E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > O2 sensor DIY????
Reply
      06-30-2009, 03:25 PM   #1
joec500
Drives: it has 4 wheels
O2 sensor DIY????
I was wondering how involved it would be a to install a new O2 sensor? Is this something that can be done on ramps in a garage or would it be best to have a shop perform this?
Thanks!
      06-30-2009, 03:41 PM   #2
Sniz
Sniz's Avatar
661
Drives: e92 335 - gone // e36 M3 turbo
you can do it on ramps
front or rear o2 sensor....do you know which bank?
      06-30-2009, 03:45 PM   #3
Kevin@AKMotorwerk
Kevin@AKMotorwerk's Avatar
Drives: THE GUY YOU LOVE TO HATE
it can be done on ramps, just not always the easiest thing in the world. get a nice stubby 7/8 wrench to get the sensors in the tight spots like the first set on the down pipes
      06-30-2009, 03:57 PM   #4
Sniz
Sniz's Avatar
661
Wink
even better.....02 sensor wrenches
      06-30-2009, 04:42 PM   #5
joec500
I am not sure which bank, I forgot which cylinders are misfiring, I will report back as soon as the trouble codes come back on....
Also I assume there are plugs and this is not some Splice Situation?
      07-01-2009, 05:07 AM   #6
Former_Boosted_IS
Drives: 4 Wheels
+100! Those 02 sensor wrenches are worth their weight in gold!
      07-01-2009, 06:08 AM   #7
Kevin@AKMotorwerk
the factory ones have plugs, if you buy from bmw they will also have plugs, but you can buy bosche sensors from napa and you have to splice or swap the connector from the origional plug to the new one
      02-24-2011, 10:06 PM   #8
dzenno
Drives:
Has anyone used the napa o2 sensors on this car successfully?
      04-01-2011, 04:08 PM   #9
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
http://www.autopartswarehouse.com/de...RBA960903.html
check these out..
JB4 beta 15 ohms FSB,AEM inline filter/ CM 10, ETS fmic, ER custom made charge pipe,TSW Donnington 18's,Simitumo HTRZ3, Injen DCI, AR DPs, Forge DVs, AA SLD, Koni FSD, ZSP springs.
      04-03-2011, 04:21 PM   #10
ghost_rider
Belgium
26
Drives: BMW e93 320i 2010 European
where is the oxygen sensor wires connected to ? is it under the engine plastic cover?
      04-03-2011, 04:26 PM   #11
dzenno
Drives:
Yes
      04-03-2011, 04:34 PM   #12
ghost_rider
Belgium
26
my oxygens are gone will the car drive better if i disconnect them
Originally Posted by dzenno View Post
Yes
thank you dzenno
      04-03-2011, 04:55 PM   #13
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
thank you dzenno
Definetely not... The rear 02 sensors have to be in place and working correctly.
      05-23-2011, 12:18 AM   #14
yellowducky
Drives: 328i coupe / AW / Stock
Hi Guys. I have my engine lights on for the the following sensors
Bank 1 Sensor 2
Bank 2 Sensor 2
What causes it to have them both showing error anyways? Is this normal? My car is under CPO warrenty in Canada and not sure if they are covered. Can anyone of you help me our? Thanks in advance
      05-23-2011, 08:43 PM   #15
Tzu
Drives: 335i
I believe anything vital to the running engine is covered under CPO.
      05-23-2011, 10:30 PM   #16
yellowducky
Thanks for your responds. I would hope so.
      05-30-2011, 09:46 PM   #17
M3 Eater
M3 Eater's Avatar
Drives: 335i Sedan
2007 335i  [0.00]
I was told by an SA that they were not covered after 60K, even on a cpo.???
      06-03-2011, 07:10 AM   #18
ghost_rider
Belgium
26
Bank 1 Sensor 2
Bank 2 Sensor 2
I heard once that if the MAF is bad it trigger faults for both sensors.
I don't know how much is this credible i've benn told this by an independant parts seller.
      06-03-2011, 07:19 AM   #19
s2k_335i
This is it!!
s2k_335i's Avatar
Drives: FBO 335i without meth
Originally Posted by M3 Eater View Post
Nice findings. I think my will eventually rip due to the remove and reinstall.
DFW, TX. Current: 08' Cayenne GTS, 14' Boxster S, 12' CBR 1000', 04' Bayliner 2556
Sold: 2010 A4, 2008 335i, 2007 335i, 2006 M3, 2006 S2000, 1990 NSX, 1991 300zx, 1992 Supra, 1996 Prelude, 1981 CRX, 1980 Mustang.
Reply
e90post
