Does turning off DTC help manual shifting?
06-25-2009, 03:48 PM | #1 |
Rep 17
Is it my imagination or does turning off DTC (1 sec tap on button) make 1st to 2nd shifting smoother? It seems so to me, but how can this be so? I would be interested if anyone esle has noticed this phenomenon!
06-25-2009, 04:18 PM | #2 |
Rep 5,046
I'd make the assumption that electronic stability control doesn't affect shifting. Might just be in your head? It will make it smoother if your flooring it because it will let the wheels spin a bit more rather than cut the power.
06-25-2009, 05:02 PM | #3 |
Rep 3,262
I think it does help: when turning DSC off (and DTC on), when shifting (under hard acceleration) from 1st to 2nd the engine will not cut the power in order to avoid wheel spin, so the shift is more "natural".
06-25-2009, 06:25 PM | #5 |
Rep 34
+1. I did this a few weeks ago and can't believe I drove the car for a year with the factory CDV....
E92 335i, 6MT, Sparkling Graphite/Black. Mods: Grocery Grabber
06-26-2009, 07:23 PM | #7 | |
Rep 34
In DTC (DSC partially disabled), the ECU applies the rear brakes to keep you from spinning the wheel with the least traction. It's pretty awesome that it does that, but if you do it all the time you're going to wear out your rear pads in short order. Of course it's your call.
