Highest WHP on a stock 335i?
06-22-2009, 04:51 PM | #4 |
Rep 2,479
The press review 335's given initially probably had around 285 whp. Just a guess.
Car:2008 E90 335i | BSM | ZPP | ZSP | 6AT Paddles | Black Leather | Dark Burl Walnut | Heated Seats
Mods: (All OEM) | BMW Performance CF Splitters | BMW Blackline Taillights | BMW Rear Deck Spoiler | BMW Performance Auto Shift Knob and Alcantara Boot | BMW Black Dakota Leather Split Folding Armrest | BMW Euro Fog Light Switch | BMW Style 193M Wheels | BMW Performance Gloss Black Kidney Grills | BMW Front Clear Bra | BMW Performance Steering Wheel (non-elec) |
06-23-2009, 07:23 PM | #6 |
Rep 6,140
Those numbers sound good. And confirm my butt dyno! I knew it had to be more than 300 hp stock (crank). nice.
Now, I definitely want to dyno the car stock before I start modding.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
02-24-2011, 10:19 AM | #8 |
Rep 5
I just had my 2007 335i Dyno’d. It's mostly stock with a Milltek catback exhaust. They did 3 pulls, all in 3rd gear. Very disappointing… 269.6 ft-lb. and 242.5 whp. After what I’ve been reading (275-285 whp stock), I expected much higher. My torque is peaking at about 3200 rpms and tailing off from there, which is impacting the hp which peaks at about 5500. Any thought on why this would be. Note that I bought the car three months ago and don't know if it's been reflashed, or what else has been done. My butt dyno says it is very fast. I buried a 535i the other day. Thoughts? Thanks.
02-24-2011, 12:36 PM | #10 |
Rep 10,587
pointless thread is pointless
every dyno reads a bit different and can often be very inflated. You can use a Mustang dyno and get 220whp on a stock 335 then go and put it on a dynojet and see 282whp. guess what, the car is still making the same power will be just as fast....or slow.
02-24-2011, 12:44 PM | #11 |
Rep 7,377
mine yield 252 whp .
02-24-2011, 12:46 PM | #12 | |
3442
Rep 79,211
02-24-2011, 01:02 PM | #13 |
Rep 10,587
hell I just had my car on cp-e's dyno Monday night testing. They had a newer modded GTR on it that put down 382awhp lol......that led to an unhappy GTR owner when in fact his car is probably fast as balls.
Jaronbwall284.50 |
02-24-2011, 01:02 PM | #14 | |
Rep 231
On a mustang dyno, i had 256hp/290 tq, all stock |
02-24-2011, 01:10 PM | #15 | |
Rep 219
Peak numbers are irrelevant when comparing to another car on any other dyno. I've personally seen over 300whp on an otherwise stock 335i at a local Dynojet... granted that was with a full correction factor (around the 1.25% range) at 6000 ft elevation (turbocharged vehicles don't lose as much power as elevation increased, making correction factors irrelevant). Either way, the same car strapped to another local Dyno Dynamics would be lucky to break 245whp (with "half-correction factor" normally reserved for boosted machines on that dyno)... Dynos are a wonderful tool when it comes to tuning/measuring gains & losses from modifications & tuning. However, not all dynos are created equal. Take the same car, strap it to a Dynojet, Mustang Dyno, Dyno Dynamics, Dynapack ect, and you'll get a variety of different results. People should try and see that they are only a tool, not an absolute measurement of peak power. If you want a true estimation of "power" per se, a better question to ask would be "what is the highest trap speed recorded by a stock 335?" Trap speed is a much better indicator of peak power than a dyno number IMO...
2008 Honda S2000 (weekend/former autoX) - 1996 Acura Integra GS-R (occasional autoX) - 2008 BMW 128i 6MT (track/time attack) - 2008 Nissan Xterra (winter beater)
02-24-2011, 01:15 PM | #16 |
Rep 5
Okay. This is making me feel better. I also just went out and raced my friend's 2008 335i. He just had the HPFP replaced along with 5 fuel injectors and a software tune. He says it's runniing great. We raced pretty much dead heat.
BTW, This is the Dyno machine that they used: "Our state-of-the-art testing equipment is the Land & Sea’s DYNOmite Chassis Dynamometer, this systems combines sophisticated data-acquisition electronics with DYNO-MAX PRO™ software for accurate, repeatable, and safe horsepower testing. This system utilizes dual tandem-rollers for stable testing and eddy-current absorption brakes for load simulations." |
02-24-2011, 01:17 PM | #17 |
3442
Rep 79,211
Cp-e's dyno is AKA the buzz killer.... Reads so low I think Stock Civics read 0 WHP. LOL
02-24-2011, 01:21 PM | #18 |
Rep 728
266 whp / 274 lb-ft for me.
Wow, I had no idea my dyno clip from 2006 is up to 50K views. Must be a record for 335i dynos. Considering my thread on e90post only had 1K views, must be a lot of people searching on YouTube. The tune I dyno'd is so out of date though. Talk about a trip down memory lane
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
02-24-2011, 01:25 PM | #19 | |
Rep 10,587
they might read negative and actually be blown away by their fans lol
02-24-2011, 01:30 PM | #20 |
Rep 219
That really is one hell of a clean E36!!
