How much HP/TQ will a DP back catless exhaust add?
07-01-2009, 04:58 PM | #1 |
Rep 2,875
My mods are in my sig, my question is, with my set-up, how much more HP/TQ do you guys think I can squeeze out of my car?
I'm sitting right around 370whp/386wtq right now on 92 pump. Is this really necessary to maximize my tune and mods? I think so. But I was told that the stock exhaust runs just fine with stock TT, no need to upgrade. I disagree with that, what do you guys think? Please chime in TIA
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
07-01-2009, 05:00 PM | #2 |
Rep 1,410
stock exhaust has cats and crushes. It will run "fine" but a catless exhaust with mandrel bends will run "finer"
Just be careful that you actually buy a dp back EXHAUST and not an axle back "exhaust" or you will still have crushes and cats... |
07-01-2009, 05:00 PM | #3 |
Your'e gonna learrrrrrnn tooooday
39
Rep 595
I would say its totally up to you...seems like you already made up your mind about it.
2013 BMW 328i MSport F30 - Estoril Blue
"Minds are like parachutes. They only function when they are open." James Dewar |
07-01-2009, 05:16 PM | #4 |
Rep 2,875
What I said in my OP was just my opinion, or what I've learned about the N54 platform.
I'm always openminded and just would like to hear what others with the actual experience have to say......
07-01-2009, 05:19 PM | #5 |
Rep 726
as far as HP gains you will get answers all over the place but we did a back to back test with a couple different systems and average gains were about 15-20whp with a full down-pipe back system with no cats compared to the stock system.
Eric |
07-01-2009, 05:44 PM | #6 | |
Rep 414
I have test both
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB3 2.0|Unlocked 18ohm Board|BMS Meth Kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP |BMS DCI|AA Exhaust|Helix fmic|CDV|H&R coilover| 10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, 11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph at 10.18
07-01-2009, 05:47 PM | #7 |
Rep 2,875
^^ 15-20 hp to the wheels? Is that with a tune, or just the exhaust, leaving everything else stock?
If that number is to the wheels with a tune, then it's better than I had expected. Would you mind disclosing what type of DP back exhaust were being tested to come up with that number? One more question: Since you guys deal with forced induced cars, would you go with a H-pipe like on the HKS exhaust, or go with the fully divorced pipes like on the AE exhausts. I believe the stock exhaust setup has an X-pipe post secondary cats, right? I was originally going more towards the fully divorced pipes(AE exhaust), but if there's no performance difference, I like the HKS exhaust, but it has an H-pipe. TIA
07-01-2009, 05:56 PM | #8 |
Rep 1,410
I personally prefer divorced pipes on a twin turbo... like each turbo has its own exhaust with no H/X in place to cause disruption in flow.
On an N/A engine the H/X pipe is essential on a dual exhaust for load balancing, helping with the mid-range torque. I think the only reason people like BMW and HKS have included an H/X on our cars' exhausts is to reduce drone. AE seems to be the only brand that was able to do that without using the H/X which is a big huge for them. |
07-01-2009, 05:57 PM | #9 | |
Rep 3,432
07-01-2009, 06:05 PM | #11 | |
Rep 726
I notice you already have downpipes. Even if they are catted going to a catback and catless DP's I would not expect more than say 10whp over what you have unless they are using VERY restrictive high flow cats. Eric |
07-02-2009, 01:20 PM | #12 |
only in it for the torque - awuleth'umshini wami
50
Rep 425
Drives: sapphire black 335i
I agree with Eric@AMS.
I am assuming you have CATTED Riss DPs. Heres my suggestion: From Catted Dps - keep OEM secondary cats in place AND pipes in between - remove resonator if you have one and replace with X pipes - from here replace OEM mufflers. Or instead of bits and pieces get a full catback exhaust system running from AFTER the second cats as per above. Your HP370 and 386TQ are serious performance numbers already and a true catback system as per my suggestion will give you better numbers and driveability. Removing the secondary OEM cats and replacing your CATTED DPs (if you have) for catless DPs will ONLY increase your existing numbers marginally and give you future driveability issues - (If you had JB3, I would have said just run a higher race map with race fuel to get what you MIGHT get with a catless system.) See attached picture: In a nutshell ONLY remove the parts in the picture:
07-02-2009, 01:46 PM | #13 |
Rep 2,875
^^ I have RR CL DPs already. I also want a full bolt on DP back exhaust. No cutting, clamping or welding!
I was hoping to see around 390 hp and 400 tq with the addition of a catless exhaust. Maybe even bump up the UT values a little to obtain that goal. Looks like AE exhausts are the way to go......??
07-02-2009, 02:08 PM | #14 |
Rep 1,031
If ur gonna grab a downpipe back exhaust, than grab the ae,, it is the least obtrusive from day 2 day driving... Very little2 no drone at all. I'm completely catless and it sounds amaziing.... U will again around 15 whp on top of what u have now
07-03-2009, 01:43 PM | #15 |
50
Rep 425
Keep us updated on your plans.
