate is needed in the bottle to produce a good amount of foam. Recently I've actually been going for a more diluted/runny foam, rather than thick stuff, with the view that too much of it will start to eat away at the wax (read that on detailingworld.com)
